John Page Posted April 16 Author Posted April 16 Thanks! We're about to get to the good stuff! The puzzle of the drive wheel has been kicking around the engineering and tool making side of my brain for a while now and, although it may or may not be the best (easiest) solution to the problem, the following saga is what I came up with- Before even touching the hoop I rolled so long ago, I first needed to come up with a circular pattern from which the entire operation references. Using a scrap bit of plywood, the router base screwed to it, plunged through with a drill bit that fit in the collet, then used a beam compass/trammel points to scribe the radius of the wheel. This sort of simple router circle cutting jig is just a screw through that scribed arc segment which then turns into a pivot. Through a series of plunges, first one circle then a second comes free. Because the depth of the hoop is quite severe in relation to the thickness of the template, I used some bits of lumber as a standoff. Laying out the position of the three outer bits and the inner blocking is more critical to the process than you might expect due to what comes next. With that first circle inside, I was able to mark and cut the excess off the hoop. Originally, I rolled about 1.25x the circumference so the flat sections at the ends of the roll could be removed and a clean perimiter leftover. After screwing in the second circle template and some creative clamping, you can see the slight gap leftover which allows for easier weld penetration without chamfering the awkward to reach edge. Some little bit of welding and grinding later and the surface is nice and flat. Due to the rolled circle being slightly smaller than the final size, the very ends of the band come inward ever so slightly because the end sections are the least flexible. Imagine the entire band is like a spring. To deflect just the ends is trying to effectively cold bend the 3/16" stock over its full width which is not going to happen without serious persuasion and causing more damage than it fixes. In the end, it's so slight that I did not worry about it. Perhaps the most harrowing bit of this whole excursion was grinding in the crown to the outer face. I do not have a gap bed lathe to machine it in like would be the sensible solution. So instead I was forced to improvise and call in the reason for all the blocking in the middle of the template. Carefully laying out the centre of the hoop and mounting a faceplate to it with a handful of suitably long screws, it was ready to mount on the wood lathe. Running at a leisurely 250 or so RPM, the motor acted more as a brake than a power source. The rotational force imparted by the grinder would have it spinning far too fast for comfort. Even with the 7" grinder and a variety of the coarsest abrasives I could find, it took the better part of an afternoon to work down both sides. It's hard to read in the picture, but in theory the crown only needs to be 1* or so for it to make a belt track to the middle of the face. In spite of the width it was still difficult to measure accurately but based on several measurements the final grind came in around 2* or so which is great. Safely off the lathe, I could take out the second circle template and blocking to begin sorting out the spokes. With the beam compass, dividers, and rule, I could plot out sets of 6 divisions around the circle which will represent the spoke pattern. To help balance the rim and allow for differential tension to thereby make the rim coaxial to the hub, there will be two sets of six spokes, one towards each edge of the rim face. This design is loosely inspired by some of the equipment I have seen and although of no particular vintage is probably later than the 1890s that the machine represents. The original would have been a single solid cast piece but I do not have that capability and with the far more limited compliment of machine tools at my disposal compared to when I started, this was still pushing the limits of viability. 1 Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted April 16 Author Posted April 16 Along with the full hoop, I also had the foresight to roll the entire extra length of the material which equated to a 2/3 circumference less the flats at the ends. Up until the final moment of assembly, I was still debating internally on whether to make this a split hoop like a lot of the lineshaft wheels are. It allows them to be assembled over a shaft without needing to slide over the end. The extra banding I rolled would have been cut in half and used as lap plates that are half rivited, half bolted. The reason for wanting to do this was more in the utility of how the wheel clamps around the shaft rather than in the captured shaft assembly. That interface with the shaft keyway is yet to be reckoned... What I did end up using it for was to make a series of plates through which the spokes attach, then the rim to the plates. Some designs forego these altogether but I was nowhere near confident enough in my design and assumption that I could also execute it flawlessly the first time. Especially because I am not able to make another rim, so it needed to work the first time. Turning down a bit of scrap from when I forged the replacement bolts, this little flypress tool formed a swage into which I sank the face of the plate segments. I had a different tool of a similar design but slightly smaller to use as the actual top tool since the thickness of the material itself needs to be accounted for. That little nub on the end of the punch is for alignment to cenre the swage. Because the working punch is a smaller diameter, alignment by eye is tricky especially with the limited visibility around the tool. The setup looks a little makeshift in the flypress but it worked almost perfectly. The only slight issue was the plates were not all exactly the same size. One was about 1/16" wider and another about 1/32" shorter. Ordinarily on something of this scale that is unimportant for hotwork but when jigs come into play it offsets dimensions asymmetrically. The toe clamp on the right side not only holds the swage down but also serves as an end stop so the inset of the punch is always the same. On the back side and held down by the rectangular plate on the left, another plate serves as a depth stop so the punch is centred on the long axis of the plate. This is what ended up being slightly out of position and since I drilled the holes before the hot work, the two offenders were a little crosseyed. Either way, it worked out fine and this setup worked far better than doing it freehand. Since the plates have the matching curve to the full hoop, the distortion to that fairly critical geometry needed correction. Using the last bit of leftover rolled rim, I used another tool in the flypress to sink back into the proper curve. The tool is a hollow, heavy wall cylinder that I use to sink large ball bearings into copper but the inner diameter was just about perfect to fit over the feature swaged under the larger flypress. Because most of the distortion happens around the punch, all the correction needs to happen there too. With the residual heat after the first operation it only took a few gentle hits to bring the plate back into shape. If none of that makes sense, this is what it looked like after the first round. Same thing on the other hole and those will be where the spoke ends will seat. To terminate the spokes, I forged a very short upset on the end of the bars using a pair of fullered jaws to better grip the bar and prevent galling. On the other side of the vice I stacked spacers to keep the jaws parallel. The bars were just slightly too long to grip centred because of the screw interfering but having that as an upsetting block to eliminate slipping is nice when it works out. By the end of the lot, the upsets were looking better. Had I been able to excavate more round stock from the pile without moving a few thousand pounds, I would have remade a few of the longer tapers because of how they need to interface with the plates. This is what the assembly looks like to a degree. The final fitment has the free ends (hub side) closer together to form shallow triangle. This gives me more flexibility in how the whole thing adjusts during the final assembly. Parallel rods, while a viable design, would make it more difficult to force the rim into its coaxial and concentric alignment. All six pairs test fit in place and its starting to look like a wheel! Making the hub stalled me for a few days debating on what to use. I thought about solid bar and quickly abandoned it for how large of a hole I would need to bore in it. Next up was rolling my own tube in two sections and going with the split wheel design. Indeed, the six pairs of spokes was in part with this in mind. Having an odd number of spoke pairs would be easier to adjust in that the force of one side would not be in direct opposition to its mating pair. I decided against this too for the challenge of keeping the half rounds free of torsional distortion and my inability to machine the two mating long edges. In the end, I settled on this bit of large pipe. It is a bit bigger than I would have liked and therefore the reason why I did not go with this first. The eccentric drive axle which this will go on is 2.5" while the inner diameter of the pipe is 4". Not a tremendous difference considering the keyway also takes up another half inch or so on one side of the shaft. But that is still very oversized. The reason I ultimately went with this is mostly because I already had it on hand and it is vaguely reminiscent of what is done on the other wooden lineshaft pulleys I have. Those are split design and have (or will have, another thing to make later) a split wooden spacer piece that goes between pulley and shaft. This is, as I understand it, so that the pulleys can go on any size shafting and only a new core spacer needs to be swapped in. I'll do the same sort of thing with this and also use the split in the core as a way to grip the keyway. The reason for risking mounting this on the lathe was to square one face. Off the saw, it was close to square but not close enough for how much I thought would be referencing off it in the fitting of the spokes. Realistically, close would have been fine because it all got measured and adjusted a few hundred times anyway. This setup, however, made it worth doing. Into the dividing head it went. Slightly worse the wear with surface rust for how it had been stored the last year, that cosmetic horror did nothing against its functionality. After a good bit of speculative maths, I set the spacing for the two rings of holes to be drilled in the pipe. This could certainly be done with careful layout but this was easier and harder to get wrong. Besides, the holes were all drilled slightly oversized due to the angle of entrance from the spokes so as long as it was close, it would be close enough. With it all sitting in place, albeit the height being off because of the template interfering with the pipe, it really is shaping up. Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted April 16 Author Posted April 16 To rectify that spacing issue, it was back to the flycutter to cut a through hole. Fortunately, and another reason I spent so much time making the wooden core template, the exact centre of the circle was already marked and piloted. Cutter flipped back around to leave a clean edge on the wood outside the circle (rather than the inside of the cut kerf like I needed for the rubber disks) and it was a bit of a rodeo to manage with a handheld drill. Going from both sides and cleaning out the rag in the middle with a file, and the fit was tight enough that it took a few hits with a deadblow mallet to seat. Before any more assembly could happen, I threaded the ends of all the spokes. This is where the critical bit of design came into effect. Adjustability in concentricity of the hub to the rim, coaxial tilt so it runs without wobbling, and ultimately tensioning the rim to force it into round or out of oval all has to be done in a way that it is not permanent until the last second. Threading the spokes seemed to solve all those issues at once, and paired with the template it should need only minimal tuning. Most of the reason for dishing the spoke plates with such a large countersink is so that the entire upset head of the spoke can rotate in place even with the plate tight against the rim. Until it was all together, I really had no good way to test if my geometry would work but the theory and a few test pieces checked out. Instead of trying to thread all 12 holes at whatever angle they needed to be, I opted to weld nuts to the hub with everything in its correct relative position. The hub tube dropped through the template and spaced off the table by the amount needed to centre it on where the rim plates sat on the top face of the template. By clamping the plates in place it forced the spokes into angular position and the nuts backed off to give tension to the length of the spoke ensured they were tight to the rim. I really wanted to figure something else out to not have so many visible welds, but every other option was too convoluted. Ugly as they are, a hefty bit of filing to give a more even fillet left it looking fine enough that the end coat of paint will disguise how it was made. Getting it apart made me immediately regret not forging in a wrench flat on each of the spokes. Vice grips etc. got it apart but the hand cut threads were eccentric enough that some of them fought me quite a bit. So after it was apart, I marked every piece with a number on the plate, hub, and bar, plus an indicator of top or bottom spoke. That way reassembling would not lead me into any red herrings with fitment issues. The guillotine tool I made for the flypress does not get used all that often, but when it does I am immensely glad I went through the trouble to make it. The flat dies were the perfect width to fit an open ended wrench and the stop collar set the depth so I would not over forge them. Now that the spokes are fully finished and the hub ground and filed, the only thing left to do in assembly was to drill the holes in the spoke plates and transfer those holes to the rim. It was a sort of a moment of reckoning to transfer the holes to the rim. Before taking out the template piece, I marked the six divisions on the inside of the rim so I could align the swaged holes in the plates with them. Then, clamped in place, I traced the fresh holes in the plates with a scribe to the inside of the rim, then with a transfer punch marked the centre as exactly as possible. Drilling into this was the single most important thing to not do wrong, as it would mean having to plug weld and regrind the whole thing to fix any mistakes. Fortunately, test fitting the empty plates worked a treat. I oversized the holes in the rim by 1/32" to account for the angle change between plates and rim plus a bit of tolerance for things never being perfect. In the end, this will (probably) get a deep countersink on the face of the rim and riveted else possibly countersunk bolts. Being able to hot rivet it all tight and file flush sounds like a better option but more chances for failure. To fit the contraption together, I first threaded all the plate/spoke assemblies as far into the hub as the threads allowed. That way the rim slides over without interference and I could selectively back out the spokes to centre the hub. This took an unfortunate amount of time. It was a constant back and forth to shift the band relative to the hub, tension places to maintain round and loosen others to slacken the oval. The heads of the spokes did a wonderful job of pushing against the rim while the plates when tightened pulled back. Being able to adjust the top and bottom spoke independently kept everything square and coaxial to the best of what I could measure. Until I make the core spacer and mount it, I won't truly know how good a job I did, but until then I am satisfied that it is as good as I could make it. Before riveting, I am going to get it to spin for extra validation and make any final adjustments before running a belt to it. Put into position, the scale really comes into perspective. Given I could not find any info on this exact model and ram weight of the hammer, I really hope I was right in sizing the diameter how I did... 1 Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
Alan Longmire Posted April 16 Posted April 16 Mind-boggling ingenuity! It looks proportionate to me, for what that's worth...
John Page Posted April 16 Author Posted April 16 Spent the better part of the day machining some hub spacers and I'm glad I built in coaxial adjustment! The rim was almost dead concentric but had a fair bit of wobble, so tightening the spokes on one face and slackening the opposite, I got it running true with an ease that surprised me! It came at the cost of throwing it out of concentricity by a small bit but now there is no visible side to side deflection which for the belt tracking is far more important. I'll call it a success! Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
Brian Dougherty Posted April 17 Posted April 17 Dude! I sort of hope I never actually have to build a wheel like that from scratch, but I am thankful that I now have a good idea for how to pull it off. You've got nards of steel my friend. -Brian
John Page Posted April 17 Author Posted April 17 I pity anyone who ever has to go through this! No wonder the small handful of line shaft experienced folks I've talked to have never heard of anyone making a wheel like this. Best I can reckon, it's firmly in one of those 'lost arts' categories at least for the wooden ones made of several segmented layers. But for the steel ones, on an industrial scale the castings are left to the old Amish foundries and the stamped steel ones probably saw the last factory close the better part of a century ago. Now that I have the final bits made and a coat of paint on it, I must say it went off without a hitch! I was really worried something catastrophic would come up at the last second but all in all, it really looks the part with a clean unified surface finish. For being perhaps the most apprehensive problem to solve on the entire rebuild, it turned out to be the most fun! I suppose technically I still have to make the shaft collars to hold it axially since I was a little overzealous getting to the paint job and neglected to make an integral way of locking it on. There are two bronze collars that were on there for some unknown purpose so I might be able to drill and tap those and not bother making one from scratch. Either way, I'll get through those last few fabrication pictures shortly! Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted April 20 Author Posted April 20 Here we go! Now that the paint is dry, I've been really enthralled with how this came out. It makes turning over the eccentric shaft a lot easier with the bigger diameter compared to the flywheel I've been moving but there's still a bit of sticking at a certain position in the stroke which will either wear in or be some adjustment I'll have to sort out... To fit the wheel to the axle I made up this hub spacer piece supporting the spoke hub by this pair of disks. To get the rough size I cut two circles out of a plate with an angle grinder scribed from a centre punch with a pair of dividers then rough ground on the belt sander to take off all the hard corners. I used a half inch bolt and some nuts/washers as a temporary arbor to get the outer size turned down until it was a tight but sliding fit with the wheel hub. Then swapping out the chuck jaws to hold the outside of the disks, I could cut out the shaft diameter. Because I did not have any drills near this size and did not want to deal with taking a few hours of cuts with a boring bar, I did a bit of improvised trepanning. The turning technique involves cutting out a disk from the middle of a part without turning everything into chips. The trick is the tool geometry needs to account for the interior curve of the part so it does not rub as the cutter plunges. While I have a small stash of high speed steel, it's not enough to justify sacrificing one to this particular tool geometry. So as a compromise I ground a bit of relief on the edge parallel to the cut and went in from both sides so the overall depth was only about 1/8". Then, once the core separated, I did a few clean up passes to reach the final diameter testing against the shaft to get a similar tight but sliding fit. All fit great so I added a bit of relief on half the thickness of each disk for weld penetration. To deal with the keyway, I scribed the width/depth on each ring and removed the bulk of the material with a hack saw then filed to fit. This fitment was not that critical because the actual keyway comes next but the whole wheel needs to clear it for installation. A little out, but for what it does, totally fine. For the actual keyway and the spacing of the two end caps, I cut some half inch square stock and clamped it in place on the shaft to weld to the disks. Whatever the bronze shaft collars were for in the as-received setup, they helped keep everything square to the shaft and ward against heat distortion from the welding. On the opposite side, I cut a bit of angle iron that was nearly a perfect fit unmodified to act as additional internal support and resquare the disk faces. I only had to grind about 1/16" off each of the three edges for the wheel hub to clear it, and the two faces in contact with the shaft will help a lot in distribution of the torsional forces when the keyway drives the axle. Between the two sections of bar on either side of the key, I added a third length to keep the key from falling out during use and give a bit more weld area contacting the disks. Checking the fit multiple times as it cooled, the 4 sheets of paper as a shim for the key during welding was just about perfect to keep it tight but still easy to install. One problem from earlier I had to deal with was all the threaded intrusion from the spokes. Because the balancing was all done by this point, I was not worried about the sliding fit of the hub spacer bit. With a die grinder and half round file, I got it all down to the level of the pipe and inserted the new hub core. It's been a while since I've done any TIG work and it took a bit to get back into the flow but it got welded together on both sides buttoned up, thus concluding the fabrication side of the drive wheel. As I think about the rivets, for the time being I opted for countersunk bolts. I was able to find enough of them locally that it made sense considering there is still a slight possibility I will need to adjust the balance of the rim to the hub. So, to accommodate the heads I had to countersink all 24 holes to fit. For this large a head it was a bummer and took a couple of hours but once I remembered I had a large carbide countersink I originally used for the underside of the baseplate, cleaning up the fit was a breeze. Then it was on to paint! Watching the cohesion come together with the first coat was incredibly satisfying. I ended up with two thick coats on it and left it to dry over the weekend. Although I would much rather have liked to have the original wheel with the machine, this is the best alternative outcome I could have hoped. Eventually, I'll figure out the shaft collars to keep it in place axially but for now that is a lower priority. Next up is working out the lineshaft and the treadle/idle wheel linkages. In theory I have a motor and VFD but that will need looking over as well once the lineshaft is going and I find some belting. 