Posted
Through a series of circumstances I ended up with a wonderfully mechanical and weird power hammer that I have just started the teardown for a full restoration. The Jenkins and Lingle upright cushioned hammers are in the same realm as Bradley helve hammers but have a bit of extra strangeness to them that I'm excited to get going. From the patent information and old catalogs I'm guessing it's from 1892-1895 but can't be entirely certain. There was another patent in the early 1900s that doesn't apply to this one but info is very scarce.
The frame body is in two pieces and the total machine weight is allegedly around 5800lbs and a 125lb ram. I just broke the ram and guides free of the upper frame so I will weigh the ram and report back on the actual size. It doesn't feel quite heavy enough for 125, so it might be the 100lb in spite of the frame weight being over 5000lbs (the 100lb ram corresponds to a 4300 frame according to a 1889 catalog).
One of the several strange things about the assembly and relating to one of the patents is that the helve does not actually attach to the ram in any mechanical way. The hole in the top of the ram block has two wooden beams sandwiching a metal helve hinge pivot, the free end captures in that square cutout but otherwise free to move. From what I have seen disassembling the helve mechanism, the ram slides in and out slightly as the machine cycles.
Although mostly rotten away the helve beams are bolted to the frame and partially captured by top and bottom brackets. Remaking these should not be much of an ordeal, although the contouring of the inside end has a specific radius to meet the helve pivot tongue (bottom of the timber in the above).
The next big mystery in disassembly is this thing on the back of the helve. For whatever reason most of the patents do not have any info available, whether drawings or written text, in the online archives. Getting it apart this turned out to be a sort of percussive dampener mechanism. The linkage of the helve to the turnbuckle/drive shaft is actually three pieces. The helve beams attach to a pivot that in turn is supported by a yolk (on the right side of the above, held between the two white rubber shocks), but then to a secondary linkage that connects with the turnbuckle. Inside the capsule and tensioned by the two bolts on the top/bottom is a series of rubber cushions that put pressure on the back end of the helve bar. I only just got that whole linkage off the frame so I'll get a better picture of the inside. Essentially the helve dampener acts similar to the rubber springs in a Bradley but a stranger way.
The whole helve assembly is supported by rubber shocks that I will have to remake. They were surprisingly only rotten on the outer 1/4" or so but ended up getting destroyed in the removal process. One thing that I am yet to fully understand is what the yolk/shock tie rod was doing in there. Whether an addition at some point in the hammer's life or original, there were metal plates at the bottom of the lower shocks that seemed to be under tension pushing up on the helve. If that is the case, all of the load of the hammer's stroke would be taken by the connecting rod rather than by the frame, but the drawings do not provide much insight...
Hopefully I only have another day or two of disassembly before everything is apart, then it's on to rebuilding! The things I know I will need to do at a minimum are-
-Rebuild the Helve beams
-Remake the rubber shocks
-Find/fabricate the flat belt drive and idle wheels
-Machine new shock tie rods
-Fabricate a motor mount and find a place to put it
-General cleanup, re-tapping threads, honing pivot bores, etc.
One neat thing I've noticed so far is that most of the bolts are forged then turned between centers. The center marks are still theoretically useable after cleaning, so I should be able to remount them in the lathe with nearly the same precision as when they were made 130 years ago!
Because there is so little info on these machines I figured I would provide what info I can as the restoration goes along.
Cheers!
John
-Nine Worlds Workshop-
Posted
I love these old beasts.  You're a good man for attempting the restoration!  If the guys who do new rubber for Bradleys can't remake the rubber bits, I bet Sunray Polyurethane can.  Assuming they still exist after the flooding, that is.  I don't know if they got hit or not.
Posted
I'll do some digging thanks! From what I've heard a castable urethane is also potentially a solution. Testing the existing rubber it looks like it's around 55 durometer, about the upper end of what castable urethanes can reach. With how the helve sits I don't think it will take a tremendous amount of vibratory load but there are still some mysteries to work out!
Posted
That is a super cool hammer! I have a soft spot for these old mechanicals.
My power hammer has leaf springs instead of an helve, but these are also not attached to the ram. They just ride in a hole in the ram casting.
I assume this keeps the linkage from breaking with a bad hit or stuck ram.
The way I understand your hammer the ''enclosed'' rubber discs provide the snappiness of the helve, a bit of tension on the back end will increase the force of the strikes.
