Posted
On 8/7/2026 at 4:08 PM, Geoff Keyes said:
In reference to your treadle hammer build, have you seen this?  It might give you some useful ideas.
g
Holy cow, you took me back, Geoff. I miss Grant (and Terry, and Jim...)
One should keep in mind,
we are all both the blacksmith
and iron in the fire...
as always
peace and love
billyO
Posted
Billy,
I know, every time I look at Grant's videos it hits me.  Just before he died we were talking about whether you could use a VFD to make a mechanical hammer do single blows.  He said that he hadn't thought so, but that another smith had showed him how to make it work.  That was as far as we ever got, he died the next day.
I said that.
- - -G. K. Chesterton
Grant Sarver
After building my own power hammer with a VFD (see this thread), even if a bit weird one, I am a bit skeptical about that. At least for something helve style with springs. For best efficiency, you need a serious flywheel like a tire or the leaded disk in my machine and a VFD controlled motor will take a few seconds to spin it up or down.
For my machine I use an articulated con-rod to engage or disengage the helve arm(s), not a clutch. That works great and has a theoretical possibility for single blows. Alas, my pneumatic cylinder to do this takes a second and is not synchronized with the flywheel rotation. So I can do maybe 2 or 3 blows at a time.
If you overcome this with a faster cylinder and something to synchronize it you could surely do single blows.
However...with a resonant spring/mass system, it take always a few cycles to crank up to full blow power and a single blow might end up a bit wimpy.
If I was shooting for single blows, I would probably dig a trench for a 240V line to my garage/shop, buy a serious compressor and build a pneumatic power hammer. Not saying that I won't but that would be a bit crazy for my use.
Edited by Gert Burkhardt
  • 4 weeks later...
Posted
Here we are! Took a bit longer to film and edit than I expected, ran into a handful of unexpected issues and severe limitations due to how small my shop is. Turns out even with a 20mm lens, I still can't get physically far enough away to get the whole hammer in frame! At least not with the good camera... Also in the interim since last using it, all the settings defaulted to factory which I didn't catch the first time so I had to reshoot everything to get usable footage out of it. Either away it was fun to get the camera back in the shop and I'll likely do a lot more filming once the restoration is actually properly done. I'm waiting until the last bits of the linkage are made more permanent instead of the collection of shoddily welded bits and clamps on the brake. Also in watching the footage back it's much more obvious how not flat the floor is by the rocking. I'm going to try and sort out a shim or wooden platform to level things out a bit more. Also a curious discovery, the treadle is much more responsive from the brake side rather than the idle wheel side where I normally stand. In spite of going completely overboard on the material for the treadle, it still has enough torsional flexibility that the diagonal opposite corner to the brake causes a bit of spring action to releasing the brake before the eccentric can spin up. Also of note I swapped out the pulley on the lineshaft which connects the motor to the shaft to slow it down a bit more and have better traction for that belt. Ultimately I am still going to swap out the motor for a slower one with a larger drive pulley, and possibly some other modifications to the transmission setup but for now it is working well enough at (almost) full motor speed. Anywho, here's some footage of the hammer running! Now that I've put it to actual use on a few small production runs, I am confident that mechanically all is working smoothly.
  • Like 6
-Nine Worlds Workshop-
Posted
Sweet!!!
Enjoy!
as always
peace and love
billyO
Posted
A sight to behold. I have thoroughly enjoyed watching this saga. Thank you kindly for sharing it!
Posted
My pleasure! At least now that I can confidently say that it was a successful venture anyway! It has truly been a great experience to get into it and has opened a lot of doors I didn't even know existed prior to. More than anything, I think, it has been (and will continue to be) a vector into the world of old iron and antiquarian machine tools that is slowly taking over everything else in the best way possible. But it is not quite over yet! I am determined to see the restoration to the actual end instead of the functional end that it currently sits at. Although I've been using the hammer properly now for a few weeks and it would certainly continue to operate as is, I cannot leave several issues unsolved.
