Posted
Hi, I just got 15 high temp soft firebrick for a kiln. They have been sitting outside for the last 15 years so they have soaked up a lot of water. They are not disintegrated at all. I have been experimenting baking them at a low heat to remove moisture. Any tricks for that? I'm making a new ribbon burner. What are some good ways to make a new burner without casting one? I made one by drilling out a hard fire Rick and that worked well. Will the soft hold up or are there other methods? Thanks!
I would build a charcoal fire (lump charcoal, not briquettes) and let them soak for several hours, rebuilding the fire as needed.
Have you considered stainless steel for a ribbon burner?  Maybe you could repurpose a turkey cooker burner.
G
Edited by Geoff Keyes
I said that.
- - -G. K. Chesterton
Grant Sarver
Posted
Gotcha! Not sure what uoure meaning about a stainless steel ribbon burner. Like the holes?
Posted
Get a chunk of stainless tube, cap the ends and run a fan into it.  Drill a line of holes in the tube and bed that in a floor of refractory material.  It will get hot, but the stainless steel should be able to take it.
g
I said that.
Grant Sarver
