Bob Bryenton Posted October 10, 2023 Posted October 10, 2023 Kiln Build Target is a 36” kiln capable of heat treating a sword. Parts: Inkbird F and C Display PID Stable Temperature Controller Itc106vh with K Sensor thermocouple https://www.amazon.ca/gp/product/B01LQ8TP00/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1 2nd SSR https://www.amazon.ca/gp/product/B06WD65K6K/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1 Ceramic Connectors https://www.amazon.ca/dp/B09QSH1XJ8?psc=1&ref=ppx_yo2ov_dt_b_product_details SSR Thermal Paste https://www.amazon.ca/dp/B09MHX5JYF?psc=1&ref=ppx_yo2ov_dt_b_product_details K23 Firebricks - 45 https://www.morganthermalceramics.com/media/9429/k-ifb-series_eng.pdf 14g Kanthol Wire https://psh.ca/products/1lb-kanthal-a-1-wire-14g Project Box https://www.amazon.ca/dp/B09DD89B9J?psc=1&ref=ppx_yo2ov_dt_b_product_details Cable Glands https://www.amazon.ca/dp/B088KQK2NV?psc=1&ref=ppx_yo2ov_dt_b_product_details Door Hinges https://www.amazon.ca/dp/B0C65STJGK?psc=1&ref=ppx_yo2ov_dt_b_product_details High Temp Wire https://www.amazon.ca/dp/B00OK6G81K?psc=1&ref=ppx_yo2ov_dt_b_product_details Limit Switch for Door https://www.amazon.ca/dp/B08VS4M2GW?psc=1&ref=ppx_yo2ov_dt_b_product_details Steel: 2 old bed frames Aluminum Flashing from the scrap pile Calculations: I have a 220V 50amp circuit available to me. I will target 30amps giving me a large margin of safety. Kiln surface area is 8” x 36” top and bottom and sides are 7 ½” x 36” left and right. Back and Front are 8 x 7 ½ for a total surface area of 1236 sq in or 3146 sq cm 30 amps x 220 V = 6600 Watts. Use a 90% safety factor again to stay under our target 30 amps. 1.89 Watts/ sq cm. This is a bit overkill. Dividing the wattage by 2 for each side gives me 2970 (or 3000) watts per side Calculating the required resistance is V squared/Watts = 16.296 ohms Using 14ga Kanthol A1 at 0.2131 ohms/ft means I need 76.47 feet of wire per side Using 16ga Kanthol A1 at 0.2687 ohms/ft means I need 60.65 feet of wire per side 1 Bob Bryenton Solar Storm https://www.solarstorm.ca bob@solarstorm.ca
Taylor Hendrix Posted October 10, 2023 Posted October 10, 2023 Are you worried about the bottom kaowool outer jacket compressing over time and allowing your brickwork to open up? You might think about redesign and either adding a hard board to the bottom instead or perhaps increasing softbrick thickness.
timgunn Posted October 10, 2023 Posted October 10, 2023 I have built a few HT ovens. I think 6 or 7 at 18", one at 23", one at 42" and 2 at 28", though the 28" ones would bolt together to make a 56" one for swords. Inkbird controller should be ok, but download and THOROUGHLY read the manual beforehand. If you understand it all and it'll do what you need it to do, great. Use the Inkbird. If not, look for something else. If you can't download the manual without buying, don't buy it. Caveats from just looking at the link: it says 0-400 degC. Make sure the output is sufficient to drive both SSRs if you are using 2 (ISTR the spec on my SSRs being 20 mA max each). Whatever controller you use (it'll almost certainly be 1/16th DIN, 48 x 48mm), leave some extra length on the wires when you connect it. That way, if you decide to upgrade later, it'll be easy. All the controllers have essentially the same connections, but the layout varies. You haven't got a link to a thermocouple. The one that comes with the Inkbird will not work for an HT oven. You'll also need suitable cable. I source my thermocouples from the supplier we use at work, but I'd recommend you sit down with a coffee and a notebook and phone the tech sales folks at Omega. They know their stuff. I usually use Mineral Insulated Type N transition thermocouples with insulated junctions and Nicrobell sheaths (Omega have their own Super Omegaclad XL high-temperature sheath, which is also excellent). The transition junction means the extension cable is already fitted and is one less thing you can louse up. Type N was developed as an alternative to type K with a much lower tendency to "drift" at high temperatures. If you want to use type N, make sure your controller supports it. The Inkbird in your link does. SSR. I haven't used the Inkbird ones, but I've used a lot of the cheap import SSRs, mostly Fotek. They are cheap and have a tendency to fail. Get spares. My ovens have had failures both "open" and "closed". I had a bad experience some years ago with a Crydom SSR that failed "closed", so do not trust SSRs to provide safe isolation and always use the door switch to bring in a contactor. My ovens have gone to people I know and like. I'd rather not kill them. Ceramic connectors. When I stopped using 16 AWG Kanthal A1 and