Posted
Hello All,
I’m newish here and have only been forging blades for a little over a year and need some help understanding what I’m doing wrong.
I’ve been trying canister damascus and I’ve failed 5 times. I’m using 1/8 walled square stock of 1.25 inch, with 1090 + 4% nickel and 3/8 ball bearings. The first two try’s did not weld at all and the can busted. I figured out my issue and the next 3 try’s ended up with multiple cracks in the millet. I don’t have a way to accurately measure the temp but between each heating the metal is yellow and feels soft at the beginning and then solid after some consolidating. I don’t have a press so all hammering is done by hand. I hammer all sides too, not just the sides.  Please see pics of the billets after I opened the cans. Any help on what I am doing wrong would be greatly appreciated. I’m beginning to think I’m heating the metal too much but I don’t really believe that makes any sense. I know 52100 is challenging but I need help figuring it out.
Note. I’ve ground down some of the small chunks of the failed billets to see if the ball bearings forged to the powder. I can see where the bearings are in the billet but they look like they are welded to the powder ok.  Why am I getting multiple cracks in the billet instead of one whole piece?
These pics are of the last couple failed billets
Good afternoon, Lorrenzo.  Welcome to Bladesmiths Forum.  If you put your location, perhaps a local smith could help, but I'll share my experience.   It looks like there could be a number of things going on here.
IMO, when doing canisters, it's really not possible to get it too hot in a home forge.  And when forging, don't forget how the steel cools, the surface will cool down first. So that might be the issue.  When I do a can, and I think that it's up to heat, I'll let it soak another 20-30 minutes or more before doing the initial compression.  Here's a picture of my last can, and as you can see on the top, I let it get a bit too cool and it didn't completely weld in a couple of places there.
How many damascus billets/how much experience forge-welding do you have?
Are there any chunks that welded solid?
You need to think about is how steel moves under each blow.  What directions and how far it moves is key to forge-welding.  You want the steel to compress together, not shear (or slide across).  With every hammer blow, you compress everything directly under the blow, but it also squishes out to the sides, and this is the shear/sliding that I was talking about above.   So it's also possible that's what you are seeing with your billet.
Doing canister by hand is not going to be easy, and I'm not sure I'd ever try.  If I had a striker or two and a big enough flatter, then maybe. I'd use a press/hammer with large enough dies to forge the entire billet. If I were doing a square can, I'd use a V swage and V top tool so that the can would compress equally from 2 directions.
When doing rectangular shaped cans, I make a simple, but significant modification to my can,  Thinking on how steel moves depending on the force of the blow, if the end caps are thick enough, these will upset giving the powder/billet compression form every direction.  Here's a pic of a similar can of the billet above:2.jpg
Edited by billyO
One should keep in mind,
we are all both the blacksmith
and iron in the fire...
as always
peace and love
billyO
Posted
Can you cut the billet in half lengthwise, sand then etch?  That'll tell you what parts are welded,  It could look welded, but still be porous.
as always
peace and love
billyO
Posted
To add to what Billy said,  trying cannister without a press means you need a much shorter cannister.  It's pretty important to get the first welds set on the first heat before the can cracks and lets oxygen in.
Posted
Another thing to remember when you use powder in a can is you need to vibrate that can a little to consolidate the powder.
I usually fill the can with whatever solid stuff I'm putting in it and add the powder to fill the gaps. Then I take a small piece of plywood and put it in a vice that has horizontal jaws. I put the loaded can on the plywood and hold an orbital sander under the plywood. This vibrates the powder and reduces the visible powder volume in the can.  Add more powder, repeat the vibration until it doesn't reduce anymore. If I don't do this, that airspace in the powder will oxidize enough to bugger the weld.
