Dan Hertzson Posted May 21, 2024 Posted May 21, 2024 This is why you need to avoid unproven online material sellers. Been saving this " stabilized " burl for a special project. Cut a slice off two blocks today before drilling for a Wa handle, and glad I did. Here are the results (first shot shows lack of acceptable penetration). 1
Joshua States Posted June 23, 2024 Posted June 23, 2024 Yeah. So many people are claiming to be satbilizing wood these days, and so many of them haven't a clue how to do it properly. A word of advice when purchasing from a new and unknown supplier. Buy just one or two pieces and check them before cutting into them. A fully stabilized piec of wood sinks like a stone in a bucket of water. Any bouyancy at all means the stabilization is not complete. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
dragoncutlery Posted June 29, 2024 Posted June 29, 2024 On 6/22/2024 at 11:42 PM, Joshua States said: Yeah. So many people are claiming to be satbilizing wood these days, and so many of them haven't a clue how to do it properly. A word of advice when purchasing from a new and unknown supplier. Buy just one or two pieces and check them before cutting into them. A fully stabilized piec of wood sinks like a stone in a bucket of water. Any bouyancy at all means the stabilization is not complete. Unfortunately not every type of wood will take enough stabilising resin to sink like a stone but if the color didn't penitrate then most likely neather did the resin Brandon Sawisch bladesmith eagles may soar but weasels don't get sucked in to jet engines
Joshua States Posted June 29, 2024 Posted June 29, 2024 1 hour ago, dragoncutlery said: Unfortunately not every type of wood will take enough stabilising resin to sink like a stone but if the color didn't penitrate then most likely neather did the resin Then don't try stabilizing it. It's already dense enough that it probably doesn't need stabilization. Some woods are already so dense, they cannot be stabilized at all. Ironwood and purpleheart both come to mind. Ironwood doesn't float at all. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
dragoncutlery Posted August 6, 2024 Posted August 6, 2024 On 6/29/2024 at 2:13 PM, Joshua States said: Then don't try stabilizing it. It's already dense enough that it probably doesn't need stabilization. Some woods are already so dense, they cannot be stabilized at all. Ironwood and purpleheart both come to mind. Ironwood doesn't float at all. I feel like we're are having two compleatly difrent conversations here Brandon Sawisch bladesmith eagles may soar but weasels don't get sucked in to jet engines
Joshua States Posted August 7, 2024 Posted August 7, 2024 23 hours ago, dragoncutlery said: I feel like we're are having two compleatly difrent conversations here Possible. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