3 Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted May 16 Author Posted May 16 As the next overly complicated phase of the lineshaft ordeal is coming near to a close I thought I'd clear out the last few old pictures from the drive wheel. Being dissatisfied with a non-integral retaining collar, I looked back at some old photos of shaft driven shops and took inspiration from the split wheels that can be installed around a shaft without needing to be threaded through the end. The benefits are tremendous and I almost went with that style of split pulley for this drive wheel but it was already complicated enough already and should theoretically never have to be in that situation given its purpose. However the locking collars to fasten it to the shaft are a sort of miniature version of that idea. First, I forged up two sets of half round flat bar and punched the ends for bolts to pass through. A wee bit of grinding to get the edge profile flat and the inside curve smooth, and it was onto affixing one half of each set to the wheel hub. Originally, the hub looked weirdly oversized due to the stock limitations I was working with. However, the outer diameter was just about perfect to accommodate the bolt hole flats. My only regret is putting a radius on the entire end rather than just the outside facing quarter. A touch up with the die grinder and the welds blended in well enough that under paint it should look decent as a nice smooth fillet. Before repainting, I did a test assembly on the axle just in case. You can see the clearance for the keyway between the static and dynamic sides of the collar and distance to the bolt. Also having this bit of gap allows for more of a spring action on the collar pieces to draw it tight. With these on either side of the hub the fit is very secure. And here it is after another coat of paint on the fresh bits. It almost looks like I knew what I was doing! The final bit for now is a set of shaft collars for the lower axles that theoretically hold pieces related to the treadle linkage. It is a bit of a mystery but I have developed a theory... Digging through the scrap bin I found these candidates. Ultimately I'll need four total but of the pieces only some of them need to be collars on their own. The rest will be a combination collar and linkage pivot assembly which will be fabricated out of a collection of more appropriately sized bits. If the hammer were already running I'd forge it, a classic catch 22. These are nothing particularly complicated, really just thick washers with a nice roundover on the edges. Eventually when I have the linkage figured out I'll add tapped holes for set screws. Here is one set (plus the original on the forward axle). The thinner one will be part of a larger assembly so I could get away with less thickness. In the lower left there is a stud threaded into the frame which is what the original (to me) treadle was attached to. Given that the hammer at one point had been converted to a direct drive off of a motor, many of the original linkages and configurations are lost to tome. None of the patent drawings or surviving catalogues have this particular vintage of hammer and at some point along the way the treadle/idle wheel/counterweight/brake clutch mechanisms changed. My current best guess is that I will keep the treadle on the lower studs and on this side (left) link to one of the two shafts with the new collars on them. From there the counterweight will keep the treadle from falling down and engaging itself. If it seems like there needs to be a bit more friction in the 'idle' state, I'll add back in the brake which rides on the face of the flywheel which is hanging down in the top of the above picture. Those two together will likely go on one shaft so the counterweight acts on the same fulcrum as the brake. Since the rear shaft was missing entirely when I received the hammer, it's as much a guess as anything. On the other side, the treadle will link to the other shaft which will act as the pivot for the arm holding the idle wheel. Downward treadle will swing the idler into the drive belt increasing friction and, more importantly from the old belt driven power transmission books I've been perusing, the amount of the wheel's total circumference that has belt engagement. For all that material I'm going to embark on an adventure to the local scrap yard and see what I can find, but in the meantime I'm finishing up the lineshaft. The last little while I've been fitting the overhead motor, drive shaft, sourcing belting and lacing, a paper pulley for the weird motor arbor, and most substantially forging/fabricating a set of bearing housings for the main shaft. I'm a day or two away from pouring the babbitt then I can get the final measurement of the belting and rig up a treadle-less test run! The end is looming but still a fair bit of engineering to get through before I can finally make a racket with this thing. 1 Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted May 20 Author Posted May 20 Now that I'm successfully on the other side of it, it's time for the lineshaft bearing adventure. This, along with the drive wheel, have really tested my ability to figure things out from the dusty tomes of ancient reference books. I think now that I have the babbitt cast I can officially self describe as an old machine guy. For the tremendous amount of work it was to make these, I really hope the end up functioning as intended... For the body of the bearing shells I opted for some sections of 5/16 wall angle iron. I rummaged through the immense pile of material still sitting haphazardly in one side of the shipping container and could not find any tube close enough to work. If I ever do this again I'll come up with a pattern and cast them out of cast iron because it would be quite a bit easier. To make the process all the more complicated, no one I have been able to find has made these before. It's always scavenging the ever-dwindling supply of old stock and making it work. So this was all a poorly educated guess that gained momentum into something somewhat respectable. Cutting off a bit of the excess width and relieving the corner for a more uniform end thickness, the blanks kept that middle peak for structure for mounting the studs which interface with the shaft hangers. It was a bit of foresight as that was one of the last things I did before pouring in the babbitt but it worked out. At the end of the day this is so thick I need not have worried. Indeed, an appropriate section of heavy wall tube would have made this about a week faster to produce. However, leaving in a bit of the corner thickness allowed me to add a bit of visual styling later on that is more reminiscent of a cast piece rather than forged. I just so happened to have a swage of roughly the right diameter and a top tool for the flypress. By rotating the angle iron with each compression it came out vaguely round. The size of these is somewhat important in that, as best I could find in old books, the babbitt layer needs to be about 1/8" thick for 'large' shafts and heavier loads. For lighter duty sometimes it is as little as a third of that. Becasue this is incredibly improvised, the final babbitt layer ended up a bit of 1/8 at the thinnest point but it was not easy to measure accurately. More is better than less, I assume? After a bit of grinding to clean up the ends and transition, you can see the slight feathered in rib that comes to a flat in the centre of each shell. It seemed to fit the vintage of the project but otherwise does nothing at this overall thickness. If it were 40 years ago, I would have stopped here but getting a retaining compound to keep the babbitt contained during casting is much more difficult to find. There are a few alternatives to Babbittrite but it was another thing to wait on and might have not even worked. So instead, and to solve the problem of holding the shell coaxial to the shaft during casting, I added some faceplates forged out of the offcuts. They were all the same size and I had the exact right number, although they are a bit overkill. With a section cut off of the drive wheel hub, I whipped up this improvised bottom tool for the flypress and it happened to be the exact size I needed. Precurved on the widest bit of my swage block then fed in a bit at a time, I ended up with a slightly-more-than half round. Ultimately it sits like this, acting as both a reference plane to the end of the shell as well as a machinable surface. The lot of them ended up fairly consistent but the issue with any sort of partial round forging is always in the ends not continuing the same curve. For that reason leaving the length oversized allowed me to cut them down to a semicircle. Creative use of a centrefinder and a combination square let me roll the half ring around the bisected axis and find the best semicircle out of what length I had to work with. In the end, a few were a bit weird but it all gets machined so the as-forged state is not critical. Shimming the two halves and tacking the outside ends together left me with rings, more or less. The easier way to do this would be to just machine them out of a plate then cut it in half, but nothing in the scrap pile fit the dimensions. Collectively, I bored out the inner diameter until the smallest one was clean all the way around then matched them. Although the dimension does not matter, consistency does because this inside face will be what locates the final shell about the axle, so they all need to match both for evenness of shell spacing but more importantly so I only have to make one set of locating plates which fit all four shells. At the same time, I turned each face so it would be perpendicular to the bore. This way, I can ensure the axle runs perpendicular to the shell (close is good enough) and interface cleanly with the locating plates. That locating plate was a three part affair. Critically, the first piece turned down to a slip fit with the rings. A bit loose, but only slightly so it would still have clearance when everything is hot but not so much that the babbitt can escape around it. After the outer diameter, I swapped the chuck jaws and bored out the inside to be another close sliding fit with the shaft. The second, less important piece is a wider flange to abut the shell end faces. I filed out a little notch in four points and welded it to the locating ring then filed smooth so it would fit again over the shaft. Here is what the first one looked like, the second matching. Part II incoming... Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted May 20 Author Posted May 20 (edited) A test fit shows how this all goes together (and the third piece of the locating collar being a bit of slightly oversized tube to help keep the interfacing plate perpendicular to the shaft axis). The thin step in the locating plate fits within the shell end plate, then held perpendicular by the wider flange. The two of them together sandwich the forged shell pieces and once the shell is joined with the ends, the whole assembly is held about 1/8" more or less from the shaft. Keeping the same shim spacing, the shells were welded to the end rings. The rings had a inner diameter slightly larger than the shells so it was easier to position them relatively concentrically. If I still had access to a mill I would have run a boring head down the welded assembly before splitting it so the bore would be nice and round. Instead, I attacked it with a small wheel on the belt grinder to even things out and remove the scale prior to casting. Tacked in place, I checked the fit with the locating plates and shaft to ensure I was not making a grevious error prematurely. This is a clearer vantage of how the parts interface. For casting, a clamp on either side holds the locating plates tight to the shell. Next up is adding a retaining shelf to the upper shell of each pair. On the originals, these exist presumably to help keep alignment of the two halves when there is no shaft between them. I figured I would add some too. For my 'design' it also helps keep the two pieces aligned even with the slight gap from the shim. I did that mostly so the shaft can wear in to the babbitt and be re-scraped if needed a few times without having to recast the entire thing. Not having a matching bearing/shaft pair I do not really know how this is supposed to look but I imagine the slight gap is normal as long as it is not so large that it allows debris to enter the bearing surface. It also acts as a sort of shield for the bottom shell for just that purpose. Finally, the way I placed the horizontal pieces keeps the two halves laterally aligned. The width of the face on the lower shell captures the shelf of the top shell. The final machining piece is to add mounting studs to each of the four shells. On the shaft hangers, there is a top and bottom bolt which locate into a shallow countersunk feature. This allows the shaft to pivot in one axis which makes installation and alignment of the hangers considerably easier. To a small degree, it also allows for a very slight bit of levelling. Using the entirety of the offcuts of the as-of-yet unmentioned helve cushion bell housing rod making, I turned them down freehand, countersunk the end, and cut them off in pairs so the final two would still be long enough to hold in the chuck. The discerning eye can see the mangled countersink courtesy of the lathe's incredible lack of rigidity. They are not really something that sees much motion so as long as the bolt ends cannot jump out, good enough to be serviceable. Once again, before welding anything I checked to make sure it would fit. And it almost did not. Fortunately, I could have ground down the studs a bit as they are on the long side. With the bearing shell held in the hanger, I could also check alignment and position of the studs and tack them in place. A horrendous amount of die grinding later and the shells felt a bit more on the cast end of the spectrum rather than the forged/fabricated. It's always impossible to tell in pictures because of the bare metal contrasting with forge scale, but all the welds were nicely filleted and hard edges smoothed out. It was at this point that I also went back with the tig welder and closed up the inside corner of the shelf bar and all the remaining seams except the critical one that interacts with the locating plates. Against my better judgement, I decided to try and use my little drillpress for plunge milling. From the little bit I could find on casting new bearings (vs. replacing existing babbitt) one of the two common methods involves anchor holes bored into the shell to give a sort of mechanical hold for the babbitt. Not wanting to take any chances, I decided to add three on each of the long edges, biased so the deeper part of the hole is towards the top. This way the babbitt cannot fall out as it is pinned in place by the undercut. The second method is to prime the surface of the shell by tinning. There are speciality fluxes and casting compounds meant for this but the only one I could find was measured in the gallons and priced to suit. I tinned a fair bit of non-ferrous metal and assumed the process would be more or less the same for steel. Using tinner's flux, I liberally coated the interior surface and slowly heated from the underside with a weed burner. A bit of tin on the inside as it came up to temp makes it easier to not overshoot. One benefit of the mass of these is how long it retained heat. I only had to do a secondary burn on one of them to get the entirety of the interlayer applied. I did find it more difficult to get adhesion on the steel compared to copper or brass. Typically I use a bit of insulation held in some forceps to sort of wipe the tin around. For this, it was a more aggressive scrubbing. The 'back in the day' recommendation was to scrub the molten tin into submission with a wire brush. It might have worked better but this was not too bad. Of note, however, even the lightest bit of forgescale prevented a bond regardless of how much flux or heat or scrubbing was involved. I was left with an adequately tinned surface but there were many imperfections. If I ever do this again I will take a lot more time cleaning up the faces before tinning. For the babbitt, I used this nickel babbitt generously donated to the cause by Jan after the perfectly coincidental discussion of using it for casting fittings. To fit it in the crucible, I had to cut it into smaller coupons. Of the 6lbs I used just shy of 5 between the four shells. A few years ago I converted an old bone saw into a hack saw using pieces of an almost-new bandsaw blade that snapped and it cut like a dream. I can't imagine a regular hack saw blade would be a good time for how easy the teeth would clog but this rougher tooth was excellent. A regular crosscut wood saw might work too... Menaced by cloudcover threatening rain, I brought out all the bits and pieces. The little 2kg crucible happened to fit perfectly in the end of my old 1 burner forge so I tipped it on end and used it as a furnace. The crucible is coated with a kiln wash to prevent it from deteriorating in the forge atmosphere although these temps were low enough I suspect it would have been fine bare. While the babbitt melted in the forge, I pre heated the shell once again with a weed burner. Recommendations suggest that it should be around 900F depending on the alloy but that seemed almost as hot as the melting point of this babbitt. So instead I crept to around 500F, watching for the tin layer to float and then a bit more. Critically, preheating cooks off any water which can turn this into a volcano of molten metal. The other serious precaution was, in addition to doing it outside, I wore a respirator rated for fumes. I poured the two upper shells first as they required more babbitt. Most of what is in the pocket next to the shelf will be removed later but I wanted to sneak up on the fit rather than have it be loose off the bat. For the shaft, I debated heavily on how to treat the surface. Most old texts recommend acetylene or oil flame blackening to add a carbon barrier. In the end, I decided the rust would be protection enough based on how hard it was to get adhesion of the tin on clean metal. For the two end plates I burned a coating of wax into them for a combination of scale and anti-flux. A few nocks with a hammer and the shell popped off the shaft. Inside, the surface is about as good as I could have possibly hoped for and has one inclusion line from starting with too little in the crucible and needing to hastily melt more. The four of them went without a hitch. The end plates served as a perfect containment method and nothing leaked out, the interface rings did not have anything creep under them and lock them to the shaft, and the adhesion most importantly seems flawless. Each one rings nicely when struck although the top left I overpoured a bit and needed some persuasion to remove. Even then there was no separation between the babbitt and the shell. All in all, I could not be happier with how it went. There is still a frightening amount of filing and fitting to do, oil grooves to cut in, oiling holes to drill on the top shells, etc. etc. One step closer! I'm mid way through making the wooden cores for the shaft pulleys, making a treadle, dealing with the belting and motor, and a handful of other odds and ends but this was the most significant challenge left and it's now ready to be checked off the list. Edited May 20 by John Page 1 Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted May 28 Author Posted May 28 (edited) Don't want to put up too many spoilers, but IT LIVES! I'm about to head out on a trip for a few weeks and I was pushing hard to get the hammer running under power before I leave. Well, with a few hours to spare the motor, belting, shafting, and linkages all operate without interference. I was scratching my head because it kept throwing the belts but then I finally realized the shaft-hammer pulley was worn into a cone by about 3/4" circumference larger on one end than the other. Some fly by the seat of my pants reduction using the lineshaft as a lathe and my biggest grinder, dust covering the entire shop, and checking about a hundred times so I wouldn't overshoot it, all is well! Still an incredible amount of work tuning the linkages both original and shop made, plus figuring out how to make the ram stroke land on the bottom die. The work continues, but getting it to a technically-operational state is an incredible feeling! Pictures to come when I return and the final stretch of fabricating more permanent and aesthetically pleasing solutions to my vision quest in discovering how the linkages work edit- here's the hammer as it sits. Can't stop looking at it! Edited May 28 by John Page 2 Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted June 24 Author Posted June 24 (edited) Finally back from a long trip on the road and it's right into it! Before I take a video I desperately wanted to get the shop walls finished after staring at the last 1/4 or so that needed work after getting the electrical run so long ago. To say the shop is in utter disarray is an understatement! Part of the lingering dread to getting the 2 days or so of work done on the walls is the moving many hundreds to thousands of pounds of stuff out of the way. It's amazing how quickly everything becomes entrenched once the mess of work starts piling up! The two sections are conveniently on either side of the garage door so moving one side makes it twice as hard to get to the other... But the final bit of concrete work is done and once it is dry enough, I can get the last sheet up on the upper walls and it's FINALLY done after staring at me unfinished for the better part of 8 months now. Until then, here's a bit more on the lead up to getting the hammer running under power. Lots of odds and ends, little jobs that have a way of turning into bigger ordeals. First things first, I needed to remake longer bolt assemblies to secure the rear bell cushions. Originally, they