My lil' Kriegsmesser
Chad J.
It's been a while since I've posted here but I've been busy.  Mostly working on decorative blacksmithing to pay for tools and propane.  Well my hammer got the best of me recently and I took on my first Kriegsmesser.  This has been the fastest I've forged and  (almost) finished a project.   I have the final edge to do and done polishing.   I like a rougher finish, wire wheel finish on mild steel fittings, and grinding the blade down to a 600 grit before going with a green conditioning belt.  5160 steel, 42 inches long with 31 inch blade,  weight is just around 4 pounds with cog 7 inches in front of the guard.   It has a constant distal taper from point down to the base which is 3/16th inch.  2 inches wide at the base and 1 3/4 inch at the curve to the tip.   Handle is a bit narrow unfortunately but I'm considering ways to add mass to it without having to pull it apart and weld material on.   I just have some fit and finish work to do but overall I'm happy with this... and have started on the next.
  • Like 4
  • 3 weeks later...
Nice one!
