Joshua States Posted December 6, 2025 Posted December 6, 2025 I finally finished this one up. 3.25" blade, 7.5" OAL. Blued Damascus with nickel-silver guard and pin. 5 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Alan Longmire Posted December 6, 2025 Posted December 6, 2025 That came out surprisingly more subtle than I thought it might. I like it! 1
Joshua States Posted December 6, 2025 Author Posted December 6, 2025 3 hours ago, Alan Longmire said: That came out surprisingly more subtle than I thought it might. I like it! Not too shabby for a bunch of scrap pieces, eh? “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Rob Toneguzzo Posted December 7, 2025 Posted December 7, 2025 Very nice Josh 1 "Old dogs care about you even when you make mistakes" - Tom HALL - Old Dogs, Children and Watermelon wine.
Doug Lester Posted December 8, 2025 Posted December 8, 2025 I would love to see more of how you joined the handle to the collar benieth the guard. That has me facinated. Doug 1 HELP...I'm a twenty year old trapped in the body of an old man!!!
Joshua States Posted December 8, 2025 Author Posted December 8, 2025 2 hours ago, Doug Lester said: I would love to see more of how you joined the handle to the collar benieth the guard. That has me facinated. Doug Simple hidden tang construction. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Doug Lester Posted December 10, 2025 Posted December 10, 2025 Thanks for the pics. Milling that collar out must of been fun but it came out beautifully. Doug 1 HELP...I'm a twenty year old trapped in the body of an old man!!!
Joshua States Posted December 11, 2025 Author Posted December 11, 2025 (edited) 5 hours ago, Doug Lester said: Milling that collar out must of been fun The trick is to take the piece of steel that will be the keyhole-collar and forge it into a rectangle. Then surface grind what will be the sides parallel to each other. Drill the keyhole and cut the wings on the bandsaw. Now you can cut the tang slot in your mill/drill, drill the alignment pin holes and get the spacers fit. Then you can fit the wood into the keyhole and drill through the slot into the wood. Edited December 11, 2025 by Joshua States 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Doug Lester Posted December 11, 2025 Posted December 11, 2025 The more that I look at it, the more that I see that it is just going step by step in assembly. I shouldn't have let the fact that using pattern welded steel for the collar made things really more difficult than they actually were, other than forging the block of steel. It would be basically the same if one starts off with a piece of horn or even another species of wood. Thanks for the explanation. Doug 1 HELP...I'm a twenty year old trapped in the body of an old man!!!
Joshua States Posted December 13, 2025 Author Posted December 13, 2025 On 12/11/2025 at 10:18 AM, Doug Lester said: The more that I look at it, the more that I see that it is just going step by step in assembly. On complex builds or on something I haven't tried before, I will draw out the process steps on paper. Even then I will find errors in my process along the way. For instance, my first idea for that keyhole had little returns on the wings. It took several failed attempts to set the wood into that before I realized they were pushing the wood away from the steel and causing gaps on the round hole. The wings need to taper to a point. 2 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Joshua States Posted December 15, 2025 Author Posted December 15, 2025 I finished a simple pocket sheath for it and took some good pics with a decent camera. 2 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
