How do you cut your blade steels?
15 members have voted
  1. 1. How do you cut your blade steels?
    • Angle grinder and cutting disc
      11
    • Bench shears - cold
      2
    • Cut off hardy or hardy shear - hot
      5
    • Metal bandsaw
      6
    • Cold Cut Off Saw
      2
    • Other
      2
Posted
I posted a similar question on a blacksmithing forum I'm a member of, but I think it is actually more pertinent here in blade smithing country.
Unless I'm forging in a blade profile from round stock, or a larger thickness of flat stock, I do most of my cutting of blade steels cold with an angle grinder and cutting disc but I'm curious to know how other makers cut their steels? Eventually, I'd love to look at purchasing a less consumable-heavy method, if there are any.
Does anyone use a bench shear, or have any experience with whether the blades on them could stand up to higher carbon, or more complex alloy steels?
Does anyone use a cold cut-off saw or metal bandsaw? How long do the blades last?
Any advice greatly appreciated.
Cheers,
Jono.
Posted
I have a bench shear, and it will cut 0.100 carbon stock for damascus, and up to 1/4 round mild, but not much more than that.  Unless you're cutting a ton of stock, an angle grinder works pretty well and I've seen both factory made and home made angle grinder jigs as small chop saws.  Cutting discs are pretty cheap.  Just an aside on angle grinders, I have a relative who has worked in fab shops since the dawn of time.  He said once that they used to buy the expensive brand name angle grinders (name starts with an "M") by the case.  They would burn them up in a few months.  The boss cheaped out and bought a case of off brand (HF) grinders and they lasted about the same amount of time at about 1/10 the cost.  Just saying.
I have an old, fairly wonky horizontal band saw and it works OK, but the blades aren't cheap ( I can't remember what I paid for the last one, but I seem to remember kvetching about it).  I have killed several 14" abrasive saws, they don't seem to last long for me.  I suppose if I were willing to spend some $ on one that might be different.  I have an old table saw and I have considered putting an abrasive blade on it, but I worry about getting metal dust in the motor.  A modded tupperware box might fix that.  I have a couple of portabands, and I have thought about getting a stand for one of them (or making one) but again, I'm cheap.
I do hot cut when that is the right process.
The real thing for me is, I'm not a fab shop.  I do build one off jigs and tools, and cutting stock to size is never that much of a chore.  If I were more of a production kind of maker, then it would be worth investing in better tools, like a plasma cutter or a water jet, but the truth is that I have sent those sort of jobs out when I have needed to.
Just my .02
I said that.
- - -G. K. Chesterton
Grant Sarver
Posted
I have tried most of these methods and still go back to an angle grinder.
for cutting bigger stock I use a big 7 inch angle grinder, nothing beats that in speed for me.
I actually have bought a ''cold saw'' with hss blade, but is mostly useless for blade steels, these really are meant for soft tube steel.
Bandsaws are nice, but only work on annealled steel, cutting a forged piece is a great way to ruin a blade.
A big shear would be the way if I really needed to cut a lot of pieces, but it would have to be an hydraulic industrial machine, the standard bench shears are not up to the task, even with a pipe to extend the handle :rolleyes:
There are no secrets, one just has to ask the right questions.
Posted
I generally use a cheap horizontal/vertical bandsaw to cut stock to length, but as Pieter-Paul said, it only works on annealed clean steel.  If I'm forging a blade, I don't cut to shape, I forge it.  If I'm doing pure stock removal, I'll get close on the bandsaw and finish profiling on the belt grinder or disk grinder.  And yes, good bandsaw blades are expensive. And can be ruined in seconds if you try to cut hardened steel, hot steel, or stock too thin for the teeth-per-inch.
Posted
Howdy!!  I pretty much use them all depending...on PW shim stock I used either a pair of snips or I have a bench shear that works well up to 0.125" thick...on thicker bar stock I use an el-cheapo band saw with a GOOD quality blade..using a good blade makes these budget saws work very well.. I stay away from the screechers if I can..too much racket.. makes my brain hurt..
JP
If you wish to know the price of freedom..Visit a Veteran's Hospital...I am humbled by their sacrifice...
Why is it when the Mighty Thor throws his hammer he is dispensing Justice and fighting Evil..BUT..when I throw my hammer I wind up in a mandatory 16 week anger management course??</p>
I came into this world naked, screaming and covered in someone else's blood...I have no problem going out the same way...
Posted
I looked at getting cheap one of these recently. The bigger ones (9" I think?) scare me, but I think 7" might be the sweet spot. My 4" eats up cutting discs too quickly, and I hate not being able to use about the last third of the disc because of the shape of the grinder body and the thickness of the guard collar on it.
Posted
On 1/31/2026 at 11:27 AM, Eric Estlund said:
"Yes"
I make a bunch of stuff, and I use all of the above.
+1
I took a cue from Gary Mulkey and started buying my pattern welding stock in pre-cut lengths.  Bladesmithing is a hobby for me, not for income, so I made the choice to cut out part of the work that I don't enjoy.
When I have to cut material, I prefer using a portable bandsaw.  However, there are a lot of times I need to use the angle grinder.  I tend to avoid the grinder if I can.  The noise it makes irritates me.  Sort of a fingernails on a chalkboard sort of feeling when I have to use it.
Edited by Brian Dougherty
-Brian
Posted
Brian, do you ever use the portable bandsaw specifically on knife steels? How well do the blades hold up? And are they very expensive?
A friend of mine has recommended them to me as well but I'm concerned I would ruin the blades quickly.
Posted
I have. You need to have bi-metal bandsaw blades, and the steel must be properly annealed. I have cut welded PW billets lengthwise on a bandsaw. I often split 1095 into 3/4" wide strips for some billet stacks on my bandsaw. I have also done ladder cuts in PW billets on the bandsaw. It is how I typically do W-patterns. Most mosaics done with tiles are cut on a bandsaw. The right bandsaw blades and proper annealing are required.
How I make PW steel.
I buy my 1095 in 6ft long strips, 1.5" wide and in thicknesses of 1/8", 3/16", and 1/4"
I Stack up 4 or 5 of these, flush the ends, clamp and cut the whole stack in the chop saw to the desired lengths for my billet.
My 15N20 I typically buy in 36"x8" sheets. These get cut into 1.5" wide strips with the plasma cutter (notably absent from your list of cutting implements, save for "Other").
Those strips get stacked, clamped and cut in the chop saw.
I recently purchased a bunch of 15N20 precut to 1.5" x 6" from Ric Furrer. That did save me a bunch of time.
Posted
Thanks Joshua. That's really useful info.
I didn't even think of a plasma cutter! For some reason, when someone says plasma cutter, I normally think of a big CNC machine, forgetting that they are more often something more akin to a welder (or even run off a welder!)
Posted
 There are a lot of smaller plasma cutters on the market now. We bought one years ago with inverter tech that is really lightweight.