were just 4 bolts but when one of the two cast bell housings failed the former shop did a surprisingly excellent repair by machining off the cast flange, threading the cast iron, and making a matching threaded hole in a plate. But to keep the stress off the threads, they added a secondary support plate that clamps from the top/bottom of the casting to make it hold under compression rather than tension. The threaded rods/bolts they used were long enough to pass from the new plate to the other undamaged bell flange. To balance the repair I cut a second compression plate in addition to the one I replaced which was far less sightly than the threaded repair job. Because of that, the rods needed to be nearly twice as long to accommodate the extra distance. Unlike the stainless threaded rods I made earlier for the stacked rubber disk assembly, these threads would take the entire load of the hammer, dampened by more cushions, during operation and therefore could not be undersized to make cutting them with a die easier. And so, it was onto the exciting task of divining how my old lathe change gears work. Going into it I was not even sure I had them all, and what stack I do have I happened into a few years after getting the lathe from a friend who was clearing out some space. Shortly before moving, he said he found another box of parts that may or may not go with it and this was the first chance I had to really go though it all. Lo and behold, the gear set was miraculously complete (or complete enough to make this work). What was not complete, however, was the original threading chart which at some point undertook some catastrophic abuse. Fortunately, *most* of the information I needed for the thread size was still there and paired with an older 1937 manual was just able to figure it out after several hours scratching my head and trying various things. What was not obvious in the manual was that many of the specified gears were simply spacers and did not interface with any other gears. I find it exceedingly strange that they would specify a tooth count for it to not do anything. Once I figured that out, and after getting maddeningly close to the right thread pitch but being off by 1 or 2 TPI, I finally got to the magic number. Rickety as the lathe is and for how much abuse it has gone through throughout its life, the thing still works a treat. The carbide inserts kept breaking immediately however so I had to grind one out of high speed steel to sneak up on the threads. Due to the glaringly horribly cutter angle I could not rely on single point turning the entire thing to fit the original nuts so I got it as close as I dared then finished it off with a die. Due to the tremendous amount of backlash in the compound, I resorted to this setup to indicate position and went through about half of one of the four rods' two ends before abandoning it and doing it by feel. Threads cut and rust wire wheeled away, and the final bit of thread cutting came to an end. This is what the plate setup looks like if the verbose and unhelpful description was lacking. The top bell is the undamaged and the bottom has the replacement threaded flange that sticks out around the helve yoke. The two outer top and bottom plates are doing all the work of holding it together and I used a little leather cut into a washer to help seat the clamping plates evenly and hopefully prevent any damage. Next side project was to weld this broken corner back onto the cushion cover. Only one of the two survived, the other being lost to time and something I'll need to remake eventually. For now, I put this one on the side of the hammer facing the working area because it seemed appropriate. Like with the other cast iron repair, I used high nickel electrodes to stick weld it. For these thin cross sections allegedly no preheat is required but I do anyway for safety. Stick is by far my weakest welding area but this nickel is great to work with. It flows nicely is easier to clean up than the other pitiful attempts I've made at stick welding. Same as the rest of the hammer, it got a clean and then coat of black farm paint. The top right corner piece was nowhere to be found but less critical given that it did not encompass the bolt hole. To get power to the hammer I mounted a 5hp motor in the ceiling but being 3 phase my only option was to either use a static phase converter, which is essentially a capacitor bank which jump starts the motor then runs it on 2 of the 3 windings, or to use a VFD. Eventually I'll probably get a rotary phase converter but this was the easier solution. I had the VFD and all the parts on hand from when I was dealing with the same problem on the table saw. There I used the static phase converter but this will be used much more heavily and the bonus of speed control made it the obvious choice. I am a little weary of the 5hp output rating of the VFD considering all reputable suppliers seem to peak at 3hp, but it seems to work and as I understand it the VFD is a hard limit on output power so if it is underrated for the motor, the motor just runs at a lower power. The setup in the dust enclosure (another dumpster score from the old shop exodus) is a bit messy with how the wires interface with the VFD. Kept in place with some conduit clamps then really stabilized with those strain relief fittings it feels relatively sane. Instead of wiring the motor straight to the VFD I added a receptacle on either end of the input and output to make the unit more generally useful. Also in part because the existing cord out of the motor was not long enough to make work directly wired and I did not want to delve into yet another project rewiring that. Where this will hang is yet to be determined but for now I can set it on the welding table as I tune the hammer. The last bit for now is another lineshaft project. Common to lineshaft pulleys are a set of core spacers which adapt the pulley to whatever shaft diameter is needed. Compared to pulleys that are made to a specific bore, these can be used anywhere. The issue is that the core spacers need to be made for every wheel and each shaft. When I sourced lumber for the helve beam, I picked up a second set of timbers in white oak in case the hard maple gave me issues or I did something irrecoverable. To that end I had the perfect starting stock for the two spacer sets I needed. I cut them to length being slightly oversized for the width of each pulley and glued them together so I could work the blocks as a unit then cut the glue line at the end to separate them. In theory they can be made out of a single larger block then cut at the end the same way but I did not have anything large enough and it felt like having two bits gave better grain orientation. Plus, having the glue line made it trivial to split them down the middle. My original intent was to turn these on the wood lathe. But of course, the chuck selection I have did not include anything able to open wide enough for these so it was back to the metal lathe which in hindsight was a better option to make perfectly parallel sided cylinders. Nailing the size of the core diameter was a bit tricky but between the chuck and a tailstock centre I could test fit it without risking losing my alignment going back into the lathe. Once turned down it was time to bore out the shaft diameter. To final dimension they just barely fit in the wood lathe chuck. With how the power transmission is set up on the metal lathe, it does not have enough torque to handle this 43mm forstner bit. Machining done, the core came out perfect. Splitting the two halves apart again was quick but ended up with the two long edges not quite coplanar with one another. A quick sanding and they were close enough. In practise, the kerf of the saw blade is enough gap for them to work as is but I felt like I should put in a slight bit of extra effort to make them not need to be in a matched orientation to seat properly. Mounted with the pulleys, and all is well! The wheels fit perfectly on the cores and the cores perfectly on the shaft all with just enough gap for the pulley mounting bolts to draw it all tight. Next up in the backlog is building the treadle and linkages, an expectedly complicated ordeal given the complete lack of information on how it was originally put together and what those pieces might have looked like. There is a bit of fiddling to do on it still now that I have it functioning but there is quite a bit of tuning to make it responsive. Edited June 24 by John Page 1 Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted August 6 Author Posted August 6 Back to it! I'm going to put up all the remaining rebuild pictures in the backlog first but now that the hammer is theoretically operational and I've actually used it for forging-other-than-testing, I have several thoughts and areas of refinement to how it runs vs. how I think it should run. Given the relative novelty of the hammer in regards to surviving counterparts, it is all so much guesswork and riddled with compounding variables that the majority of the time I've had with it to try and tune the mechanisms has been guesswork and trial and error mixed with a bit of somewhat educated speculation. First up, finishing the treadle. The original to me was certainly not the actual original and also in several pieces so no help in using it as a template for the new one. Instead of the classic bent tube approach, I opted for a flat top surface for the foot to leaver on (mostly based on available material but also for better rigidity due to the immense size as relates to pivot:actuation length). The egregiously heavy and oversized angle iron that fit the bill gives me some important features that will come up later. For now, the main one is having a built in perpendicular side through which the pivot studs can fit sans welding assembly. To reduce the weight of the leaver arm on the working end, I plasma cut each limb in a mirrored shape that feathers out the vertical face somewhat like a clock lancet. keeping this bit of the angle iron keeps a lot of the anti-bending strength at the far end of the tip. The back end on the rear side of the hammer has that extra length for counterweighting which comes up later. Because the metal was filled with stress, released in the plasma cutting, they both bent fairly significantly in a long arc which was fairly easy to take out with the flypress. The final assembly looks like this, although a bit cleaned up on the lines and welds after the fact. The rear portion received some through holes to bolt on another short leg of the rectangle onto which various ballast counteracts the vast downward force of the long lever arm. I had to leave it open to be able to physically install the treadle so hardware was the only real option there. The next and possibly most daunting piece of the puzzle is the key to all the linkages. Somewhere along the way I may have already told the story of the idler piece but the short of it is, when I got the hammer it was totally missing. The idler and drive wheel were both things I knew I would have to figure out, and luckily before getting to the idler the old owner got ahold of me saying he found the piece. In a roundabout way it eventually found its way back to me after almost having it be lost in the postal system forever. The good news is the idler and upper bit of the tension arm were in almost immediately-usable condition. The bad news is only about a