Posted
Hello!
This will be my take on the Seax of Beagnoth in an attempt to create a showpiece for people to handle and feel at a festival I'm a vendor at.  The hope is to create a touchable work from history, rather than to be 100% accurate with construction and materials, if that makes any sense. (more usable as a learning object, less postable in "The Seax Files")
As always, just because we're in show and tell does not mean I don't want your advice, tips, tricks, and evaluations.  Please Feel free to chime in, I'm here to learn!
The blade is forged and ground to shape from 1065 using measurements found on the British Museum's entry.
I really struggled with the tip shape for some reason... It also ended up with a larger shoulder at the tang than I wanted, but I wasn't paying enough attention when isolating that section.
Next came scraping in a fuller.  I opted to use the tool I received in a KITH a couple years ago again, this time opting to add a small brass guide block and going back to smooth it out with a rotary tool.
I then went back over the flats with the grinder up to a Trizact A45 belt. The hope is to create a nicer surface so that after the inlay I don't have to do much cleanup grinding, just hand-sanding.
Then some inlay practice and material selection.  I'm aware many if not all of the original lines of inlay use Gold and/or Silver, but neither of those are in the budget for me for now, so Bronze, Copper, or Brass it is!
After looking at the different colors I like the Bronze best (top line), so that's what I'll be using since I have plenty on hand at the moment. I'm thinking I may use copper for the triangles and dots though...
Lots of drawing and checking and sketching with Sharpies later we have a general guideline!
I'm very new to this inlay stuff, so this is quite an undertaking for me, but I figure with all the straight lines it'll be good practice for me. :lol:
So with my gravers and small hammer in hand, and nothing in my head, I set forth on the first line!
And it took me FOREVER! All-in-all probably around 4 hours for a very not straight line using a flat graver and a small onglette to raise burrs in the channel.
I opted to leave it not ground down yet except for the very end, probing it every inch or so to make sure it doesn't come out of the channel.  My thought is to grind/file it all down at the same time to reduce the amount of finish work needed on the flats.
After the long grueling process of one very long line, I'm starting in on the Runes and taking on the corresponding outline lines as I move further down.  I started marking the top of my graver with red paint to give more contrast so I go cross-eyed a little less, seems to be working so far.   It also helps when I go to stone the graver to make sure I'm working in the right spot, and of course marking where there's still work to be done prior to inlay.  Real multipurpose tool, that red paint:ph34r::lol:
(who needs straight lines?!:rolleyes: What's a big squiggle here, there, and everywhere?! LOL!)
That's where I'm at now for now.  This is quite the learning curve, and I'll be happy with any kind of progress done by the time the festival rolls around in August.:lol::D
  • Like 8
Posted
Great job! I just did my first inlay on a blade yesterday. That was only a few cm on each side, and that already took a fair amount of time. I used the same flat engraver to also raise burs in the channel. I've not seen evidence of this on original blades. From what I could see in the very corroded state was just V grooves. But that was just on one longsax.
P.s. no gold was used on the original. Only copper, silver and copper alloy (not modern brass, that's far too high in zinc). It appears that they were using left over bits, as the combinations are quite random and changing.
Jeroen Zuiderwijk
Posted
Thank You Jeroen, I really look up to your work so that means a lot coming from you!
You're right!  I just looked at the Museum entry I linked and even they have it listed as Copper, Silver, and "brass", LOL!  I'm not sure where Gold got in my head.:blink:
Posted
This is looking really good so far. Blade inlay is on my list of things to try, and I very much appreciate the WIP pics.
2 hours ago, Jeroen Zuiderwijk said:
Todd has a nice write up on the inlay work: https://todsworkshop.com/blogs/blog/reproducing-the-seax-of-beagnoth Very educational.
Bookmarked for future reference!
Posted
Nice!  You only get better by being ambitious, and I think has really boosted your skill level.  VERY well done!
Posted
Nice work so far, and always glad to see a reproduction of this blade. I also ended doing something similar with with guide on my scraping tool, though yours looks sturdier than the wooden attachment I made.
I was lucky enough to see the blade myself last fall, you can see some of the grooves where inlay has fallen out, and get a rough sense of the groove shape.
I’ve done a couple of blades and a few test pieces with with inlay and there was a lot of trial and error. It may have been obvious to you, but at first I was trying to cut basically to full depth in one go, only to realize that 2-3 passes allowed for a lot more control. For twists, the depth is super important. In my picture you can see grooves that were too deep or too shallow.
I used the same kind of gravers to cut the grooves, but I used a set of homemade chisels to raise the lip on the side, you can see one in the second photo. It’s a super simple chisel, ground do have a “long” bevel on one side, and a “short” one on the other. It’s the same I use for kata-kiri and nunome zogan. The wider tip makes it a bit easier to keep the edges of the groove straight and even.
I look forward to seeing how this goes!
  • Like 3
13 hours ago, Jeroen Zuiderwijk said:
P.s. did you see the reproduction Todd and Owen did?
Thank You for the link! I remember hearing about it but not looking too hard to find it and then of course forgetting all about it..:ph34r::lol:
I'll be reading that several times over
Thanks Joshua, I'm learning just how much time is spent freshening up the graver as opposed to actually graving anything, lol!
I really appreciate the compliment Alan!  I'll be curious to see what kind of difference there is between the first side engraving and the 2nd side, if any.
Thank You for the photos Aiden!  I too tried chunking out the full depth on the first pass on a few test pieces, but after several broken graver tips I found I spent less time sharpening the graver if I spent the time to do multiple passes.
I will absolutely need to make one of these chisels to raise the lip.  I was just using my flat graver and doing a very gentle pass on either side of the inside of the channel to approximate this process, but I'm thinking the chisel will be a much better option, lol!
Edited by Jaron Martindale
