Asa Newsome Posted December 1, 2025 Posted December 1, 2025 I am currently in the process of making my own heat treat set up, specifically for swords. I used to do all my heat treating in a Cress oven with digital controls, but it recently went kaput and I need a temp set up until I can get said Cress back up and running. I saw a lot of good posts on this forum about using a 55 gal drum which allows for a vertical soak of a hanging blade. I have already created a burner, but am unsure of what PSI to run at. I normally use 5-9 psi for basic forging and 5psi seems to be a good place to start, but came here for some enlightenment since I really only need to achieve 1500-1600 F over a short span of time. Also working on a PID control system. Some of you guys on this forum can make the coolest things.
Alan Longmire Posted December 1, 2025 Posted December 1, 2025 I don't have a gauge on mine, but probably 5 psi will do it. It's a soft hiss, no roar at all. I use a pyrometer to tune it. 1
Asa Newsome Posted December 2, 2025 Author Posted December 2, 2025 Thanks! Hope to be able to test this soon.
Joshua States Posted December 18, 2025 Posted December 18, 2025 On 12/2/2025 at 7:09 AM, Asa Newsome said: Hope to be able to test this soon. My vertical sword forge uses two thermocouples set at roughly 1/4 the height up from the bottom, even with the burner, and a second one about 1/3 the way down from the top. I use a smaller tank than the 55-gallon barrel though. It tends to get a little hotter in the top half. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Asa Newsome Posted December 24, 2025 Author Posted December 24, 2025 Thanks for the info! I am currently working on a PID system to ensure an accurate heat. I was able to test this setting at 6 PSI. In a 55gal drum, the burner is offset at an angle about 7cm from the bottom. All sides are covered in 2" kaowool, and top and bottom are 1". At 6 PSI and a gap of about .09" on my venturi burner, it took about 8 min to preheat the drum, and about 4-5 min for the blade to get up to 1550 F. The steel was 5160, hardness at quench was 60-61 HRC. I would say the test was a great success, but I would love to have a thermocouple set up like yours and others I have seen so I know exactly what the temp is inside the drum rather than having to go off a color spectrum.
Dan Hertzson Posted December 26, 2025 Posted December 26, 2025 In addition to varying the input gas air mixture, some of the fine tuning adjustabiliy on a Fogg style gas fired vertical drum heat treat "oven" can also be achieved by how the exhaust is handled from the top of the equipment. Something as simple as a additional top exhaust vent with a variable soft brick cover can help a lot with tweaking the internal temperature. More gross variation can also be made by allowing the burner to induce more or less secondary air around the burner head by varying the distance from the chamber burner opening that the burner is placed. A pair of 12 gauge type K thermocouples like Joshua noted will certainly help with tuning. Alternately a sacrifical piece of mild steel can be hung in the forge and a quality IR temperature gun can give you an idea of what your billet will experience. 1
