Hi everybody! So I have a damascus knife in the works, and as I was sanding the blade, I noticed that at the edge there was a sort of silvery line that followed the pattern. (it's hard to describe). I only saw it at 1000 grit. while I could see glimpses of the pattern in places on the blade, this looked distinctively different. could it be a delimitation? I'll try to take a photo, but it's very hard to capture it. It is not something readily visible. The damascus was from my mentor, and I forged the blade and heat treated it.
Edited by Spencer Phillipson
Posted
Apologies for the pic! I know I looks like a sanding scratch but it is not! It’s that very tiny lighter colored line within the circle. Like I said, this “follows”the pattern.image.jpeg
Posted
I can't see anything from the pic, but delamination shows up as a black line, not a silvery one.  Might be a bit of decarb between layers, though.  That shows up as a white line. Most likely nothing to worry about.
Posted
That photo was an exceptionally bad one :ph34r:. Yes it looks like a slivery- white line. If that's what it is, that's a relief.
Posted
It doesnt look like there is anything there.  but really hard to tell from your photo.  If this is already quenched (and it looks like it based on where you are in the project), I would say its not anything to worry about.  I personally have found the quench will often "widen" the gap.  You could also do a "test" etch if you are really worried.  As Alan said, this will make the delam dark.
Bob Bryenton
Solar Storm
https://www.solarstorm.ca
bob@solarstorm.ca
Posted
Why, pray tell, are you sanding to 1000 grit?
Posted
Because (this is my assumption) a higher polish results in a better finish for Damascus(?). I actually went to 2000 grit in the photo, but the two little lines saw I only saw them at 1000.
Posted
If I'm going to etch a damascus blade I stop at 400, then hit the high spots with 600 afterwards.  The etch itself erases the fine polish.
Posted
Yup, +1
-Brian
Same here.
I stop at 400 on 90% or more of the knives I make, especially Damascus. I hit the high spots with 800 for a slightly brighter finish.
If I am doing a Hamon, I stop at either 600 or 800.
Posted
Stop @ 400 pre-etch +3. Post etch I use 2000 or 5000 grit for the high spots
Don't ask me why, it might be just because I have it.
One should keep in mind,
we are all both the blacksmith
and iron in the fire...
as always
peace and love
billyO
Posted
I would go ahead and etch it and see what you get.  If  you don't like it, sand it back to 600 and give it another go.  At the very least you'll learn something.
g
I said that.
- - -G. K. Chesterton
Grant Sarver
Posted
I'd leave it.
You might try just a coffee etch first to see what happens.  I've done that at a relatively high polish and liked the deep reflective blacks I got.  The finish won't be as durable without the little bit of topology that comes from a ferric etch, but you may like it, and you can always etch with ferric afterwards if you don't.
-Brian
Posted
Geeze...you guys go up to 400 then etch?? I stop at 240...hit it with a sisal buff using a emery/oil slurry,,degrease then etch..
  • Haha 1
If you wish to know the price of freedom..Visit a Veteran's Hospital...I am humbled by their sacrifice...
Why is it when the Mighty Thor throws his hammer he is dispensing Justice and fighting Evil..BUT..when I throw my hammer I wind up in a mandatory 16 week anger management course??</p>
I came into this world naked, screaming and covered in someone else's blood...I have no problem going out the same way...
Posted
Yeah, but your finish off a 36-grit belt looks better than my hand polished 400-grit finish :P
-Brian
BD: That's cause I don't use as 36 grit belt. I use a 40 grit one..Those extra 4 grits make all the difference..
Then again I do the same thing with high carbon...grind to 240 (or 220 if that's what I have)...gives a nice semi-satin look.. then go to my sisal wheel with the black emery and throw a coat of oil on the blade and buff away,  It cuts nice and leaves a rather attractive semi-glossy finish.. Just don't overdo it cause you can roll the grind lines..
I can see no "need" to put in all that extra tie to mirror polish a carbon steel blade cause the first time you cut anything like fruit..cheese..certain critter parts it turns colours and there goes the mirror polish...
Edited by JPH
Posted
:lol:
I don't quite have the knack yet to make a 220 grit finish look intentional on a big blade.  However, I agree with all your points.
-Brian
Posted
I've seen that buffing is kind of a generational thing, in that only pro makers who started before about 2000 do it.  I put that down to several factors, not least the expense of a big Baldor or two.  Then there are all the horror stories about buffers being the most dangerous machine in the shop.  I agree it is, but not if you use it correctly.  We (those of us who use them) all have stories about getting stuff whipped out of our hands and thrown across the shop hard enough to crack a cinderblock.  I bought mine when I was making pipes, and it sure threw a few of those before I figured it out!  I don't use it on blades very often because I tend to round over the crisp lines I spent such effort putting there in the first place.
Then around 2000 or so, the satin finish came in in a big way, and we all started hand-sanding.  Takes forever, still easy to lose fingers, but less expensive to buy the equipment and it won't throw a blade at your head/toes/chest.  :lol:  Easier for the beginner, anyway.
Alan:
Well I have a whopping 1/3hp buffer at 1750rpm..why? Cause it doesn't rip what I am working o out of my hand and send it back at me with a murderous intent..
Edit: Something I just caught>> "I've seen that buffing is kind of a generational thing, in that only pro makers who started before about 2000 do it"..
Alan are calling me  "old".. well are ya? If you are I'll give you a good trouncing as soon as I put in my teeth, find my cane and work my way around all the empty geritol bottles... Damn kids...these young whippersnappers need to learn to respect their elders..
JP (not only over the hill ..I'm halfway up the next rise) H
Edited by JPH
  • Haha 2
Posted
Heavens, no!  Far be it from me to suggest you have more years under your belt than I do (even though you do! :P), I was merely remembering the old print knifemaking supply catalogs that all used to carry buffers, wheels, and compounds, while now you have to look pretty hard for them. I would have been using one from the start (along with a Wilton Square Wheel or a Bader B2) if I'd started making knives a year or two earlier than I did.  I made my first one at age 31, lo these 24 years ago...
I too have a 1/3hp slow-speed buffer for safety reasons, and it has thrown pipe bowls at me more than once.  Something about a loose muslin wheel charged with fresh White Diamond compound gets sticky when it hits briar wood. But boy, does it make it slick.
Posted
Alan is only 55??  Sheesh.  I'm on a forum with buncha young'ens!  *contemplates while chewin tabbaky*
  • Haha 1
Posted
" I'm on a forum with buncha young'ens!  *contemplates while chewin tabbaky*"
Tell me about it...I met the GRANDSON of a man I served with when I was in SE Asia all those years ago..  damn..time slips by..
JPH