On my hammer adjusting at the back of the helve will have effect on the "stickyness', kneading your steel a bit instead of just striking.
The white rubber dampers around the pivot I think are mainly there to catch vibration.
I guess this hammer was a very expensive model back in the day and when restored well will be super nice to use.
There are no secrets, one just has to ask the right questions.
Posted
Excellent insights, Pieter-Paul.  The reason there is rarely a hard connection between helve/springs and ram on this type of hammer is because to translate the motion of the helve (an arc) into pure vertical (the ram) there has to be some movement.  I've seen it done with a sliding bushing, a shackle, and a set of rollers, but it makes more sense to just let it slide in the ram.  I do bet there was a wear plate of some sort on the wooden helve so it wouldn't wear out.  If that end of the helve was missing, I also bet it was brass or bronze... although cast iron on cast iron is an okay wear surface if kept oiled.  Forensic machine restoration, I love it. B)
Posted
If those rubber shocks are just made up from flat disks, I may be able to help you fabricate them.  However, I wouldn't know how to tell you what material to use.
-Brian
Posted
Fascinating, thanks all! I am (nearly) finished with the deconstruction and finally managed to get the axle that connects the large turnbuckle to the back of the helve, although it was a casualty so I'll have to turn a new one unfortunately. Digging around and comparing to the Bradley rear cushions they seem to be about the same as far as function goes, although fully enclosed rather than the egg shaped ones. They seem to be in great shape, at least the 3/4 or so of them I have unearthed thus far. Taking about 50 readings they seem to be an average of 80 durometer, which is also very similar to the Bradley cushions. If they clean up nicely I will probably keep the ones it came with as they were likely replaced fairly recently compared to the other 4 cylindrical shocks.
The wear plates is a great call Alan! The front half of both helve beams was in fact missing and one of the few things I don't have hard data for. I was curious about how that wood/metal junction would last, and I like the idea of having some bronze in there. I have a small stash of plate bearing bronze I might be able to send through the rolling mill if it's thick enough, otherwise I'll have to source some wider material than I have. Oiling is one thing I decided I am going to improve on the original design. Where the hammer sits is unfortunately an extremely dusty area because wind carries in huge plumes of dust from dumpsters getting emptied nearby and it's a losing battle however frequently I blow it all out. Most of the oil ports are on the stationary part of the machine so I think I can bore out the outer bit of the hole slightly and add an oil zerk fitting or maybe make a handful of lidded oil cups so nothing untoward works its way down the bearing surfaces.
If in fact the cylindrical shocks end up being more of a vibration dampening system rather than a functional redistribution, I think the castable urethane might just work! The ones it came with averaged to about 55-60 durometer, quite a bit softer than the back helve cushion. The stacking flat disks is certainly a prime alternative. Originally hammers from this era allegedly would have used latex so whatever I throw in there is probably a lot stronger/more stable. I have a vaguely sinister plan B to try and do some backyard vulcanizing if I can find the right stuff and the castable doesn't work, although just using unfused disks is probably smarter considering there's already a rod through the core holding them in place. I'm fortunate that the shop I work out of has a water jet so making the rubber disks shouldn't be too bad!
Posted
Taking duromete readings of the cylindrical rubber cushions was a little challenging given the decay, but I took as many as I had flat surfaces to read from and the average was around 55-60, the lowest being closer to 50 and highest at 65-70 near the outside edge. Because I had to cut the bottom cushions out to remove the helve assembly I had access to the entire cross section, and only the outer 1/4" or so was in bad shape. The top pair are still whole and may be able to be used on the bottom if remaking them goes poorly...
Contrary to the decay of the 4 larger rubber springs, the helve dampener rubber was in nearly perfect shape. Instead of a single larger piece they are stacks of 4 disks with the inner and outer having a tiered shape to fit into recesses in the back of the helve/tensioning plate. The readings on these were much more consistent, right around 80 for the 6 pieces I tested across both faces and 10 or so readings per face.
