Eric Bohnstedt Posted September 3, 2025 Posted September 3, 2025 Hi all, I started this in Design and Critique (link), but now that the design, the re-design and the re-re-design are finalised, I feel like this is a more appropriate space for this project. Here is a little recap of the project so far: Disclaimer: First off, I'll just reiterate that this is my very first time making anything close to a sword (only made scabbards before) and I do not have any of the material required to actually forge anything. This is more of an "artistic" endeavour to make a "sword-like object". The blade I used for this project is a pretty crappy one, taken from an old bad replica of the sword of Achilles from the movie Troy (2004) for which I paid way too much as a teenager. So, yes this is not going to be a practical sword or even a sword at all. The steel is stainless and not heat treated, the tang is too thin, there is no distal taper and it is not peened and will be held together by a thread (I just don't have the space or the material to peen anything). But it will allow me to learn some new things like filling a blade, grinding fullers, making wax models, working with brass, etc. And it is really fun, so I guess that is a good enough reason. Background: This sword is intended as a part of the world of GRR Martin. In this world, the ancient empire of Valyria rose to power in the east through their taming of dragons. It has been speculated (and mostly confirmed in the House of the Dragon TV show) that Valyrians first tamed dragons through blood magic. As part of the ritual, a member of the family would be sacrificed and their being would be bound to the dragons, allowing members of their bloodline to tame the dragons. This is would explain the incest among Valyrian families. This blade would therefore be a sacrificial sword, used for this purpose (you can actually see such a scene in the opening credits of season 2), hence its name, Anogar, which means Blood in High Valyrian. I really liked this theory because it adds something super dark to what would otherwise be "oh look a big lizard pony, let me hop on it". Work already done: In the other thread I already covered the following: Inspirations Design Wax models New blade profile First version of the brass hilt components Re-design of the blade Shortening of the grip to make it more akin to the dimensions of a cinquedea or even the grip length of a gladius. Now for the new updates: I decided to completely redo the grip out of African blackwood. I chose this material because it gives a more ancient feel than the leather wrap. In the lore, Valyria is strongly inspired by the Roman empire, so it made more sense to be closer to a gladius handle. Also I like the defined shape. It is just very comfortable and blends nicely with the hilt parts. I also made the scabbard core out of veneer and wrapped in linen cloth for durability. This was the first time I used PVA glue instead of hide glue to attache the linen and I was very happy with it. It is a lot cleaner that way (unfortunately I forgot to take a picture before I started doodling tooling ideas on the linen). I then slightly reworked the brass parts, thinning them down to adjust the balance of the sword and to make them fit better with the grip and the reworked blade profile. I ended up losing a lot of weight which I am very happy with. I was initially a bit worried about the weight of the blade when I cut the blank as it was 606g. But after a lot of filling and refining it is not at a decent 430g. The fullers definitely helped a lot. I did quite a bit of work on texturing the brass with a small carbide burr, which was supremely satisfying. Finally, I have now wrapped the scabbard in leather, which will soon be tooled to mimic dragon scales. Getting the leather to neatly stretch over the mouth of the scabbard was a bit of a challenge but it worked alright in the end. I hope to move a bit faster in the coming week or so. 5
Alex Jemetz Posted September 3, 2025 Posted September 3, 2025 I like that there is a story to the fantasy blade you are creating Eric. Did you pour the brass guard and pommel yourself? Would love to see if you used the lost-wax casting process and how you did it.
Eric Bohnstedt Posted September 3, 2025 Author Posted September 3, 2025 1 hour ago, Alex Jemetz said: I like that there is a story to the fantasy blade you are creating Eric. Did you pour the brass guard and pommel yourself? Would love to see if you used the lost-wax casting process and how you did it. Thanks Alex. I find it very helpful to write a bit of lore around all the things I do. It really helps me with the design phase. And it gives me something to refer back to if I feel like I'm losing my way, if that makes sense. Regarding the brass parts, I made it out of jewelers blue wax and sent them to a guy here in the UK who does sandcasting. It's not as detailed as lost wax but I didn't really need that. And it was a lot cheaper. Also I like the fact that I get to keep the wax models.