quarter of the arm itself was there. What happened to the rest of it must have happened long, long ago and the remainder lost to time. Due to the way the idler and axle interface with the arm mount, I desperately did not want to make one from scratch if at all possible. But the arm segment is cast iron and finding a way to join that to non-cast iron seemed dubious at best. Reading around, it seems like the same nickel welding rod I used for the cast iron repairs could also service a mild steel-cast iron weld interface. I figured worst cast it does not work and I have the same piece as before but in need of a little cleanup. To make my chances of success as high as possible, I added a sort of spine piece across the seam so there would be both a butt weld and a good bit of fillet welding holding it together. Had I better machining capabilities, I would have also used pins somewhere but that was not in the cards. Having used it now quite a bit, the joint is solid and I'm not worried about it failing under load. Extending the arm was only part of the issue. Once it was the right length, I also needed a way to attach it to the pivot axle in a way that kept it in plane with the drive wheel. An assortment of clamps and dunnage is the best I could come up with so I held it there and welded it in place. Ultimately it is very slightly twisted but good enough and possibly within the tolerance of the pivot hole to shim straight if it seems like it's an issue. Due to the heavy amount of fabrication on this piece, it may be the only one on the hammer I end up using body filler on to make a little more sightly. The roughly 6' of fillet welds on the other side between the round bar and flat bar are fine and blended with a die grinder but need a little more work. Here as well as on the other side where the brake linkage ends up, I found the thickness of the pivot hole matters a lot more than I thought. Even at roughly 5/8" thick, there is considerably too much play when at the end of the arm. So I turned a few more discs, adding threaded holes for bolts to lock it to the shaft and reduce any more wobble. (It also looks way worse than it really is from all the bare metal contrast with oxidation, but another reason I want to hide a lot of the crime with body filler) Presumably somewhere in the original linkage the math was figured out as to where the treadle needs to mount to the idler arm. Unfortunately for me, the number of variables made it impossible to constrain any of them and still have the certainty that one of them would be in the right place. To give myself plenty of room for adjustment, I used the geometry of the flat bar to make a sort of sliding clamp to variably fix the height of the linkage from treadle to idler arm. The original plan was to use the same bolt that clamps to the arm as a place to attach the linkage, but I ended up welding on a new piece parallel to the bolt with a hole so the joint would be perpendicular instead. After a bit of filing on the arm to get the sliding collar to move smoothly, it was ready for a test run. On the treadle, a similar collar interfaces with the vertical bit of the angle iron left during the plasma cutting weight reduction operation. The pivot of the idler arm and the treadle are of course fixed, but the position on the treadle and height up the idler arm are adjustable, as well as the distance between those two points. This allows for tuning in the position of the treadle and idler wheel so when the treadle is fully up/released, the the idler is just off the belt. When fully depressed, the idler arm is just short of touching the drive axle. In hindsight, the older patent drawings depict an arc for the idler arm so it can swing over the drive axle instead of bottoming out there. During operation, it seems like there is no slippage (full power) when the treadle is fully engaged so it has not been an issue. Worst case I throw it in the long forge and try to bend it. Based on how I have come to understand the belt configuration, I do not think it will be an issue because the only way for the mechanics to change are if the overhead shaft moves considerably farther towards the front of the hammer which it will not do and remain out of the working space. Of note I also replaced that improvised turnbuckle with a real one. I planned on forging a rigid linkage for this side as I ended up doing for the other smaller one near the brake, but I've found it's actually convenient to have the on the fly capability to tune it. Also the original brass turnbuckle that came with the hammer suggests there should be some sort of built in adjustment anyway. Next batch is working through the nightmare of the other side linkage... Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted August 6 Author Posted August 6 For the left side of the hammer, originally there was a smattering of leftover linkage parts that had been modified at some point, likely around the time the direct drive motor mount was added to the right. Because of it, one of the two linkage axles was missing and the entire brake assembly in shambles. Before running the hammer, I hoped I would not have to worry about the brake and counterweight, just figuring out the idler arm on the right side. But the first time it ran under power it was obvious that I needed the brake otherwise even at the loosest belt tension it would continue to slowly turn over. Using the last long bit of what I rolled so long ago for the drive wheel rim, I put it back in the ring roller and tightened the bend to match the flywheel. Based on similar style hammers of the time, this brake shoe is probably twice as long as it needs to be even after later cutting a fair bit off. Slightly oversized in the diameter, it fits with good contact using the leftover bit of belting from the hammer-lineshaft belt. To hold onto the shoe, I added a pair of tabs between which will eventually sit the linkage arm. Due to the various unknowns I knew I would need the mechanism to be able to pivot to match whatever arm and actuation length it would end up with as well as continue to seat as the wear pad breaks in. For hopefully the last time, I went to the lathe and bored out the hole for the pivot. Even with the largest annular cutters I have for the mag drill, opening it to size still takes the better part of an hour on thick sections. The interface between treadle and the brake arm is compound, so it was a lot of guesswork. The eccentricity of the plate I just bored was a somewhat random guess but I had no real way to make it variable until finding a length that would work in situation. The treadle has the same sliding collar pivot as on the idler arm connection so I could move the position of the turnbuckle until it seemed like it would work. You can see that the first try had the treadle pivot on the other side of the axle but I ended up moving it farther towards the ram side of the hammer to get the right amount of relative movement between the treadle depressing and the brake shoe disengaging. At this point it also starts to get a bit messy with the counterweight arm involved. I went back and forth quite a bit debating on if I should have it all using the same axle or if I should involved the rear one that has the idler arm on the other end. By having the counterweight able to rotate freely about the rear axle it would eliminate some of the interference issue I have between the treadle and weight. Without the weight acting directly on the brake, it does not apply enough force to function properly. A quick interlude at this point, mostly out of necessity, involved mechanically attaching the belting to the shoe. I previously had it just sitting there and it mostly worked but every now and then it would shift and shoot out as the brake engaged. Instead of using some sort of glue, I figured some bolts and a clamping plate would work better over time and be easier to replace the belting when it inevitably wears out. Drilling the belting is all but impossible to do cleanly, but fortunately the punch does a wonderful job. Here you can see the new and improved belting retention at work, the forward end folded over and around so the contacting surface covers the bolt heads. Also above the discerning eye can see the horribly slapdash effort at using something other than clamps to hold the counterweight arm. Also the little turnbuckle which got immediately destroyed by the forces involved in the assembly. To replace the turnbuckle was trivial now that it did its service in divining the length needed to make it work as intended. This is the first real thing I forged on the hammer which, making parts for itself, seems appropriate. A couple of punched holes and chopping off the extra, and it was a perfect fit with far more rigidity. This section is now somewhat functional although still has a long way to go to not be an abomination. I remade a more substantial locking collar for the treadle arm as the old one kept wanting to twist out. Now it locks to both outer sides of the angle iron and holds much more firmly. I need to make a new arm for the counterweight that is the proper size for the hole, the one on there temporarily being too thin and not long enough. The proper one will also bend upward so it does not hit the treadle and may possibly have some sort of bolting mechanism to join it with that random bit of extra length on the forward end of the brake shoe arm. Plus, the entire linkage assembly at this point does not have the axial rigidity I would like so that will need to be rectified eventually, and some spacers so the brake does not drift towards the hammer frame... Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted August 7 Author Posted August 7 The final bit for now before meandering speculation. One of the odd jobs left to do was make the treadle operational. As it sat, I had to have about my own weight on the back end to balance the length and weight of the front. As much as I hate it, using springs seemed like the best option. In the original design there appears to be a similar solution although as to where they attach I have no idea. I temporarily replaced one of the frame bolts so I could see how it might work. With the same sliding collars on the treadle arm, I could move the position of the bottom end of the spring forward or backward, thus adjusting where the force was acting in relation to the fulcrum. Conveniently, a near vertical line balanced the treadle while keeping the springs out of the way. To more permanently attach them I forged a pair of washer hooks so I could still use the frame bolt position. Simple and effective for once! Another small but looming issue is all the oil. Because every bearing surface on the hammer is an open system, all the oil tends to collect in mostly two places on the frame. One is in a shallow rectangular depression directly below the helve yoke, the other on the curved part of the frame beneath the eccentric cam. The one inside the frame just collects there but would eventually overflow, but the bottom one tends to pour down the back face of the hammer or into a seemingly unused threaded hole. With random bits of scrap I made up two pans to act as collection reservoirs. The lower one was a bit more complicated due to the fact that the surface it sits on is not flat and therefore would almost instantly eject the pan from mechanical vibration. Conveniently that mysterious threaded hole happened to be