Posted
I think I am far enough along with these to start the WIP thread. Hopefully, this one will take less time than the first Tale of Six Blades.
These will mostly be pattern welded steel, so there is a lot of steel to make. I'm less than halfway through half of the bars, but here is a sampling of some of the billets and progress.
The first pair of bars for a mosaic pattern. The core in this billet is another 26-layer bar that was set up to look like 13 layers when welded. 14-1095 and 12-15N20 pieces laid up 2x2 (AABBAABB etc.)
When this got welded there was another set of pieces added to create a corner element in the pattern. (more on that in a minute)
When the final stack got welded, re-squared and drawn out the end grain looked like this.
This is the core bar for another blade, but it follows the same pattern as the core bars for the mosaics.
Then another 30-layer straight ABAB layup welded and forged out to a 30-layer bar and a 90-layer bar on the right in this pic.
The final stack looked like this.
Welded, drawn out to 1" square ready to twist.
  • Like 4
Posted
Another mosaic built around the same core bar pattern. Then I took another same starting stack, welded it, re-squared it and flattened it like I do for W's. Cut it in half and stacked it. Weld that, flipped it 90 degrees and flattened it again. When I cut this bar in half and checked the end grain, it looked like this.
When I stacked that around the core , with the core sandwiched between some 15N20, it looked like this.
Then I prepped some small pieces for the final element. (this is the same element on the first mosaic.)
Some 1095 (1/8"T x 3/4"W), some 15N20, (1/16"T x 3/4"W) and some 15N20 bars 3/16" square.
These get stacked on top of bar #2 like this. (capped with a piece of 15N20)
Then mirror image on the other face of the bar.
These bars are ready to be forge welded together, re-squared and drawn out to 3/4" square like mosaic #1 above.
  • Like 3
Posted
I still have more steel to make. There is a feather pattern coming and (hopefully) some Wootz.
I did take a chunk off of one of my W2 ingots and forged out a bowie.
This was clayed, hardened, and tempered. I'll find a pic and add it tomorrow.
  • Like 3
Posted
Thanks guys.
The Bowie knife went through HT and straightening fairly well.
8+ inches of cutting edge and will be about 9" long from tip to guard.
Surfaced to 220 grit. I'm a little bummed as I wanted this blade to be .200" thick at the spine and this is now at .188".
I did get the mosaic billets welded this afternoon.
They need some cleanup grinding on the sides to remove the overhanging 15N20 strips and tack welds.
These will then get reduced to 1x1 and re-squared.
Posted
The suspense is killing me.  Can hardly wait to see the finished product.
Posted
Well, this is going to take a while. Like a couple of months. So, make some popcorn, sit back and relax.
Posted
Go man go! 👍
Posted
The first disaster happened.
While Liz was using the forge this morning, I set about grinding that Bowie. Got it up to 220 grit.
Then I noticed a little weld booger.
Before anyone asks, "why is there a weld booger in W2?" it's because this is the parent bar that a piece was cut off of to make this blade.
In processing this bar, I have to weld all those voids shut. I guess I missed one.
It's a shame because the Hamon was looking pretty active, even at 220 grit.
So, I will not use the Rybar W2 for this knife. I will cut a piece off of one of my @Don Hanson W2 rounds and forge another blade.
Posted
31 minutes ago, Joshua States said:
The first disaster happened....
O.K., what were the other disasters?
As for that raw steel bar with voids, did you use too much yeast or how does that happen?  🫤
  • Haha 1
Posted
I seem to recall in posts way far back, smiths repairing welding flaws in fancy pattern welded blades (assuming the flaws were minor) by chiseling out the flaw and hammering in some silver wire to fill the void. This that not done anymore?
I can’t see from the photo how bad the flaw is other than it *looks* small and hopefully isn’t deep. I am surprised how clean your billet was from what you started with!
Posted
Stay tuned. I'm sure there will be others to come.
Unfortunately, I don't want to take the time to sort it out. I typically have a "3-strikes" rule. Three problems with a knife and it gets tossed. For this set of knives, it's really down to 2 strikes. This blade was already thinner than I wanted. It has a flaw. It's off the bench.