Here is a picture of the deconstructed lower cushion/yoke housing. One of the mysteries yet to be solved is how the hardware interacts with the helve cushions. There was a long rod extending through both the upper and lower cushions, the yoke that holds the helve axle/helve, and these very rusty plates. The majority of the rod is around 3/4" diameter, but the lower few inches that goes down through the frame body is larger with a shoulder that potentially pushes up on the rusty plates, thus compressing the rubber. I don't fully understand why that would be, as it would take the full load of the helve off of the frame and place it on the jam nuts/upper frame plate assembly. Possibly an aftermarket job? Or, potentially a way to compress the rubber cylinders enough to get the thing assembled, then backed off once in place? Originally those plates sat flush on the lower frame and only the squared off bit of the bars projected to the underside of the frame where they can be adjusted with a wrench. Only the very top of the rods were threaded. I think when I remake these I am going to use stainless so they never have to be cut out again due to severe rust binding.
Here are a few pictures of the helve, yoke, and turnbuckle assembly. Allegedly the helve was a forged piece! The rest is most likely cast but it's a fantastic bit of metal.
Getting the axle that connected the rear helve yoke (top of the above picture) to the turnbuckle was the hardest bit of work disassembling thus far. I managed to get it to move about 3/16" but no more, and in the process cracked the top end of the axle. In the end I cut it flush and managed to barely fit it in the press. It used the full stroke of the machine and nearly the full 50T!! It would build pressure, then jump about 1/2" down at a time with a sound like a gunshot. Not to mention that the two pieces weighed about 200lbs so moving it around was in itself challenging. In the end I managed to press it down through one side of the yoke and about half way down the turnbuckle before being able to strike it out with the biggest sledge hammer I have.
Of the last remaning bits to disassemble, getting the sow block off the lower half of the frame is going to require making one of those swinging battering ram style hammers. The bottom die came out without too much trouble and the key might be useable (my least favorite part about making things for power hammers). Hard to tell before cleaning but I think most of the variation in the upper dovetail is old grease packed in there. There was a shim in there too but only about 3/4 of the length of of the key which is strange. Possibly that the rest is entombed in that grease somewhere.
Final bit for now is some neat machining on the cam shaft. There's a radius tapered key for the flywheel with a cutout on the outside end so a cap can bolt on over it. For some reason there are also threads on the L shape going in only 1/2" or so. Before I got it out I thought it might be one of those two part keys that is held together with a bolt, but not so. Possibly it was used at one time to remove the key or break the tension on it by way of a wrench and some washers to pull on it, but there is no sign of the bolt that was in there other than that it is the same thread size as the one holding on the cap.
On the other side of the flywheel was this cool shaft collar. Most of the collars I have seen are either a spring collar like the stop on a flypress, or a symmetric two part that has a bolt on both sides. This one rotates into place around the shaft, that lower bolt connecting the two halves, then that smaller bolt on the left side holds the collar to the shaft. They don't make them like they used to!
Hopefully tomorrow I can get the rest of the cam shaft disassembled, the top die out of the ram, and the sow block off the frame. Then it's on to the actual restoration!
Posted
Thanks for sharing the process.
One should keep in mind,
we are all both the blacksmith
and iron in the fire...
as always
peace and love
billyO
Posted
Hopefully someone with a similar hammer finds this someday! I managed to get the rest of the cam linkage fully apart today, leaving only the key for the top die and the sow block. The ram die is about half way out but the limit of what I can fit under the press and hammering does nothing. I need to remake the key anyway to I might cut it where the die meets the ram and try driving it back the other direction. What a pain! Unfortunately the sow block won't have any special tricks to get the key out so brute force must prevail. As I get closer to having everything apart, each piece left takes an order of magnitude longer to unpair!
Posted
That's kinda what we want, right?
The closer you get to the foundation of the machine, the more solid you want it, and it sounds like you've already removed anything that was supposed to move, which means that what's left isn't supposed to move...
Thanks for sharing, I wish I was around to help and watch.
as always
peace and love
billyO
Posted
An extra hand or two wouldn't have been amiss! Luckily I was able to find some help for the last few bits. It took most of the day but I got the final two keys out today! The one in the ram for the top die was a casualty and I'll have to remake it, but the sow block came out in one piece mostly due to its size.
Anyone happen to know what sort of material is appropriate for die keys? It seemed like the one that got destroyed was only mild steel. Maybe some unhardened 4140 would work? I have quite a bit of large round stock that I could make something out of no problem, and since I have to machine a new pivot for the linkage and a few replacement bolts, it wouldn't be much of an issue to cut an extra piece for a wedge.