the same size and thread as one of the spare bolts I made way back when. With a bit of pipe as a standoff to keep the oil from seeping beneath the bolt head, that little island receives the bolt before locking the pan to the frame. The second, a simple rectangle, sits just inside the lip of the frame casting and does not seem to want to jump out. If it does, I will likely just add a magnet somewhere to keep it in place. So far, this catches the majority of the oil but I still need to make a similar solution to the lineshaft bearings as those currently drip onto the floor. As mentioned when I first got the hammer moving under power, an immediate and obvious issue I found was that the ram simply does not come down far enough. To be able to use the thing, I made a quick die plate. I happened to have a section of 4140 that was the exact length of the lower die and just a bit narrower, so this little hook holds it in place. In the future, when I do not need to do this during normal operation, the die plate will still be able to hold various tooling, auxiliary dies, or stop blocks for thicknessing. Ultimately, I want to make a new bottom die that is a little taller and has a through hole for bolt on tooling die plates. For now, this is more than sufficient. Before I get too carried away and totally reconfigure the shaft setup, I needed a few solutions to the motor-shaft belt. However I tension the belt and camber the motor, when the system comes under load it wants to either throw the belt or slip on the shaft pulley. For the belt throwing issue, I added a pair of shifter forks just past the motor to keep it from flying off. Not the best solution long term but for now it does the job. Watching it in operation, it seems like the belt wanders only as the hammer comes up to speed then returns to center on the paper motor pulley. For the second issue of slippage, one of the things I learned scouring old texts is that tension is rarely the solution to belt slippage. Either increasing belt width, thickness, or contact around the circumference of the pulley are all more effective solutions. The only one of the three available was to add this idler to effectively force more belt contact around the pulley. Fortunately the motor mounting plate had a built in tension adjustment mechanism and it also had enough movement in it to slacken the belt enough for me to add in this idler. For now, again, it seems to do the job. Finally, and something I was not looking forward to, is the major issue of ram movement in relation to die closure. I made up the die spacer a while ago now as pertains to present day (where I just finished putting the hammer back together after this tremendously tedious endeavor) but the entirety of the time between then and now I have been thinking about this problem and possible solution. Observing the stacks of rubber discs I used as an improvised cushion solution for the four springs supporting the helve assembly, the amount of movement and compression due solely to the fact that the matting I used was the excess of the baseplate. Because it was the variety with little feet standoffs arrayed on one side, when cut into the discs that meant I lost roughly half the actual supported contact surface. I found a new mat that is flat on both sides and had the wonderful task of cutting out all the new ones manually. Since coming up short on the original ones I water jet at the old shop I knew I could do it but with how long it took to do those odd few I was in desperate search for a better solution. Enter the belt driven fever dream my world has become. Part of the eventual plan is to bring belt driven power to various other machines in the shop, chiefly the old drillpress. Looking at old catalogues, it seems that my particular drill was originally sold in two variations- one which is mine and has only a manual crank for power, and the exact same drill with a longer drive shaft to hold a step pulley on the outboard side of the flywheel. I have been puzzling over that for some time now on how to either adapt the existing shaft to somehow splice on something new, make an entirely new one, or replace the crank on the right side with the pulley and remove the manual option altogether. Until then, I used the old trick of adapting the lathe to be an improvised lineshaft which is in the perfect position to belt directly to the flywheel. Long term, if I were to use the flywheel as the drive wheel, I would need to roll a rim for it because the extreme crown of the casting is bad for belt longevity but for two days of circle cutting it did just the trick. Conveniently I had a pair of step pulleys handy and a bit of shafting that (!) already had a hole on one end that I used for tailstock support and all together was the exact right length for what I needed it to do. Even more impressive in the makeshift solution department is I had a bit of old leather belting that was just too short plus a baffling splice already laced which extended the length by only 2" or so (seen on the top of the flywheel). With that splice added to the belt length The pulley diameter options were between what would give enough tension to keep it from slipping under load so I wrapped masking tape around the smaller step until it was large enough to hold. Consequently for low power operations the tape surface was weirdly excellent at grabbing the grimy leather belt. Even automating the circle cutting, it took almost 2 days to cut enough for replacing just the bottom two cylinder stacks. Partially to avoid another 2 days breathing in the awful rubber fumes and partially because it might be better to actually have a different compression spring force on the upper cushions, I left it there. If it were just to swap the discs but otherwise leave the configuration the same, I would not have bothered. Although a bit springy, the hammer otherwise operated in a way that those particular nuances would not have been the only problem. However, in the long internal monologue on solving the ram height issue, the next and most promising fix was to shorten the bottom stack by one layer (and adding equivalent height to the top), effectively lowering the entire helve assembly. To do this, as I have learned to expect, it is never as simple as just doing that one thing. As witnessed by the impact marks on the frame casting, someone in the past must have done something similar to what I had in mind. The bolts holding the helve beams in place are too long to install from the bottom up, which I initially tried with no luck, but lowering the helve would make the longer nut and jam nut end contact the frame on the bolt closest to the cushions. This is where the real reluctance to do this comes in. To get into the area I had to take the ram back off, then hoist the back end of the helve up enough to get a bottle jack under the yoke, then lower the chain hoist carefully to leaver the helve beam up into the air. The maneuver involved an almost complete disassembly of the hammer's upper half but gave me just about exactly enough clearance to slip the back bolt in from the underside. The other two were far less of an issue and went in no problem, and so it was back to reassembly. Another bonus of taking the ram off the helve beams was a brief moment to inspect the wear on the wood-ram contact area. All in all, it was about what I expected and after more deliberation revealed something that I think will be both a solution and another arduous problem solving montage. By the time it all got back together and more adjusting back into some sort of balance between the belt's ability to turn over the eccentric and how far down the ram bottoms out, it is significantly better than it was before. Not perfect by any means, but a step in the right direction. Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted August 7 Author Posted August 7 Now for some final thoughts. I figured I'd put this in its own post to consolidate all the thoughts I have about getting the hammer actually running in a functional sense. I suppose most of this will be purely for posterity as the user-experience pool for the Jenkins and Lingle hammers is approaching 1... The two biggest issues I have at the moment are power and ram travel. Power is a half problem that I think I already have worked out as to the solution. Foremost, the motor I am using is 5hp, 3phase, and 1735RPM. The drive wheel is a roughly 4" paper pulley which is the appropriate material for this sort of thing, but this particular one is the singular pulley I was able to find that had a matching arbor size. It is not quite wide enough for a 4" belt so I have a 3" on it currently which is likely the source of the slipping and belt throwing issues. A wider, thicker belt would transmit power more efficiently and remove that linkage as a slipping clutch. I have another paper pulley that is somewhere between 8-9" and wide enough for a 4, possibly 5" belt. Replacing the current motor with a 3hp, 900rpm motor would give me 1.16 the amount of torque and the motors I've been able to find have the right frame size to receive the larger pulley. Strangely enough, swapping just that gives a nearly equivalent hammer speed after all the pulley ratios are taken into account. At full speed, currently the hammer would run at 266 RPM/ cycles per minute where according to the old 1889 catalogue it should be around 250. With the 900RPM motor and larger drive pulley, the same system would be at 301RPM. From what I gather, these lower speed motors were more common back in the day which makes sense after a fashion, and the lower RPM giving higher torque at the same rated power output is the real bonus. While on a road trip earlier this summer I took a wee 26hr detour to secure a bounty of various lineshaft parts so the whole extent of the long term plan is to run the larger paper pulley to a main linehsaft, then by way of a fast/loose pulley setup be able to selectively bring power to a countershaft which in turn runs the hammer. As it sits, while the motor is running the belt to the hammer is running so there is a constant source of wear on the belt which is eliminated only by turning off the motor at the VFD. Instead of controlling it electronically, the fast/loose pulley shifts a belt from the main lineshaft from a free spinning pulley (loose) to one that is keyed to the countershaft (fast) thus allowing the countershaft to be 'turned on' or 'turned off' using a pair of shifting forks like I have currently keeping the belt on the motor pulley. Adding in the countershaft also gives me the ability to more precisely control the hammer cycle speed because I have more pulleys to swap around for reduction ratios. This all is, however, a longer term problem that does not immediately need solving. Onto Problem 2. Having the ram come down and make contact with the bottom die, or close enough therein that the compression of the helve cushions allows for forging thin stock, is what I really need for the hammer to become useful. This style of hammer in particular does not have nearly the stroke length as some of the later mechanical hammers so I know that I am inherently limited by the throw of the eccentric cam as to how far the ram can move. That is a contributor to hammer power output, the other being cycle speed. During use and testing, I currently have the eccentric at the maximum throw to eliminate it as a variable, and even still the ram moves only 