Pommel Caps
Joshua States
Pommel caps or butt caps, whatever you call them, they are a classy finish to a solid handle, especially antler.
Here I have two separate antler handled knives each with a pommel cap of 1/8 inch nickel silver.
One of them looks much thinner than the other, even though they are the same thickness. The difference is the "thinner" one has had the edges beveled down.
So if we take this thicker looking cap
And thin down the edges a bit
And buff those bevels to a mirror finish, it looks like this.
How far up the face you take the bevels is a matter of personal choice.
5 hours ago, Doug Lester said:
followed the contours of the antler
That's a time-honored finish, especially in German knives from the Black Forest region.  I have also been known to cheat by beveling the end of the antler and insetting a cap.
This is handy when the crown was cut wrong and the pith is showing.
That's a good cheat Alan!
And it's surprisingly easy to do. You just need a couple of blind pins to keep the plate oriented and a through-rod with nuts and washers. That allows you to scribe the outline and cut away what's outside the lines.