Tomorrow I finally get into the rebuild! As with the teardown I'm going to start with the easiest stuff mostly so I can clean up the enormous pile of parts that's everywhere at the moment. I have a small sand blasting cabinet, 5 gal of evaporust, some bore hones, drill mounted wire bottle brushes, and coming in a few days some low gloss farm machine paint. I would love to get the entire frame cleaned and painted first but the reality is a little grim on that timeline. Especially trying to figure out a way to paint without dust covering it while it dries...
Posted
Busy last few days, the final bits are free (with one exception) and the cleanup has commenced! I tried sand blasting but for whatever reason the old grease is impervious to the media. Rust disappears, but the black goo isn't touched. So instead I turned to wire wheeling everything and may go back to the blaster if it looks necessary. Here are the last few pictures of the interesting bits as they came off.
This is the eccentric cam mechanism, a rather fine solution to an adjustable throw as the cam shaft rotates. The centre bit is rotated about the top bolt hole, forcing the shaft out from being coaxial, then the bottom bolt tightened to lock the whole mechanism in place. One of the two bolts was missing, although it might be in the bag of loose assorted extra bits that was stapled to the pallet. If not, I'll make a new one along with the handful of others that were too heavily corroded or worn to be put back into service.
The cam/turnbuckle junction is a two part collar that bolts over the eccentric wheel. One of the mysteries was what the bearing surface would be, and after cleaning this piece I discovered that it is cast with babbitt or something similar. It was covered in a layer of rust from the cam wheel and when I went to wire wheel it (see how rounded over the corners are where the oil X grooves are) the material just disappeared. I stopped immediately realizing what was going on and hand brushed it. I will go back with a brass brush or scotchbrite to remove the last bits of rust, then clean the wheel. Using some sort of layout fluid I want to see if the babbitt is actually riding the wheel or if it is the two parallel shoulders rubbing instead. It looks like it's in great shape so I really do not want to have to repour it!
Getting the turnbuckle apart was both very challenging and very easy. I picked up a $22 harbor freight 3' pipe wrench, then added another 4' tube for leaverage. It came right apart, but finding something sturdy enough to take the load was less simple. It weighs around 75lb and at the clamping points is 3-4" wide depending on the part, and my post vice is not bolted down so even with the combined weight it just walked around. In the end I got it loosened, and once the initial tension was free I was able to turn it by hand the rest of the way.
The only damage to the assembly was the bottom section of where the threads engage the cam bearing yoke. I'm not entirely certain but I think this might extend through the bottom of the internal threads by at least half that section, so I may leave it. Otherwise it'll be either brazing new threads on and filing them to shape or remaking the whole linkage. As with the other smaller turnbuckle for the treadle, I would prefer to not have to turn the left handed threads especially on such a large bar with diametral threads.
This beast was the worst part of the whole disassembly and will require a new key. The ram and die together weigh 125lb with a very imbalanced centre of gravity. It ended up back in the hydraulic press first to offset the die by the max throw of the press ram, which was about half of the length of the die. I hoped that moving the die opposite the wedge of the key would simply loosen the die and the key fall out, but no luck. I took it back out, cut the key as low as I could, then put it back in the press with spacers under the die to prevent it from moving as I used the press to instead move the wedge incrementally down. For whatever reason, it took the thing being forced completely out before any of the tension was released. I have a phone picture I'll have to pull up of the rig getting this thing in the press. True shenanigans.
Getting the sow block/frame key out was challenging but ended up without catastrophe. First I tried a makeshift swing hammer made from a sledge hammer head fitted into a 1/2" wall heavy tube, with a 2"+ bar of 4140 sleeved inside, held together with clamps and a ratchet strap. It was about 100lb more or less and didn't get the key to budge even swinging it as hard as was safe. So instead I made this frame out of heavy wall tube and put my welding skills to the test.
It slung over the frame and braced on the back side, a 20T bottle jack pressing on the key with its foot on the bottom of the square frame where there are 3 rows of tube. I have another harrowing phone picture of this operation in action, but I ended up having a friend hit the large end of the key with a sledge gently up and down to try and jar it free as I increased the jack pressure. I thought it was not going to work but then miraculously it jumped about 1mm out, then it was easy from there. Had it not worked, I would have inadvisably gotten a 30T jack instead and really seen how the welds held up.
