I got an idea......
Joshua States
I started this project today. I'm still not sure how this will end up as a KITH entry. There are two sets of 3 tools each set in this mix. I may offer one of the sets or both. I'll probably decide, after I find out whether this works or not.
First thing to do was dig through the Damascus cut-offs for usable pieces.
I also ended up salvaging this little piece of Flat stock for one of the tools.
Then I set myself to forging them into submission.
Rough grind to 120 done. That little bit of flat stuff was center drilled, shaped,  and curved.
Welded those suckers to a piece of scrap flat bar in preparation for HT.
And they got hardened and tempered.
  • Like 3
Onward we go.......
After taking the surfaces to 220 grit.
Then it was time to make the handles. I took some quilted maple and turned them out on the lathe.
Then I ground the tangs down to fit inside the 3/16" holes.
The finish on the tools is 400 grit in preparation for etching. The handle finish is also 400 grit with some light Pecan stain and Danish oil
  • Like 5
So after a couple of ferric etches, and stenciling my marks, I did my bluing and here the blades are.
The little finger saddle has a nice ladder pattern
Now to glue them up and sharpen them.
  • Like 3
These are all glued up and ready to sharpen.
Three leather working knives
And three wood carving chisels
I rather like these, so I will throw one set of three into the KITH. Whomever draws my project picks which set they want.
  • Like 4