Alex Jemetz Posted September 4, 2025 Posted September 4, 2025 Thanks for your reply. Cool that you have a guy that can cast stuff for you. I just wanted to learn from anyone else experience in lost-wax casting as I just did a few practice casts and a saber hilt in my home forge. The issue I had with the hilt was I didn't get all of the wax out and the mold wasn't at a high enough temperature when I poured the brass so I had some small voids in the piece. It did come out decent enough to use on the saber... 1
Eric Bohnstedt Posted September 4, 2025 Author Posted September 4, 2025 3 hours ago, Alex Jemetz said: Thanks for your reply. Cool that you have a guy that can cast stuff for you. I just wanted to learn from anyone else experience in lost-wax casting as I just did a few practice casts and a saber hilt in my home forge. The issue I had with the hilt was I didn't get all of the wax out and the mold wasn't at a high enough temperature when I poured the brass so I had some small voids in the piece. It did come out decent enough to use on the saber... Yes I have been following your thread. It look really good. Personally, I think a few imperfections are what gives the piece character. Obsession with absolute perfection is a pretty modern thing, but people are not machines and we make small mistakes and slip up occasionally. 1
Alex Jemetz Posted September 5, 2025 Posted September 5, 2025 I appreciate your view Eric, my philosophy in making things in the forge is that I want the look to be hand made with some (unintended) imperfections. I can buy ready made replicas of very attractive medieval weapons for much less money than the equivalent of my time spent making them, but I want something more authentic in appearance and in how it was made... 2
Eric Bohnstedt Posted September 11, 2025 Author Posted September 11, 2025 Update: The scabbard has now been tooled. The design is meant to look like dragon scales and extends to the back of the scabbard. I did little cuts on the sides to look like the belly of a snake. Pretty happy with it overall, especially with the way the scales get progressively smaller. That's done by always having the same amount of scales on each row. I also added the Valyrian glyphs created by David Peterson for House of the Dragon and represent the song "Haros Bartossi", which is used in the show to tame dragons. I only have the first and fourth stanzas but have reached out to David to see if he wrote the other two. Not the biggest issue but would be nice to have them and put the elsewhere on the scabbard. The song is the main hint pointing to the blood ritual around dragon binding so it felt pretty important to have. Also did a bit of polishing on the blade. It looks decent now. We are getting there! 3
Eric Bohnstedt Posted September 16, 2025 Author Posted September 16, 2025 Update: First fit before getting started on the finish of the brass pieces. All very shiny for now, but I'll look to age the brass and add a patina using some vinegar and salt solution and see where this takes me. Not sure what I want to do with the blade yet. I quite like the high polish but it might clash with the hilt furniture and the overall idea of an ancient sword. I might try and get myself some patina solution for steel. I have threaded the end of the tang and with do some final adjustments later. Not the most solid, but it is meant to be a display piece for me, so not super fussed about this. Would have loved to peen it, but the equipment is lacking. Next, patina, final fit, scabbard dye and beginning work on the chape. 5
Joshua States Posted September 16, 2025 Posted September 16, 2025 This came out fantastic. I really like the use of runes in the blade hardware and sheath. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Alex Jemetz Posted September 16, 2025 Posted September 16, 2025 On 9/11/2025 at 4:22 AM, Eric Bohnstedt said: Update: The scabbard has now been tooled. The design is meant to look like dragon scales and extends to the back of the scabbard. I did little cuts on the sides to look like the belly of a snake. Pretty happy with it overall, especially with the way the scales get progressively smaller. That's done by always having the same amount of scales on each row. I also added the Valyrian glyphs created by David Peterson for House of the Dragon and represent the song "Haros Bartossi", which is used in the show to tame dragons. I only have the first and fourth stanzas but have reached out to David to see if he wrote the other two. Not the biggest issue but would be nice to have them and put the elsewhere on the scabbard. The song is the main hint pointing to the blood ritual around dragon binding so it felt pretty important to have. Also did a bit of polishing on the blade. It looks decent now. We are getting there! Outstanding work and I love the Valyrian glyphs! Super authentic!