stepped up to 14 AWG, I bought wound elements from a specialist who checked my calculations and offered advice and only charged the same as the price I'd pay elsewhere for the wire alone. They were pretty adamant that bolted connections were the way to go. Apparently the ceramic connector blocks are a common source of failure. I didn't ask too many questions, as the guy seemed to know his stuff. I use M6 stainless bolts, nuts and large-diameter washers. On my most recent ones, I use M6 stainless allthread and keep the Kanthal end and the Copper end far enough apart that I don't need to use expensive hi-temp cable. Thermal paste. Any decent thermal paste should be fine. I've generally used Arctic Silver because I had it from building computers. You need a good heatsink, which you've not mentioned. The extruded Aluminium ones on ebay, etc. are ok up to about 15A as far as I can tell. Over that and you can expect SSR failures. As said above, I've had Fotek 25A SSRs fail on 13A with the extruded heatsinks (UK domestic outlets are 230V, 13A and I have the elements wound to draw nominally 12.5A at 240V so they keep within 13A). K23 IFBs are probably the best choice in North America. I use JM23 here in the UK, which are apparently made (also by Morgan Thermal Ceramics) in Italy and which seem to be very close in performance to the K23. They tend to go all melty when used for forges, but are by far the lightest and best-insulating IFBs I've found for HT ovens. When I built the 42" oven, it was a quick-and-dirty build. I used cheap grade 23 IFBs I'd picked up locally from a place making pet crematoria. I also picked up some Ceramic Fibre Board. For speed, I made the 42" oven 9" wide (no need to cut the IFBs). The roof was made from the board so it bridged the 9" gap and I used board for the door too. I've used board for the roof and door of several of the more recent builds too. It makes things much easier, particularly for the door. 14 AWG Kanthal A1 is what I use now. My first few builds used 16 AWG and there were element failures. I think some of the failures were due to the use of stainless allthread to get through the wall and imperfect connection to the Kanthal on the hot side. Using doubled, twisted tails on the Kanthal to get through the wall and bolted connections on the outside, together with the thicker Kanthal, has apparently overcome the problem. I use staples bent from thinner Kanthal A1 to pin the elements in place in the grooves. You will need to order it with the elements if you intend to do the same. Project box is not the one I'd choose. It's plastic, which is a poor conductor of heat, and you want to be cooling the SSRs and their heatsinks as effectively as possible. I use steel enclosures for this reason. YMMV. Cable glands seem fine, though I'm not sure whether PG threads are standard/common in North America. Hinges look like a PITA. I use fire-door hinges on all of mine. Door closure is something to consider. The first HT oven I built used an overcentre door catch. After using it for a few weeks, my test-pilot pointed out that it was absolutely crap for HT of multiple blades because it took both hands to close the door. I came up with a quick-and-dirty F-handle arrangement to provide one-handed closure with compression of the Ceramic Fibre Blanket door seal. High-temp wire. If it's needed, it's needed, but I have designed it out of mine. The Silicone Insulation is not tough IME and I don't want it anywhere it can get damaged (we're on 230V mains over here). I stick to Tough Rubber Sheathed mains cable wherever possible (H07RN-F is the designation here in the UK). Door switch. Not much detail there, but looks like it can be made to work ok. I can't remember which one I use, but it does have the facility to manually override it by pulling out the actuating rod. This allows the elements to be powered with the door open for faultfinding and maintenance, which is useful. As mentioned above, I use the door switch with a contactor, rather than just putting it in the DC circuit to the SSR(s). Calculations: I'd recommend a rethink. The 42" one I built was 3 kW per side and it was too much, according to the guy it went to. He thought 3 kW total would have been better and I'm inclined to agree. It was only being used for HT of Carbon Steels, which massively reduces the power requirement compared to Stainless steels. I assume it'll be the same for You? Good control and steady temperatures are MUCH easier to achieve with appropriate power. If you are going to be using the same oven for tempering, you REALLY don't want too much element power. I've waffled enough for now. Any specific questions I might be able to help with, please ask.
