michaelHope Posted June 15, 2025 Posted June 15, 2025 Sorry for the crude drawing I am undecided if I want to use a purple material or mother of pearl on sections of the handle.
Joshua States Posted July 22, 2025 Posted July 22, 2025 The flat line at the front of the handle where the index finger sits should be more of a curve or it will not be comfortable. That curve should go from the tip of the guard to the point at the belly of the handle with the apex of the curve in line with the bottom of the ricasso. The handle point might move back a little as well and make a more shallow and smoother curve. You should probably put more of a bird head at the handle heel as well. If any of that sounds like gibberish, check out the Beginner's challenge projects, and look at the first knife. Also check out this photo of a similar knife I made in 2020. It is also a through tang with threaded pommel. You will want to grind and shape this handle off the blade. So, check out this thread on how to hold all those pieces together while you shape that handle. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Geoff Keyes Posted July 22, 2025 Posted July 22, 2025 I think you're going to find that the area just in front of the bulge is too close to the guard. It will pinch your finger. Joshua's handle had the swell much farther back which hit's you between your 2nd and 3rd fingers, which I find a lot more comfy. g "The worst day smithing is better than the best day working for someone else." I said that. If a thing is worth doing, it is worth doing badly. - - -G. K. Chesterton So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy. Grant Sarver
michaelHope Posted July 22, 2025 Author Posted July 22, 2025 Thank you, I will play around with the shape more.