Eric Bohnstedt Posted September 17, 2025 Author Posted September 17, 2025 23 hours ago, Joshua States said: This came out fantastic. I really like the use of runes in the blade hardware and sheath. 21 hours ago, Alex Jemetz said: Outstanding work and I love the Valyrian glyphs! Super authentic! Thank you both! Yes that was quite a learning curve, especially when it came to the brass pieces. It is not as clean as I would have hoped, mainly due to me trying a lot of different techniques. But in a way it works with the lore of the piece and makes it look old. For the leather I also tested a few different techniques to get the glyphs properly printed into it. You can actually see some misses on the top right of the scabbard, where I tried to carve the glyphs with a hot awl, which gave the desired depth but not the crispness of the lines. I eventually settled on using tiny flat head screwdrivers (essentially like a chisel) and it worked really well. 1
Eric Bohnstedt Posted September 22, 2025 Author Posted September 22, 2025 Update: Really good progress and expecting to do the final assembly this week! In the meantime, the finish and patina have been done on the hilt pieces and the blade. I'm very happy with it. Here are a few nicer pictures for when I eventually decide to get an instagram page... The guard The pommel The grip The tiny peen block (which really was fun to make) And the pre-assembled hilt! 4
Eric Bohnstedt Posted December 23, 2025 Author Posted December 23, 2025 Last steps: The sword has been put together for a while, but I am waiting to fully finish the scabbard to post the picture. Now we are getting there with the last touches on the scabbard chape. I carved it in blue wax and had it cast in brass by A Wardle & Co (a UK company recommended to me by Peter Johnsson). They worked so fast and sent me the unpolished piece as requested (along with a couple of other ones for another sword). Polishing is underway and so additional step are still needed to age and distress it a bit. But we are almost there! 2
Eric Estlund Posted December 23, 2025 Posted December 23, 2025 Fun details 1 Eric Estlund WinterCutlery.com IG @wintercutlery
Joshua States Posted December 24, 2025 Posted December 24, 2025 This is going to be epic. I love, love, love, when new pieces look like they were transported through time to today. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Eric Bohnstedt Posted December 26, 2025 Author Posted December 26, 2025 We are there! Chape is done and aged. Will post photos of the full set when the sun decides to show up again! I left some scratches on purpose to make it look a bit more weathered. I might give it a few hits later if I feel like it should have more. 4
Eric Bohnstedt Posted December 29, 2025 Author Posted December 29, 2025 Here we are at last! Some final pictures and description of this short sword I have made using a repurposed blade I had from old times. This project started in September 2024, while spending time in my family home in France, rummaging through old stuff and finding a very poorly made replica of the sword of Achilles from the movie Troy. The blade was 420 Stainless and atrociously heavy. But I was looking for something to do in my spare time and though I could turn it into a nice decorative piece. As a big fan of A Song of Ice and Fire, I was tempted to make something that would fit in this world. I was always fascinated by the concept of lost worlds and civilisations so it felt obvious to make something that would fit in the ancient civilisation of Valyrian, which is inspired by many real world myths like Atlantis, but also by real cultures like the Roman empire. On the back of this I decided to make a little backstory for the sword: "The blade named Anogar, meaning Blood in High Valyrian, was long lost to time. It re-emerged during the Century of Blood, which followed the Doom of Valyria, when a trading galley travelling from Qarth to Volantis picked up a madman clinging to driftwood in the Smoking Sea. The man was covered in boils and rambling about the ruins of Valyria, which prompted the Volantene captain to order him thrown overboard along with all his possessions. However, the young sailor in charge of disposing of the man's meagre possessions noticed a strange looking sword wrapped in the remains of a crimson and gold banner. He hid the package under a pile of ropes and upon arriving in Volantis, he headed to a tavern to brag about his discovery. A mysterious man purchased his story and the blade and the sailor was later found in an alley with his throat slashed. The blade disappeared again and became a sailor's tale, with men claiming it was a cursed item passing the Doom to whoever holds it. In 45 BC, the diary of a dying Maester of the Citadel of Oldtown was found by his apprentice. Among other accounts of the maester's travels in the East, the diary held a description of the blade and the scabbard, along with a translation of the ancient glyphs. When the apprentice enquired about the whereabouts of the blade to the Archmaester, he was order to never mention or think about it ever again. Yet the words on the guard and scabbard remained etched in his mind: "From my voice, the fires have spoken and the price has been paid with blood magic". Now for more practical, less nerdy considerations, here are the sword's dimensions: Total length: 550mm Blade length: 440mm Blade width: 78mm Weight: 810g Material: 420 stainless steel (blade), aged brass (hilt and chape), African blackwood (grip) and leather over birch veneer (scabbard). Now a few final pictures. I hope you guys enjoy it! I certainly enjoyed making it. And even if it is not really practical, I learned a lot of new skills that I will hopefully reuse for a practical sword as soon as I acquire the right equipment and skills. 5
Rob Toneguzzo Posted December 29, 2025 Posted December 29, 2025 Amazing work. Great to see the progress shots. I love this stuff "Old dogs care about you even when you make mistakes" - Tom HALL - Old Dogs, Children and Watermelon wine.