The only piece of the puzzle left together is this non-keyed dovetail in the bottom of the sow block. It looks like those centre marks on the right side are there to put tension in the material and hold it in place, but I see no reason to even try to get this apart. Just above that are some holes that I used for a makeshift pair of handling tongs in the engine hoist to pick it up the same way it was 130 years ago. I was a little worried that the 1/2" bar I used would be too small, but it worked a dream.
The horizontal swing once it cleared the frame was terrifying, the whole winch sagging under the sudden weight change. I/m guessing but I think the sow block is in the range of 300lb.
Into the actual cleanup, I discovered the top die had the markings H9  13 on it, the 9 seemingly added at a different time based on the cut. Whether that means it is H13/H9 I can only guess. Either way I am only dressing the damage and cleaning the face a little before putting it back into use.
The easiest casualty of the disassembly to repair was one of the top blocks holding in the 4 cylindrical cushions. I had to cut it off on both ends because of how entrenched the rust held it, and my first plan was to drill it out and rebore the hole. Fortunately the no8 flypress was just able to get it to budge using another piece of the same rod as a punch die.
The first day of de-rusting yielded this pile of somewhat more clean metal. I think I am going to drop most of it in the evaporust before painting, possibly sand blasting first but to be determined. The wire wheel did a great job at blasting off the surface rust, the needle descaler for heavier, more corroded bits. The only surprise I found was one of the ram guides is a bit more corroded than I would like for a bearing surface so I may toss it on the surface grinder if I can figure out a way to position it. The 45* faces are opposite a relief cut into it so it can straddle the frame, so accurate workholding it going to be a challenge. Although there is a very slight shoulder on that face I may try honing it by hand first just as a test.
Finally is this thing. It was attached to the top of cam shaft yoke collar that has the babbitt in it. It has a through hole and the cap is sprung closed, in the top picture I have it rotated out of alignment but the toothing pattern registers nicely even with the corrosion. It seems to be packed with grease, but is that what is supposed to be in there? Is grease a normal thing to use with a babbitt bearing? I assumed that the whole machine should be using oil but that may be erronious. Never seen one of these things before so if anyone knows what it is, I'd love to hear it!
The next few days I will be whittling my way through the pile of rust and by early next week I should be able to start painting. For all the female threads I have taps coming to chase the threads although they are all visually in good shape. It'll be one of the last operations before reassembly so any paint or other debris should be well clear of the holes. Machining will be the fun part, so most of that will come later when morale needs a boost!
  • Like 3
Posted
It certainly looks like a type of grease cup. However, I can't figure out how it would work...  The usual way is a cap that unscrews so you can fill the cup with grease, and then rotating the cap slowly squeezes the grease into the mechanism it's supposed to be lubricating.  This look like a simple compression cap that does not act to squeeze the grease anywhere?
Machines of this period usually did use oilers, relying on total loss to flush dust from the bearing surfaces, but some heavy machines like locomotives (and apparently over-engineered power hammers!) used grease cups on the babbitt bearings.  Of course, they also used several different viscosities of oils. 130-weight gear oil is almost a grease!  And some grease is thinner than others.  I've seen instructions for lathes of the period that call for three different oils and two kinds of grease, so it wouldn't surprise me if this hammer did as well.
Posted
Nice job on getting all that apart! I still want to do the same with my own hammer to re-paint it one day.
I would not be too quick with grinding the ram guides, the bearing surfaces on a hammer are different from machine tools and perfect contact is not needed.
The mystery item is indeed a grease cup, although the design of it is a bit strange, maybe the spring on the bottom keeps even pressure on the grease.
My hammer has 6 of the threaded  grease cups, and also a few oil cups and holes.
The grease cups are really nice, I just tighten them a quarter turn every so often, the oil cups I fill every time i use the hammer.
Funny enough the hammer is the only machine I ever bought that didn't have grease in the wrong place.
I think it is farmers wisdom to fill everything with the cheapest nastiest grease available.:rolleyes:
My south bend lathe was advertised with a ''broken'' gearbox, turned out I just had to clean out about two pounds of crusty grease and it runs like new now.
  • Haha 2
Posted
Great to know! The cup is indeed rather strange. The indexable tooth pattern on the bottom doesn't have much in the way of feeding grease downstream but it's so crusty in there that the actual mechanics are a mystery! I may replace it with something I understand. Good to know about the ram guides too. One is in great shape but one has seen better days. Through the disassembly process it has felt like one side of the machine was significantly more corroded than the other. Not that it was lying on its side, but maybe half out of a covering? Strange thing is the frame body is almost perfect but that may be due to it being cast iron rather than something lower carbon. Inside the back plates that support the 4 cylindrical cushions, one was heavily pitted in spite of the surrounding bits being perfectly clean.
