Posted
Hello Everyone
I am in the process of purchasing a LG 25# hammer and I have two sellers I've narrowed it down to. One has a couple available but not currently operating (no motor) that are either early style or transitional. I am going out there this weekend to view in person and wanted to know what common things I should look. I didn't see and obvious welds/brazes on the top portion and everything looks intact with no holes or cracks in the pictures I have so far. I plan to hand check the moving parts actually move or don't as they should and the dies and dovetails for anything major.
The other seller has a new model and it actually runs so is there anything different to check as the ram guide is a different style.
Thanks
Posted
That's one of those things where I'd need to see it in person. Check the clutch. I prefer the wood blocks, some like the fiber cones.  Any welds or brazes are a red flag.  Look at the dies. A 25lb LG can't use combo dies, they're just too small.  Slightly crowned flat dies are what you want.
Sorry to be vague, there's just too many variables...  they're pretty simple machines, as long as the bearings and frames are good.  Ooh, bearings!  Grab the shaft and try to wiggle it. If it can be moved by hand in any direction other than rotating, that's another red flag.  Fixable, but not easy, depending on if it has shims left.  Ideally you could pull the bearing caps to see, but that's not usually something the seller wants to do.
Added brakes are sometimes nice, but on a 25 not necessary. A spring guard is also nice. Very few people have been killed by a broken spring (like maybe less than ten in the last hundred years), but you don't want to be one of the few.
Posted
Thanks Alan.
Yeah I wasn't expecting anything concrete as there is a lot of small variables that you just need to see. Welds/brazes were one of the main things I was looking for and I planned on adding the spring guard. Not only for protection from the spring, but I know the people I share the shop with and wouldn't be surprised if someone almost accidentally leaned too far forward.
I didn't see any brakes on the 3 units I was looking at unless the pictures are at poor angles. I wasn't sure if that was a mod people added or if it was original as I really just haven't seen more than one or two with one even at other sizes.
When you say the bearings are you just referencing if the Babbitt is still good or needs re-poured?
Posted
They didn't come with brakes as an option, they're an aftermarket DIY addition that the 25s don't really need.
And yes, I was talking about the babbitt.  There should be three or four shims between the bearing shells. If there are none, the bearings are worn to the point of needing repouring, or will be very soon. You only see that on hammers that have had serious industrial-level use, though. Babbitt bearings last a very long time in hobby use.
Posted
This may seem obvious, but I'll say it anyway.
On the ones with no motor, make sure the motor mount is attached and is solid. Location is also a consideration. Our 25# LG has the motor mount way down at the bottom. This means it needs really long belts. Not only are these costly, it makes it difficult to adjust the tension because there is so little room to move. Another thing on those without mottors is to spin the flywheel by hand and engage the foot pedal. Make sure the linkage engages and can be adjusted, if needed.
Thanks Joshua.
Yeah both ones I viewed were new pattern so had the mount. I'm still deciding if I add on a new mount for a shorter run or keep as original as possible. Getting a new belt here isn't the worst, but I already saw its not pennies either. I was a bit worried about the tensioning as most online example of running hammers I could find have an added mount and most are running V-belts though saw a couple flats.
I did test the linkage and everything seemed good without disassembling it and the threads still worked for adjusting.
I'm not expecting anyone to look over the pictures but I figured I'd add them as a courtesy.
Edited by Sean Blum
Posted
Ooh, that one has the sow block option!  That's a good thing, especially if you can score another one.  Makes it easier to switch bottom dies or add dedicated tooling.  Don't sweat the motor mount too much, it's remarkably easy to fab one up that bolts between the upper frame members for a short belt.  Here's my Star motor mount, just a bit of plate clamped to the frame.  The center pulley makes it easier than a rear pulley, but you get the idea.
Looks nice Alan.
He had a second one that was almost exactly the same, but was LG green, had 1 or 2 pieces of the ram assembly replaced and had a motor system wired though he said the motor was shot. I decided on the one I posted over the other as it had the crowned flat die instead of the planishing flat die and I would replace the motor electrical anyway so would only get the drive wheel out of it.
I'm picking it up this Sat weather permitting and I have to discipline myself as he has a lot of good anvils and other stuff that my budget would kill me for buying. The only major issue I've found with it is it looks like someone spot welded the sow block to the frame in one place. It looks to be shallow enough I can grind it without to much work, but I cant really see a reason why its welded.
Edited by Sean Blum
Posted
Most likely it wasn't wedged properly and tended to move around on the previous operator.  Or just insurance against moving.