Posted
Minor update.
I have forged that hunk of DH W2 into a new bar. Now I have to forge a new Bowie from it.
The mosaic stack I showed above has been forged to 1" square, re-squared, and draw out to 3/4" square. (~24" long)
The end of the bar with a light etch
Another mosaic bar I was working on has been through the first 4-Way stack.
The end cut
I did not get the star I was trying to get. (missed it by that much) This will get drawn out to 3/4" square and another 4-way weld.
  • Like 3
Posted
I forged that bar of W2 into a new blade.
Profiled, rough ground, clayed and ready for HT.
After several straightening tempers, it was ready to finish grind. Here it is at 220 grit.
It's a biggun'
  • Like 3
Posted
For this Bowie, I am planning a dog bone handle. For that I will need a template. This is how I create templates for frame handles.
First, I take the blade and create a full-scale design drawing.
Then, I photocopy the handle portion.
This gets cut out and glued to a piece of 1/8" flat steel. That gets cut out, ground to the lines, and all the pinholes drilled.
I now have a template for making the frame, liners, and scales.
To see how these are used, either stick around or check out this thread.
  • Like 3
Posted
I have a couple of commissions to make, so I will be off this project for a bit.
Posted
AEB-L takes a long time to come up to quenching heat, so I did some work on this Bowie while I waited.
Some of you may have noticed that I left the tang and ricasso areas abnormally large during forging, HT, and grinding.
This is how I get all of that to correct size and proportion.
I make another photocopy of the ricasso and handle and draw my tang out on the copy.
You have to consider the pin layout. The tang should not interfere with any of the pins that go through one scale to another.
This gets cut out from the plunge lines to the end.
I use superglue to place it on the blade using the ricasso/plunge cuts as the guide.
Grind away the excess. I purposely left the tang long in case I decide to make this a take-down.
Check the shape on the full drawing and adjust if needed.
Posted
Looking good!  God's speed on the rest.
Judging from the thread title, I'm guessing there will be a fancy dagger in the mix?
-Brian
Posted
That is the plan. I have the basic bar of steel for that. I don't know if the pattern is going to work the way I planned, but I will post some pics of how I made the bar along the way.
  • 2 months later...
Posted
Sheesh, it's been a long time since I was here. I haven't had much shop time to work on these, but there has been a lot of progress on the new outdoor garden to augment the greenhouse. Hopefully, there will be lots of fresh veggies this year.
Not much work on the mosaics, but I did get moving on that dog bone Bowie. After cutting out the handle portion of the drawing and using superglue to stick it to a piece of 1/8" flat steel, I can cut and grind that out to make the handle template. This is a symmetrical handle. There are center line holes drilled in the template and only one side of the template is used to drill the pin holes in the frame. The first step to making the frame portion is to lay the template on a piece of flat 410 Stainless that has been surfaced to 220 grit and drill the center line holes.
Then drill the pin holes on the side you want to use. In this case, it's the side without the X's. and scribe that side of the template onto the frame material.
Flip the template over, align the center line holes, drill the other side of the frame, and scribe that side on the frame material.
This ensures symmetry for the pin holes and profile.
I now cut out and grind down to the scribed line to create the rough frame. All the pin holes in the liners and handle scales will be drilled using the rough frame as a guide.
In the meantime, I needed to practice grinding the bevels on this handle to make sure the pin locations will work.
I use 1/4" MDF for a lot of things in knife making. The finished handle scales will be about 1/4" thick, so I make the liners and a couple of sacrificial scales from the MDF board and pin them to the frame. I blacken the frame edge with a Sharpie marker and grind the scale down until I just get into the black.
Take one side of the liners and scale off to make a line 1/8" above the frame along the scale profile. Repeat for the other side and reassemble.
I now have a grind reference line.
Using an angled work rest on the 2x72, I set it at about 22 degrees and grind the handle bevels.
Satisfied with this, I move o create the final handle scales.
I was going to use mammoth ivory for this knife, but one of the scales I had chosen developed a prominent crack during surface grinding.