Bob Bryenton Posted October 11, 2023 Author Posted October 11, 2023 Brilliant Advice! I am totally familiar with the inkbird controller so no issues there. The advice on maybe too much power is something I never thought of. My initial thought was more is better... but I can understand the logic as too much could lead to cycling. Looks like I did forget to mention the thermocouple and heat sinks, but have both as well. My thought on the bricks was to use a ball router to create a round groove like my wife's pottery kiln and avoid the "pins" for the Kanthol. for the Kaowool on the bottom I was thinking of how to support the bottom, potentially with some 1" angle iron running the length but turned so that it is flat on the bottom, and extending down. I think it should be OK as my wifes 6000w pottery kiln doesnt even use any insulation. Target is for Carbon steels. I have a commission for some swords for a wedding and have no heat treat facility. For my smaller knives, i have been using my wifes pottery kiln with great results, but it will only do an 18" blade. Bob Bryenton Solar Storm https://www.solarstorm.ca bob@solarstorm.ca
timgunn Posted October 11, 2023 Posted October 11, 2023 You will get cycling. It's inevitable, but you can reduce it to insignificance with a short cycle time. You'll get a saw-tooth temperature variation with the tooth pitch being the output cycle time and the tooth shape being down to the rate-of-temperature-rise with the elements powered and the rate-of-temperature-fall with the elements unpowered at the temperature of the chamber. At low temperatures, the rate-of-rise is high and the rate-of-fall is low. At higher temperatures, the rate-of-rise is lower and the rate-of-fall is higher. By running a short output cycle time, the size of the teeth reduces, making the deviation from setpoint smaller. I found that a 2-second cycle time gave me no discernable variation using the monitoring equipment I had access to from work (various thermocouples, including 0.5mm diameter fast-response ones, and a paperless recorder logging at one-second intervals). I fit an LED indicator on my control panel, connected in parallel with the elements. It is on when the elements are powered and off when they are not. A 2 to 4 second glance is enough to tell me roughly how much power is being applied from across the shop, so I stuck with the 2-second cycle time. I use a router to make square-bottom grooves and pin the elements about every 3 inches. getting the elements evenly into grooves cut with a ball-cutter seems a lot like hard work to me (like pushing string uphill), though I can see the advantages. I'd still pin the elements, though maybe at wider intervals. Pinning the elements is the most tedious part of the build for me (at least since since I started routing the grooves. On my first build, I filed them in with a bit of bent allthread and that got very old very quickly). When I spaced the pins wider (one pin per 4 1/2" IFB), I found the coils tended to move axially and bunch up. They never touched and shorted (I've always stretched the elements to at least 3 times their closed length and aim for 4 times or more), but running the oven with the door open showed that the bunching was causing uneven heating. Probably not enough to be a problem, if I'm honest, but enough that I wasn't happy. Some pics of how I build mine, in case it helps. The router makes it easy, particularly with the scrap-wood jigs. Early on I made D-bits from tig electrodes to drill the IFBs. When i needed to hold a forge together, I tried cutting a welding rod with a pair of side cutters (dykes?) and using that as a drill. It worked (I think the dust gets pushed into the pores in the IFB. It needs a starter hole to stop it wandering, and the starter hole needs to be pretty straight, but it seems to drill straight holes much like a gun drill. For the forge, I drilled through several IFBs until the welding rod came out the other side, then just cut of the protruding rod to leave the iFBs pinned together. It's useful to know and is cheaper than using drill bits to drill IFB. The steel guide for routing the element grooves provided some much-needed welding practice and has saved a lot of frustration. The pics are of one of the 28" ovens (27" of IFB and 1" of kaowool blanket each end as a door seal that compresses down to 1/2" in use) and the elements come out of the sides so the backs can come off to bolt 2 together. 2 1
