Randy Griffin 68 Posted May 30 Share Posted May 30 My sandpaper is leaving a grey residue on my wood. I have cheapo from Amazon and I have 3M. It’s not noticeable on darker wood but I’m using some hard maple and it’s turning the wood grey. I tried alcohol and it helped but didn’t clean all of it off. Y’all got any tricks? Link to post Share on other sites
Alan Longmire 3,783 Posted May 30 Share Posted May 30 #0000 steel wool tends to remove stuff from the pores, but if it's the cheap stuff leaving the residue, I'd save it for dark wood only and use the good stuff on the maple. If they're both leaving gunk, I don't know what to tell you. What grits? You can also try floating it out in acetone, but that risks pushing it deeper into the wood. Link to post Share on other sites
Randy Griffin 68 Posted May 30 Author Share Posted May 30 The cheapo and 3M does it. Mostly the higher grits like 500 up. 220 does a little but not nearly as bad. It’s worse on the edges of the scales where I’m sanding wood and metal. Going to try the steel wool. Link to post Share on other sites
Alan Longmire 3,783 Posted May 30 Share Posted May 30 I get that when I sand maple that has silver inlays. The wool usually cleans it right off. I use both the regular hardware store #0000 and, for final cleanup, Liburon brand #0000. It's about twice again finer than the hardware store stuff. Hard to believe they're both called #0000. 2 Link to post Share on other sites
Randy Griffin 68 Posted June 10 Author Share Posted June 10 The 0000 steel wool worked great. The problem was the fine sand dust coming off the tang. Steel wool is not hard enough to cut the steel so it just cleaned the wood. Thanks Alan. Link to post Share on other sites
