Mike Jesensky Posted May 30 Share Posted May 30 Hey guys,I have been getting by with my makeshift ways of filing shoulders and all else,but now want to get some hardened file guides before they go up another $10. I see two types, one has two pieces of metal and one looks like there are 3,I wanted to ask owners of each why one is or isn't better.as far as I can see from images maybe the one with 3 pieces could be held better in a vice while also holding a tang,any thoughts? Link to comment Share on other sites More sharing options...
Geoff Keyes Posted May 30 Share Posted May 30 What pictures are you looking at? ' g 1 "The worst day smithing is better than the best day working for someone else." I said that. If a thing is worth doing, it is worth doing badly. - - -G. K. Chesterton So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy. Grant Sarver Link to comment Share on other sites More sharing options...
Dan Hertzson Posted May 31 Share Posted May 31 Recommend you get the type with dovetailed carbide faces. 1 Link to comment Share on other sites More sharing options...
Mike Jesensky Posted May 31 Author Share Posted May 31 Link to comment Share on other sites More sharing options...
Carlos Lara Posted June 1 Share Posted June 1 The extra piece in the Jantz one is just where the screws attach. Otherwise they are functionally identical. I don't think there's really a pro or con either way. 1 Link to comment Share on other sites More sharing options...
Mike Jesensky Posted June 1 Author Share Posted June 1 Dan, I hadnt even seen that type,but after looking around I found it and ordered one. Thanks Link to comment Share on other sites More sharing options...
Mike Jesensky Posted June 1 Author Share Posted June 1 thanks guys,I searched "carbide file guides and amazon had some for $120 and then searched"dovetailed carbide file guides" I found a set for $65 made by Derraco I believe that I may have seen that name in the knife places I looked at for the past decade or so,plus they were a better deal and ordered them Link to comment Share on other sites More sharing options...
Mike Jesensky Posted June 1 Author Share Posted June 1 Link to comment Share on other sites More sharing options...
Dan Hertzson Posted June 1 Share Posted June 1 (edited) 18 minutes ago, Mike Jesensky said: Dan, I hadnt even seen that type,but after looking around I found it and ordered one. Thanks Makes a big difference if you are going to use your file guide with your belt grinder. Now the second trick is to get a set of longer pins and clamping screws so you can also use it for integral bolsters. Edited June 1 by Dan Hertzson 1 Link to comment Share on other sites More sharing options...
Joël Mercier Posted June 1 Share Posted June 1 I've heard a lot of carbides pop off on the guides which they are just glued on. So I bought one with screwed on carbides. Also, here's a model made for integrals: https://maritimeknifesupply.ca/products/behnke-integral-file-guide Link to comment Share on other sites More sharing options...