Bob Bryenton Posted October 12, 2023 Author Posted October 12, 2023 @timgunn this is so helpful!, thank you Bob Bryenton Solar Storm https://www.solarstorm.ca bob@solarstorm.ca
timgunn Posted October 13, 2023 Posted October 13, 2023 A few more pics, in case it might help anyone. It's a 3 kW oven. The temperature is in degC and the pics were taken on the first heat, which was before tuning the controller, hence the overshoot. 1300 degC is the upper limit of the Type N thermocouple I use and is 2372 degF. The 1288 degC setpoint is 2350 degF and it seems to run and control to that temperature quite happily. Inside the panel, on the left, are a 16A 2-pole circuit breaker and a 30 mA Residual Current Device (GFCI?). On the top-right is a contactor which is configured for No-Volt-Release and is dropped out by the stop button and/or by the doorswitch. It is pulled back in by the (momentary) start button (though this has been swapped, by the guys who now have them, for a rotary selector on a couple of the ovens, so that power is restored as soon as the door is closed and they don't need to remember to press the start button after closing the door when treating several blades). The green LED indicator on the front of the panel shows when the contactor is in. Bottom-right is the SSR on the standard e-bay heatsink. Here in the UK, we are on 230V "hot" and Neutral is bonded to Earth/Ground at the electricity supply company's transformer, so we only need one SSR on the "hot". Not shown is the bottom of the panel. There is a 16A socket to power the elements, fed from the SSR output. There is also an "unusual" 3-pin socket for the door switch. The type N thermocouple plugs in to a miniature socket on the front of the panel. The idea is that I can use the panel to control anything I might want to temperature-control up to 3 kW. I've played with little saltpots for heat-treating, melting furnaces for casting and a few other things in the past, so it seemed sensible to design-in a bit of versatility. The "unusual" connector is one we use at work and is unusual enough that there's no chance of anyone plugging in anything else. If the panel gets used to run something without a doorswitch, a plug with the pins linked gets plugged in. On the front of the panel is the controller. I use either an Omega CN7823 or an AutomationDirect Solo SL4848VR. They are essentially the same instrument with different badges and I buy whichever is cheapest at the time. For many people building HT ovens, the fact that Omega sell thermocouples, thermocouple cable cable, connectors, etc, can tip things in their favour once shipping costs are considered. To the right of the controller is a yellow 230V LED indicator, connected in parallel with the output to the socket supplying the elements. In normal operation, this flashes every 2 seconds (I use a 2-second output cycle) and it's quite easy to tell how hard the elements are being run from the proportion of the 2-second cycle the LED is lit. To the left of the controller is a sealed USB bulkhead connector, on the back of which is a cheap ebay USB RS485 converter, connected to the controller, so I can plug in a PC via the USB socket on the outside for programming and for logging the temperature. The pic of the 2 ovens from the side shows the 1" x 1/8" angle and 1" x 1/8" flat frame and the fire-door hinges, along with the F-handle I used from about my third HT oven. It is not elegant, but it works well enough that I've not seen fit to design anything better. These have IFB roofs and 2" CB board doors and backs.
timgunn Posted October 13, 2023 Posted October 13, 2023 With the 2" CF board door, there are 2 frames that bolt together and clamp the board. If a longer oven is needed, longer bolts can be used and extra layers of board can be added. At Carbon Steel Austenitizing temperatures, I'd have no concerns adding 2 layers of 2" board for an extra 4". With the elements coming out of the side on these ovens, the back can be extended too, giving an extra 8" total and 36" overall length. The 2 ovens combined give 56" and this could be extended to 68" with 4" of board in both doors and 4" in the middle. The ugly-looking standoff brackets for the hinges are intended to give more even compression of the CF blanket doorseal.
