Jim Piast Posted May 14, 2025 Posted May 14, 2025 Hello all, I've used my own DIY propane forge and burners, but the lightweight bricks are delicate and the burners are of varying effectiveness, so I'm ready for a professionally designed and manufactured forge. I want to forge weld and tinker with items as large as 3" x 5" x 12". What forges would you recommend? I'd like to keep this under $600. Thanks for the help! Jim
Alan Longmire Posted May 15, 2025 Posted May 15, 2025 A friend of mine has one of these: https://chileforge.com/forges_habanero_details.html and it's an excellent unit, but for the price (~$1,600!) I'd build a blown burner forge with two inches of kaowool topped with 1/2 inch of kast-o-lite 3000, plus a kiln shelf laying on the floor. If you're a good scrounger you can do that for around $70. If you prefer venturi burners, the now-discontinued Black Beauty from Anvilfire has blueprints to build your own: https://www.anvilfire.com/21centbs/products/P-75/ . They're discontinued because the owner died, but the concept is simple enough. They're far better than the usual DIY pipe reducer burners. 1
Jim Piast Posted May 15, 2025 Author Posted May 15, 2025 Thanks Alan! I was looking at the Atlas and Majestic 2-burner options, but was unsure of their reputation. Chileforge is sky high, as you mentioned. I never tried a blown burner. Are they more efficient and/or hotter than a Venturi type? I'll have to look into those. I made a mig tip style venturi burner, and then bought a stainless venturi type, and they both work OK but I couldn't reach welding temps in my latest iteration. I'll hit the beginners section to learn how to try your suggestions. $70 sounds better than $600. Thanks!
Alan Longmire Posted May 15, 2025 Posted May 15, 2025 Blown burners are infinitely tunable, and one will heat most any reasonable forge size. Hotter than venturi, not necessarily, since you are limited by the maximum flame temperature of a propane/air mix. More efficient? Maybe? The don't rely on gas pressure to induce air into the system, you just dump propane into the air stream via a 1/8" copper line with a needle valve for fine tuning. PSI is irrelevant, unlike with a venturi burner. Flow is the true measure, and as far as I've found nobody has done a side by side flow rate comparison between blown and venturi. The best thing about blown burners is the ability to really close down on the exhaust to increase heat, followed closely (some would say more importantly) the ability to tune the atmosphere to neutral or even reducing to eliminate scale/oxidation. This allows you to weld without flux and to avoid serious material loss to scale when making damascus billets. Also reduces the amount of grinding needed. I suggest this thread: and then this one to understand how a forge actually works: Your inability to weld in your homemade forge may be more of a forge design issue than a burner issue. 2
Carlos Lara Posted May 15, 2025 Posted May 15, 2025 I agree with Alan. I have a venturi type system (an also discontinued Mr. Volcano), and I can get it up to weld temps no problem, thanks to advice from here. More important is to run it reducing, otherwise it's hard to get the weld to stick, even if you use flux (run the venturi fairly closed, and close off most of the front and back of the forge up with bricks or what have you to reduce airflow and limit oxygen supply). Not to discourage you from getting a blown forge, but I think if your venturi forge is properly designed and set up, you should be able to do it. For your budget, it may make more sense to mod what you have than invest in something new. 1
billyO Posted May 16, 2025 Posted May 16, 2025 (edited) I agree with the above as well, and would only suggest one modification to what Alan said above, depending on how much metal you plan on heating up. I have 1" of castable over my kaowool, not 1/2". What I think this does is provide more thermal mass, and allows the billets to heat up quicker once the forge gets up to heat. I do recognize that the time to get the entire inside of the forge to welding temps is probably longer (about 30-40min), to me it's worth it, especially when welding up numerous billets at a time. My previous forge was a monster: 2-1/2" of castable, and once up to heat, I could turn the gas flow way down, barely burning, and maintain welding heats. Edited May 16, 2025 by billyO 2 One should keep in mind, we are all both the blacksmith and iron in the fire... as always peace and love billyO
Mike Jesensky Posted May 22, 2025 Posted May 22, 2025 Jim, I agree with Alan too. I started with a venturi and went to blown and also ribbon burner after dissatisfaction with the one hot spot the venturi gives and the noise it makes. I would suggest to add your location and maybe someone is near with a nice forge you could see or maybe help you get a nicer one made.I do see there are forges for sale places ,but before everyone got on tv ,we all made our forges. It is 2" inches of inswool with rigidizer painted on and a burner with fan. I'd say look around and read for a couple days,I dont think theres an inexpensive off the net answer to your situation. If you,re in Pittsburgh I can help you,$600 is more than I used on mine even if i bought the pieces today,I didnt check if inswool is tariffed tho.