On another note, does anyone have any recommendations on things to put on the threaded parts to keep them from corroding and becoming a nightmare for someone else in 100 years? Is anti-seize meant for that or is it more of a thing to prevent galling? Maybe a heavy dose of some sort of corrosion resistant oil?
Posted
I'd be wary of putting an anti-friction coating on threaded fasteners on a vibrating object.  They have a way of working themselves loose over time even without slippery stuff applied.  That said, anti-seize would be a good choice.  If in time you find it makes the bolts back out or loosens the nuts, you can add a bit of period tech and use castellated nuts and cotter pins on the bolts.  That was standard practice until the lock washer was invented.  Plus they look cool... B)
Posted
Castle nuts are the best!! I'm learning that with a lot of this old equipment there are a lot of pre-checks that need to be done so I'll be adding a quick nut/bolt/thread check to the list!
More for my own memory so I don't forget, but from what I can find the most appropriate general lubrication will be either Vectra no4 or DTE heavy medium. TBD on how fast the eccentric will be rotating, but out of an old steam engine manual it suggests that anything over 150 RPM with babbitt, grease no longer removes heat sufficiently so it needs to be an oil as things spin faster. Also based on how the eccentric collar is put together, I may see if the babbitt is cast in such a way that the bottom of the collar has a recess for a reservoir. I only cleaned up the top half so more investigation is needed, but general practice seems to be to have a small groove or some such in systems where 100% loss is not the intended design. However, the side walls may act the same way if in fact it is smooth down there. The top half did have some X grooves cut into the babbitt for lubrication pathing, the bottom likely a similar story once I get into it.
Posted
Last bit of debauching for the weekend, the unreasonable solutions to old rust. Thankfully nothing catastrophic happened in spite of dubious expectations! For how much it has done and not ended terribly, I highly recommend the electric winch bolted to an engine hoist routine.
Posted
First day machining new parts today! The order of operations has shifted from my original plan due to lead times on a handful of supplies, so this was the next 'self contained' project to dive into that I had everything on hand to make. This bar is the axle that joins the cam shaft turnbuckle with the back of the helve. To get the original one out, it ended up suffering too much damage to be reused, so here we are! I took a few liberties with this one based on the stock size I had to start with, so instead of the old one having two holes on the ends for pins, I decided to make a large 'bolt' instead. This way I can control the tension on the linkage, making the pivot rotate around the turnbuckle instead of the helve (like the old parts) without having to resort to another press fit on the helve. This was a bit of a trial due to the machine limitations, but the end result is a great sliding fit with the helve bar.
First up, as always, is to try and get as much data out of the old one as possible. Taking as many readings as I could find a clean spot to indicate from, I came up with an average diameter for my target number that was just below 1.8". Some spots were closer to 1.7, others 1.85, so the wear patterns caused it to be a little out of round. The other pivot axle within the helve has substantially more deterioration, visible very clearly through the corrosion, so that may end up being remade too.
This is the starting stock, obviously much larger than the original. The excess will become the bolt head, and extra length the corresponding nut.
First off, I took a few shallow cuts to get through the mill scale to clean metal. Now I was able to sweep an indicator along the length of what will be the final shaft length and measure for runout. Going in, I knew this would be problematic, as there is a noticeable deflection in the bed due to twist that could be theoretically levelled out but has never been adjusted. This process took the better part of two hours, using the tailstock instead to try and reduce any deflection by inducing a taper. Long story short, the lowest I was able to get it was still not spectacular so I ended up freehand turning a very slight counter taper using the compound, the final result being +/- .003 which is considerably more than I would have liked. Ideally it would be within .001", the machine accuracy being theoretically .0005". If I knew I had the precision I could work to, I would have instead taken all the readings with a bore gauge off of the helve and turnbuckle after running a bore hone through them, but in the end I think this will be ok. Worst case I'll bite the bullet and take another day to level the lathe to get out the twist, then readjust the tailstock, but due to a set of extenuating circumstances that will likely not be possible.
Turned down to the final diameter, the remainder of the parent bar no longer looks outrageously oversized. This picture was after a pass at 120#, then I followed it up to 600#.