3-4" or so under power. Compared to a Little Giant style hammer or similar, it is almost nothing. That aside, achieving useful closure of the dies has led me into a series of problems which I am slowly beginning to understand. With the lower cushions shortened, the dies are much closer as expected. Adjusting the eccentric turnbuckle is the hammer's built in mechanism to adjust for material dimension. Lengthening the turnbuckle moves the entire ram stroke down, shortening it raises the ram stroke but does not change the actual length of the top and bottom limits. Up to the present, there has been a sort of limit as to how long I can push the turnbuckle before the eccentric/helve/ram linkage seizes. Prior to adjusting the cushion height, I ran it at the maximum length where the belt still had enough friction to turn over the drive shaft. After adjustment, I found that the turnbuckle had to be taken in even farther to avoid the seizing. At first I thought it was something to do with the eccentric clam shell linkage, as overtightening that has always been a concern as to the introduction of friction. However after loosening it to the point the lower half was making no contact at all, the problem persisted. Next up I tried the ram guides, thinking maybe somehow they were overtightened but similarly had no effect on how hard it was to turn over the drive shaft. It was then after remembering the wear patterns in the helve beam that I realized it was actually a function of the helve beam-ram interaction. It should have been a clue when I was putting it together the first time that the entire thing acted like a wedge. Part of it made sense since the metal helve tongue piece is wedge shaped so naturally there will be the inverse of that on the mating wooden surface. However, thinking about how most of the wear is on the rear end of the ram through hole means the length of beam through the ram should probably be parallel instead of having the slight taper narrowing towards the outside face. By lengthening the turnbuckle, the stroke is effectively trying to push more of the helve through the ram, causing it to jam at the lowest point of the cycle where the wood is physically resisting a sliding fit. The obvious solution would be to take the helve back apart and make the top and bottom parallel at the dimension of the ram through hole. Indeed, the way the ram casting is made suggests that the helve sort of rolls from the outside to inside face during a complete cycle with the neutral point at its height having the wood touching at the centre of the casting. The slight paraboloid surfaces make sense for that interaction. However! On the original bit of rotten beam that was my only clue as to what the beams should look like, there was an unidentified through hole on the bit that would sit just behind the ram. Based on other helve hammers, many of them have some sort of wear plate affixed to the beams so the wood does not get gradually abraded away. This is a possibility I was aware of and something I suspected might come up but not in this way. So the real question is this- What sort of wear plate goes into this style of hammer? I expect the mysterious hole in the old beam was the mechanism by which the old wear surface was attached. If I modify the current beam which was both expensive and incredibly labour intensive to make, I desperately want to not do something irrecoverable. If my idle speculation is correct, the beam is what is jamming the linkages and if I can overcome that then I MIGHT have the length of travel I need to bring the ram down to the bottom die. But even then I really do not have a way to know before doing it. If I simply remove a little material from the back end of the top and bottom surface I might have answers, but it is a good half a day of work to take it apart and put it back together which I am quickly growing tired of doing. Ultimately I think I will have to install some sort of sacrificial medium between wood and ram, whether it be bronze or old belting. Part of me hopes it will wear in and the problem will solve itself but that sounds like wishful thinking thinly disguising a self destruction sequence. Anyway, that's enough of this rambling speculation for now. Before doing much else to the hammer I'm going to work with it and see how it does at forging steel again. Cheers! John Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
Brian Dougherty Posted August 7 Posted August 7 Geeze John, once you get this one tuned to your liking, I think your next project should be to build a hammer from scratch -Brian
John Page Posted August 7 Author Posted August 7 At this point it's mostly a Hammer of Theseus! Not to spoil the party but I'm also concurrently building a treadle hammer from the trove of industrial scrap I have lying around. Although not quite as mechanically interesting as this one, it'll feature a 420lb Blacker Power Hammer anvil as the work surface with a few tricks involved to make the face, hardy holes, and horn all available depending on the work being done under the ram. The better part of today involved some more serious speculation on the operating limitations of the J&L and I think I have gleaned a bit more insight into the seizing. It just so happened that, when I made the helve beams, the ram was up on blocking at a height roughly equivalent to the neutral position of the cycle as it sat with the combination of equal cushion cylinder height (which I rediscovered last night in an old patent drawing that they are in theory all 4 supposed to be the same size) and whatever length I had the eccentric turnbuckle tie rod set to. Since the helve beams are a gradually tapered wedge shape, being in the neutral position during the fitment it, logically, worked fine with the ram at that specific height. The rocking motion of the helve against the hourglass shape of the ram through hole means the beam could rotate up and down freely during each half of the cycle in that position. However, extending the turnbuckle as I earlier suspected does try to push the beam farther through the ram hole. Yet that is not the main issue. Rather, since the ram is farther down with the helve yoke assembly at the same height, the beam is biased towards one position in the ram hourglass shape where the bottom front and top back edges are always trying to contact, and THAT is where the pinning is coming from. Looking back on earlier patent drawings, the front of the helve beam is totally hemispherical rather than the squared off cut that I used. Also of note the drawings depict a much shorter bit sticking out of the front of the ram which I presume facilitates more freedom of movement as the helve cycles up and down. Additionally on closer inspection the 1889 drawings have some sort of wear surface wrapping the end of the helve beam so I suspect figuring that out is also in my future. What this means for now is that I do, in fact, need to fully disassemble the ram and helve beams and reengage the very slow process of sneaking up on a reprofile of the beam ends. While I'm in there I might also adjust the top beam as it sits on the bottom. Currently there is a very slight difference in some mating geometry causing the very outermost end of the beams to not hold closed with any sort of pressure even with the leather pads. I think either the angle of the interface with the metal helve tongue or the halved angle where the two pieces come together (or both) is off by some minuscule measurement. That adjustment alone might be enough to give the ram what clearance it needs but I suspect I'll have to fully put it back together to find out. Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
Geoff Keyes Posted August 7 Posted August 7 In reference to your treadle hammer build, have you seen this? It might give you some useful ideas. g 1 "The worst day smithing is better than the best day working for someone else." I said that. If a thing is worth doing, it is worth doing badly. - - -G. K. Chesterton So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy. Grant Sarver
John Page Posted August 7 Author Posted August 7 Thanks for sharing that link, hadn't seen that before and clarifies a lot of the linkage mechanisms. The shock absorption spring is very clever and something I was trying to work out for the sake of my knees. Mine has a way to go before it's even remotely functional, at the moment it's mostly a pedestal with a pair of treadle arms hidden inside some large rectangular tubing, but no connections yet or ram/guide/upper assembly to speak of. I'll certainly be borrowing some of those linkage designs Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
John Page Posted August 8 Author Posted August 8 Indeed! Something like 10 hours of slowly whittling down the helve and reinstalling it with the ram and it seems like that issue is solved at last. It's remarkable how much easier it is to turn over the drive shaft now that it isn't binding on the lower end of the stroke. I previously figured it was just the working stiffness of all the linkages but here we are. Another interesting thing I learned is that the binding action of the helve beam through the ram was forcing the yoke assembly cushions to compress upwards, lifting that whole section which is what allowed the cycle to complete. In a sense, that is what those cushions are for after all, but rather a release mechanism for when there is relatively immovable hot metal between the dies so the frame does not take the stress (as opposed to the ram stopping its travel from the helve jamming). I'll put up some pictures of the adjustments eventually, but the interesting bit is I was able to see how far I had to go by how much of an angle the ram sat when the helve was fully lowered on the stroke. By keeping the ram guides off it was actually fairly quick to install and remove the ram aside from the fact that is is something like 165lbs of weight with the die installed. With the added visibility of the lines being out of parallel between ram and frame, the problem was actually quite obvious. However, there were previously no circumstances where I needed or wanted to install the ram sans guides so it was sort of hidden in plain sight. Of additional note, the way the treadle linkage in the above drawing is situated, the idler pushes back away from the ram but that is due to the fact that in most ordinary setups the flat belt would be running to a shaft behind the machine rather than in front. According to belt lore, the idler should always go on the slack side of the belt rather than the side bearing transmission from the motor or shaft/counter shaft. Think of it like an idler on a bicycle- one side of the chain is always under tension while the other has the slack. Having the idler on the slack side both gives more complete belt contact around the pulley circumference as well as works in conjunction with the way the belt experiences tension rather than against it. Because I have the unusual configuration of the lineshaft on the front end of the hammer (due to my shop space constraints) I need to have the idler on the back side of the hammer pressing towards the ram to keep the same tensioning configuration. Not that any of that means much to anyone but thought I'd put that out there in case this comes up for someone in the nebulous future. Not all those who wander are lost. -J.R.R. Tolkien -Shards of the Dark Age- my blog -Nine Worlds Workshop-