timgunn Posted October 13, 2023 Posted October 13, 2023 My preferred doorswitch is a Johnson Electric/Saia Burgess DS3UL, mainly because it has the override facility by pulling out the plunger. Pics with extensions in place. Notes from the initial test run at 28" (no extensions) giving time to various temperatures. I was hoping to reach 1100 degC within the hour and 1177 degC (2150 degF) within an hour and a half to give a reasonable compromise between capacity and speed: 2150 degF still seems to be enough for any of the stainless steels likely to be encountered by anyone using one of my ovens. In the event, 800 degC was reached in 22 ½ minutes, 1100 degC took 54 ½ minutes, the temperature at an hour was 1125 degC and 1177 degC (2150 degF) took 71 minutes. 1
Bob Bryenton Posted October 14, 2023 Author Posted October 14, 2023 @timgunn I have some rework to do. I will try and copy a bit of what you did and make 2 sections that can be bolted together. Most of my work is knives and heating a 36" kiln for a 10" knife is overkill. You have been a wealth of knowledge. If we ever meet, the coffee or beer is on me. Bob Bryenton Solar Storm https://www.solarstorm.ca bob@solarstorm.ca
Alan Longmire Posted October 14, 2023 Posted October 14, 2023 5 hours ago, Bob Bryenton said: You have been a wealth of knowledge. That's Tim for you. I am going to pin this thread, it's the best so far on HT oven builds, thanks to Tim's detailed input! 2
timgunn Posted October 14, 2023 Posted October 14, 2023 I feel I should explain why I use the relatively expensive controller that I use. Back when I built my first HT oven in 2009, I used a lot of stuff that I'd scrounged over the years. I put the system together on the cheap (I bought the elements and the IFBs. Everything else was from my "it'll come in handy one day" pile. There are dangers to oversimplifying things and there are dangers to overthinking things. Because I play with temperature control systems as part of my day job, I could foresee a number of potential issues with the control system, but couldn't be sure whether they'd actually cause any problems in the real world. The only way to find out seemed to be to build and test. I expected to go through several iterations before I felt that I'd got things about where they should be, so I expected to build several HT ovens. I'd teed up one or two test-pilots: guys who actually make knives, whose judgement I trust, and who have the smarts to be able to provide enough feedback to enable me to understand the shortcomings they found. Before the first oven went out, I did some testing. Because they were what we use at work, I was using 6mm diameter Mineral Insulated type N thermocouples with insulated junctions for the control and I was concerned that they might have a slow response that was effectively damping out the controllers ability to "see" temperature fluctuations that had the potential to affect performance, particularly at the cutting edge. The controller I was using was a very basic one. I had a number of thermocouples of different diameters, which I felt would approximate several different locations on the bevels of a blade. I had a 1.5 mm (.060") MI assembly, that seems to have had a grounded junction, a 0.5mm (.020") MI assembly that appears to have had an insulated junction and a 3mm assembly with an exposed junction. I had a paperless recorder that could log them all at one-second intervals. I wanted to see what happened when I stuck a simulated bevel in the oven, set a tempering temperature and started the oven. The top trace below shows this. The control thermocouple (6mm, Insulated Junction) shows a nice steep initial increase in temperature, with the controller limiting the power as the 250 degC, 482 degF, setpoint is approached, giving a gentle creep up on the setpoint with no overshoot. It looks wonderful and anyone watching the display would be pretty impressed. However, the thin thermocouples tell a different story. The edge of the blade might be expected to see a similar peak temperature to the highest of the thin thermocouples: 369 degC, 696 degF. For O1 steel, the controller display would suggest a tempered hardness of around 58 HRC. For a 6mm (1/4") thick blade, tested on the flat (spine, ricasso, etc), a hardness close to 58 HRC would seem quite likely (at 6mm thick, the steel might be expected to behave rather like a 6mm thermocouple). However, the edge would have got to 696 degF and it's tempered hardness would be around 53 HRC. I had borrowed a high-end controller from work and set a (30-minute?) ramp-to-temperature for the second run. Overshoot was down to 19 degC, 34 degF. Still not great, but a 100 degC, 180 degF reduction in overshoot giving a "mere" 1-2 point reduction in hardness, rather than 5 points. Subsequently a slower ramp and the use of a smaller-diameter, faster-responding control thermocouple helped further reduce the simulated-edge-overshoot. I'd still advise burying the blades being tempered in a tray of dry sand and giving them an hour or two longer to get the sand to temperature. I've not tried the same logging exercise with any of the big-name HT ovens, but I'd be very surprised if they don't show the same effect to some degree. Most seem to use an exposed-junction type K thermocouple with ceramic insulators and the wire gauge seems to be around 14 AWG. I'd expect these to show some lag, though considerably less than my original 6mm insulated junction. Once I'd convinced myself that a ramping controller was worthwhile, I looked at what was available and settled on the Automation Direct Solo SL4848VR and Omega CN7823. Auber Instruments also have a ramp/soak controller that looks pretty good. It seems popular in the US, but Auber don't have a UK presence which ruled them out for me: I want tech support in my own timezone. 1