The last feature of this round is to turn threads on the free end. To make better use of the other end for the matching nut, I turned down the end farther to 1.5" then took a test pass to check the threads are cutting properly. In a perfect world I would have used diametral threads because of the diameter, making a cutter ground out of high speed steel. However, because I also have to cut the internal threads, that becomes more of an ordeal. The boring bar I have accepts the standard 60* single point thread cutters, meaning I settled for these. If it ends up not working as designed I can easily recut threads at a smaller diameter or simply bail on the threads altogether and just use a pin. According to the Machinerys Handbook the standard coarse thread pitch is 6 at 1.5" diameter, which looked far too wide for this, and the fine pitch at 12tip. 12 looked a lot better so I went with it.
Once the threads were cut I went over to the mill and tossed it into the dividing head. Typically a tailstock would support the free end, but it was easier to use the dividing head only as an angle gauge and do all the workholding like normal in the vice. Another option for this would be a collet block if such a monsterous set exists that can hold a bar this large, which I may do for the smaller bolts. Part of me wants to leave the heads forged hexagonal like the originals if the tolerance is close enough to fit in the 3 jaw lathe chuck. Of note, that scored line is where I will part off the nut section. I figured it was easiest to mill everything at once, then finish off the nut after the fact.
Which is what I did! Pilot drilling up to my largest bit allowed me to come in with the boring bar and begin to open the hole for threading. A feature I added, which ended up being potentially detrimental and cause me to remake this nut later, is on the bolt section the full diameter extends a slight bit beyond the span of the helve piece so none of the threaded area is inside the machine body. Whether or not that will matter in operation, I have no idea, but to account for this I added a shoulder to the nut that is a slip fit to the axle diameter. That way the nut can extend past the threaded rod section and close down on the helve. However, I could not check the fit of everything until I dismounted it from the lathe and it's not quite what I want. Putting it back in a 3 jaw chuck (I don't have a 4 jaw unfortunately) will almost never have it be in the same position as before, so getting the additional depth I need and having it be concentric with the threads is unlikely.
Anyway, here's the setup for thread cutting. Whenever I cut internal threads, I prefer to have the carriage running away from the spindle so prevent any possibility of crashing into the chuck. Mostly it's an issue for blind holes but it's a habit I got into so I keep with it. This means that the tool needs to be on the opposite side of 'normal' because the lathe needs to run backwards for the feed to reverse. It feels weird the first time but now I actually like it because of how much more visible the tool is while cutting.
And there are the threads and extra recessed area for the nut to travel.
Before removing anything from a fixture I check every possible thing I can think of, because as I mentioned it's almost impossible to get things back in place accurately with what I'm working on. There's a mile of extra thread but that's easy to trim once I know how everything will interact.
And there we have it! Aside from potentially having to remake the nut, everything turned out perfectly. The final question I have is what to do about potentially heat treating it. Because it is fully annealed at the moment, I know I need to do something, just not exactly what. At the least I am going to normalize a few times with a healthy dose of anti scale, but I may harden and temper at a high temperature to get a little more abrasion resistance out of it.
Anyone out there made axles like this before? Or generally made linkages? The original was certainly harder than annealed, as it cracked around the hole for the pins when I was removing it. I'll take a hardness reading of it when I remember just to see what might be going on. Also a spark test, but when I was cutting it down to get past the cracks for further extraction, it seemed to be higher carbon than mild.
Next up, depending on the arrival of materials, brazing the few things that need that repair, getting primer on the first parts, or forging out some hexagonal stock to remake the handful of bolts that need replacing.
Posted
Managed to get the first bit of forging done for the new parts, mostly breaking down the larger diameter 4140 to the hexagonal blank of the bolts that are missing/damaged. I'll have to go back and forge another section at a larger size to make another set of jam nuts and one bolt for the cam linkage that has a larger head than these.
Working stock this size always surprises me by how long it takes to get hot. Somewhere around 12lb and it was about 40min before I was ready to forge.
If I were to do this again I would make a set of dies for the press. Reducing large stock all but requires taking the round, forging to square, then trying to get a regular hexagon out of it. That final transformation was challenging due to the tendency to have to pinched corners and four obtuse. In the end it was very close and probably closer than the heads of the old bolts that were on the hammer to begin with. I thought it was neat to be able to reproduce the missing hardware using the exact same methods as 130 years ago!
