Push dagger WIP
Joshua States
I'm going to step out on a limb here. Typically I don't start a WIP thread until I am far enough into it that I am pretty sure it's going to work out.
This time, I'm just giving it to you as it happens. The idea is to make an integral frame handle from a 3-bar composite. This was the original forging concept.
I have already deviated from that design somewhat.
The W's bars have been replaced with some 1095 bars and I'm probably going to ditch the small "guards" on the back end of the blade.
The blade bars are also much longer than the drawing indicates.
I am still going to split the center bar and wrap it around. I just don't know how to end the bend and make a connection yet.
Here is the initial forging. The center bar is about 17 layers (?) twisted.
These were welded together at the anvil: https://drive.google.com/file/d/1G0yYCIk56tKiDuDM2mHchfQUYwlAR08P/view?usp=drive_link
Then I cut for the bird-mouth weld.
This got closed at the anvil and welded shut in the swage block dish: https://drive.google.com/file/d/1c0cB-_EiyNde5tpNPJKUaZOacwOeQFK_/view?usp=sharing
That was where I left off. Tomorrow I have some forge time and several projects that need doing.
This will be one of them.
  • Like 3
Today's forging exercise
First I fullered the finger loop areas on a 1" double fuller tool.
Then I drew out the body, which will become the frame.
This drawing out will elongate the twisted core and I'll lose the effect of those center of the twist stars. So I took that to 1/2" square.
And twisted it again.
Then I flattend that out to about 3/8" thick and normalized a couple of times.
This is now in the Paragon going through a full annealing.
Tomorrow I need to make a new design drawing, a template, and a mock-up model out of wood.
Not much of an update, but I surface ground the tail, profiled the blade shape, and scribed my edge center lines. The tip needed a little forging back to center (side to side, not edge to edge). Once I got that fixed, I drilled a small hole and split the tail.
Next I need to make a form to shape the handle frame.
Maybe tomorrow or Monday. Maybe next week, IDK.
I'm not one to only post my successes. I also post my abject failures, and this is no exception.
I prepped the split bar by grinding the sides mostly even and made the form.
Then I took a heat and spread the split open.
Wrapped one side.
And wrapped the other side
Hot cut off the excess
Using some clamps and a push rod I tucked the ends in.
Unfortunately, shortly after this phot was taken, It broke.
My fault entirely, I tried to move some cold steel. Just plain dumb.
At least I know this can work, but it will have to wait for another day.
I reached out to retired MS Larry Fuegen to ask him for advice and some pointers. He was very kind and told me about how he made this knife.
So I switched to plan B.
More on that later.
Plan B:
Cut the blade out of a flattened bar of twist
Scribe the outline of the handle on the anvil
Take another piece of flattened twist and make a pretzel
Hot cut the ends and flatten
Verify the form after normalizing. This needed some tweaking to work well.
After adjusting the form and getting it flat via surface grinder, it's time to get it connected to the tang of the blade. I coated one side of each piece with Dykem blue and Scribed lines where to cut material away so that they interlocked.
For this welding op I used the A/O torch and some W1 filler rod.
Welded two points in four places.
And filed the excess down
A little more on the surface grinder and it's ready for H/T.
H/T went really well. It stayed flat and true. resulting hardness is 58-59 HRC.
I have to admit that I don't like plunge daggers but you're craftsmanship is great.
12 hours ago, Alan Longmire said:
Good save!  I would've brazed it with extra-hard silver solder (1700F flow), but OA works!
I thought about brazing, but I really wanted to get this all fit together before HT and I don't hae any of that fancy solder stuff.
Thank you sir.
I really had to sit and think about how to do all the little steps left in this one. Getting them all in the correct order is critical. Only 13 steps left!
Today was choils, bevels, and plunge cuts. I also started the liners and prepping the scale material.
Here are the bevels and plunge shots. Everything gets done in the file jig.
I always appreciate seeing your progress Joshua,
I like the shape of these palm daggers, sadly they are very illegal where I live so making one would be a bit of a waste.
What kind of surface grinder do you use? I'm weighing my options for one in the future.
I went the (relatively) inexpensive route and got a adapter kit for my 2x72 grinder. Mine is from Weurtz Machine Works.
Today was scales and liners day. I drilled the pin holes in the liners and cut them out. Then I surfaced the scales (stabilized karelian birch) drilled the pin holes and cut them out. This is a tricky thing to do because you have to mark each side of the blade and then marke each side of each liner and scale to match with the inside faces also marked. If you get this confused, it will never fit together again. It becomes a puzzle.
Rough cut and fited scales and liners.
Finished out to 400 grit on the profile.
Then, the start of what will be the trickiest part of this build. Notching for the bolster.
Last weekend I had the opportunity to make the bolsters and I cut out two pieces of 1/4" thick nickel-silver plate.
These got glued together and ground to 220 grit on three sides, both short sides being the top & bottom and one long side for general alignment.
I blacken the smooth short side and push it up against the curve they have to fit to. I scribe the curve with a pair of dividers.
Grind that curve and carefully fit it to the scales/liners.
Pick one for side 1 and one for side 2. Glue them in place one at a time and drill for the alignment pins.
Generally, I only go about 0.10" deep as these will get soldered on.
I also mark the curves of the blade stem for stock removal.
After getting them fit smooth to the stem I make tiny alignment pins and glue them to each other so I can grind the bottom curve and taper the bottom end. Here they are fit to the knife. They did get a little fine tuning on the bottom curve after this photo.It's really amazing what a photo shows you that your eye may not
Too late now, and they may not have been selling it when you bought the Weurtz, but Beaumont makes one for a fair bit less: https://beaumontmetalworks.com/product/sga/.
That's what I have.  A dedicated stone wheel surface grinder it ain't, but it'll flatten to +/- 0.0005" if you do your part.
15 hours ago, Joshua States said:
It's really amazing what a photo shows you that your eye may not see.
Or even just better lighting.
I am really impressed with this build!  So much so that I shall be stealing using techniques inspired by this when I finally get around to putting a handle on one I made from a scrap of Cu-Mai I was given...
3 hours ago, feltran said:
Congratulations my friend, you really have talent
I have technical skill, which is slightly different from talent in my way of thinking. :blink:
  • Haha 1
I decided to put vine filework on the handle liners across the top. It's been days of filing and micro adjustments.
When doing opposing sides, the filework should mirror image when the liners are pinned to each other.
That way they look best on the handle
If you zoom in on that second pic, you can relly see the stars in the twist.
  • Like 4
this is fun to watch from black forge scale to refined white metal.....Thanks Josh.....
Well, I finished the filework on the underside of the handle liners.
Some of the black background is missing. I will put that in before final glue up.
Then I soldered the bolsters on.
Now I get to prep liners and scales for epoxy. I need to remove some material in the liners and underside of the handle scales to form epoxy "rivits" to hold everything together.