So, I decided to use some ironwood instead.
After surfacing the iron wood scales and using the frame to drill all 11 holes in each handle scale and mark the profiles, I cut them out and pin them to the liners and frame and blacken the frame edge again.
Grind the scales down to the frame. These scales are left a little thicker than what the final thickness will be at this point and will be thinned down later.
*IMPOTANT TIP* The two sides of the frame need to be marked, and every liner and both scales need to be marked as to which side of the frame they attach to, and which face of the liner goes against the frame. They are NOT interchangeable regardless of how careful I have been to keep everything symmetrical.
Now to cut out the tang slot in the frame. I remove the scales and liners from one side, blacken the center area and clamp the frame to the tang.
Centering on the ricasso for visual location.
The guard and spacer package was already fit to the tang. The spacer package is held together with alignment pins. I have some pics of forging the guard from a 3/4" round bar of 416. If anyone wants to see those, I will post them. For the process to install alignment pins in the spacer package, you can look at the first Tale of Six blades post in the pinned topics.
I can now scribe the cutout for the tang and remove the material on the bandsaw and cleaning up with files.
Because the tang is not perfectly straight and the slot is cut to fit the tang in one orientation, this handle will only go on the tang one way and fit correctly. The handle needs to be marked as to which side of the handle goes on which side of the blade.
Assemble the entire handle and make sure everything is super-tight. Put it on the knife and superglue the last couple of spacers to the frame so you can use them as transfer plate to drill the alignment pin holes. Insert the pins and assemble the knife. Check for gaps, center lines, etc.
Gotta run. More later today.
Posted
Time to trim down the spacer package. I remove the spacer package and blacken the thin spacer that sits against the handle. Put it all back together and scribe the outline of the handle on the spacer. Then I pin the package to a piece of 1/4" MDF (have I told you how much I use this stuff?) with the black face up and cut off the excess MDF.
I can now grind that package on the 2x72 down to the lines and have a rough shaped spacer package.
About that dagger bar......I started with the same core bar of 26 pieces of steel, 14-1095 and 12-15N20 stacked 2x2 so it will present as 13 layers.
Then I stacked up another billet of 30 layers, mostly equal distribution of 1095 and 15N20 with a few sheets of pure nickel. This second bar got welded and drawn out. About a third was cut off and the rest stacked to make 90 layers. The final billet stack looked like this.
That got welder and drawn out to 1-inch square and about 14-inches long.
This will be twisted. I am hoping to do a video on how I twist this bar for the YT channel. Stay tuned.
  • 5 months later...
Posted
I know it's been a while now, but I have some small progress to show. Various commissions and home projects got in the way of any shop time.
I did manage to get some work done on that big Bowie handle, but I have not made any progress posts along the way.
I shaped the guard and beveled the spacer package and handle scales. The bevels were done with the spacer package attached after roughing in the handle bevels.
Now comes the laborious task of doing all the file work on the frame and liners. This handle has a 3/16" thick frame of 416 SS, two .04" thick 410 ss liners, and two .02" thick black paper liners. The main frame will get rope file work and some lines, and the two thin stainless liners will get vine and some coining or maybe just all vine work. This is the handle prior to bevels.
I won't load this thread up with the whole process of cutting in the rope. You can find that elsewhere on this forum.
In the past I usually sanded my rope file work with round rods wrapped in sandpaper and buffed it to shine.
However, I was never totally happy with the resulting finish. I could still see sanding lines with even mild magnification like a pair of dime store reading glasses, even when I sanded to 600 grit before buffing. Buffing your file work also brings additional dangers. If you are using an aggressive buff, either compound or a sewn wheel, you risk removing little details or flattening out features that are supposed to have a crisp edge. There was a constant compromise that usually ended when it was "good enough." That always bugged me.
This time I tried a new polishing technique using a rotary tool and a fine rubberized abrasive disc.
This is the file work after sanding to 600 grit.
This is after polishing with the rotary tool.
A short buff with a soft wheel and some pink compound is all that is needed.
Posted
This was the test look before polishing.