These two bolts will be for the eccentric cam adjustment lock. The one above is what came in it, the second missing altogether. It's in rough but probably serviceable shape, so I just remade them both. My original plan was to make the cam/turnbuckle linkage bolt out of the same stock but it's too small a cross-section.
By way of single point threading, I made these the exact same way as the larger axle bolt a few days ago. Fortunately the dimensions are far less important here. Although the bolts are the same size as the originals, I am not entirely happy with how small the shoulder is where the shank transitions to the head. I may end up making or finding large washers of a close fitting size to use between the bolt and eccentric locks.
I'll drill the cross hole for the pin later. I think there is another bolt of a different thread pitch but similar size that was also missing, so I'm saving the last bit of the bar for that when the time comes.
While I was in the forge, I also made another blank for the axle bolt nut. From the forging process it's a larger size hexagon and also a little deeper than the other one I machined. This will allow me to have a deeper recess to thread over the full shaft diameter. I decided I'm also going to put in some bronze washers so it doesn't wear anything away prematurely.
Today I also started the first bit into the painting process. These shaft bearing blocks have (somewhat unintentionally) been sitting in evaporust for the better part of the week so I took them out, scrubbed them off, and hit them with a rust inhibiting primer. For the remainder of the larger parts I am going to clean out all the bores and threaded holes prior to painting, but I've found that the fresh surface tends to flash rust fairly quickly and did not want to leave it for tomorrow.
On the lower block half, hammer right, the little locating tab was severely cracked. To be honest I have no idea how it was still attached, as the crack was very deep on all sides. I tried tig brazing, and never having done that before the results were mediocre at best. Given the feature is non-structural in any way, it would have likely been fine without doing anything to it, so surely this is worst case the same as before.
Poking away at cleaning and derusting, I prepared the sow block today and found a few surprises. Under where the die sits, the center has a fairly severe pocked corroded or worn into it. It's hard to tell from the picture, but that center 1/3 or so where it's extra textured goes down about 1/4". I may try and mill it flat given how much other damage there is to the bottom face, also potentially reface the top where the die has bitten in fairly severely.  If the mill can take the height needed to cut it, I'll probably at least try.
Underneath I was given a glimpse of how the dovetail section was affixed. The two bolts/pins/rivets/?? are what keep it from sliding out. Good thing I didn't try to disassemble it before cleaning! It'll stay where it is of course, but how it's mechanically fastened I can only guess.
I also cleaned and primed the ram. It may need a bit of machining too, although I hate to do that given its relatively good condition. As I stockpile parts to paint, things finally feel like they're moving in the right direction! As I debate what to do about the two frame halves, I'm going to clean and prepare as many of the larger sections while the smaller stuff sits in the evaporust.
As I work through the big bits, I've found that there is a strange coating on a lot of it that may either be old paint with horrible additives, ancient caked on grease, or something less savory. Without the powered air respirator it would be a huge mess to deal with. My current strategy is to take off everything I can with the needle de-scaler, then wire wheel, then a little scotchbrite pad on a die grinder. Doing this to the ram took about an hour and change which isn't too bad in the grand scheme of things. There are 7 or 8 larger parts that need the treatment, plus a host of things like the shafts and axles that are only getting gentle treatment, so all in all not terrible!
Posted
No, but I knew a guy who worked in a plant that made axles for heavy equipment.  They used 4140 and scanning induction coils to basically case-harden it.  That bolt is thick enough you could probably get that effect by oil quenching the second it showed the right color on the surface.  Or you could make a scanning induction hardener out of an induction forge with a coolant mist... :lol:
Posted
I've made a few large custom bolts before for some machinery restoration projects, but I have never forged the hex stock to start with.  Bravo!
-Brian
Posted
I also heard about the induction hardening, which I might actually be able to pull off. I have a small induction forge and this is around the max size I can work. It would definitely be a more haphazard approach but I have hardened tooling with it in the past and nothing catastrophic happened. The biggest concern about using the kiln is how long it would take to get to temp and the amount of decarb even with antiscale. If it doesn't end up working worst case I can make another! The way the induction forge works for me with larger material, the outside gets hotter faster so for a non-through hardening operation that sounds like an inadvertent perk.
Posted
If you have control over the frequency of the induction forge, higher frequency will penetrate more shallowly than lower frequency.  So, crank it up for surface hardening.
