Posted
To distract me from my (kind of) obsession with the counterblow power hammer, which is *almost* finished by now...
I started the design of a Musso Bowie style knife, but not an exact replica.
One idea is to cast the guard in bronze (and maybe together what used to be the brass sheet ridge on the spine) in place onto the forged and roughly ground blade. Obviously, the whole steel/bronze assembly would have to be heat treated together after that. Not sure if that is possible, given the unequal expansion of steel and bronze.
The other idea is to cast the grip as one piece from aluminum, to be riveted with copper dowels to the tang. That is surely possible (technically), but I was wondering how a steel Bowie with bronze guard, polished aluminum grip and copper rivets would look like.
Oh well, just some thoughts for now. Let me know if that sounds crazy or if it may work (even after some failed trials).
Or let me know why that can not work at all (you spoilsport...)
Posted
I think if you made a standard Bowie blade as if it were a hidden tang going into a wooden handle, took it all the way through HT and finish, you could insert the tang into a mold/form and pour the bronze or aluminum around the tang. It would undoubtedly bond to the steel tang. Then you could clean up the cast handle/guard assembly.
Sort of the same way brass or bronze hammer heads were attached to steel handles. I have an old casting frame for these hammers outside. I'll see if I can get a photo of it for you.
Posted
Bert, aluminum handle made me think of F. J. Richtig (only what I’ve read about). Vintage maker from 1930 - 1970. He did a lot of kitchen knives from cast aluminum handles, but I don’t know if these slabs or molded on.
Gary LT
Posted
1 hour ago, Joshua States said:
I think if you made a standard Bowie blade as if it were a hidden tang going into a wooden handle, took it all the way through HT and finish, you could insert the tang into a mold/form and pour the bronze or aluminum around the tang....
That would be the preferred way of doing it. Unfortunately, when using an investment gypsum mold with the blade embedded, I have to fire the mold and the blade to some 1300 degrees which would nullify the heat treatment of the blade. That is why I was wondering if to cast the guard after normalizing, maybe clean up the sprue and burrs and then take the complete thing to quench temperature, quench and temper. The quench temperature will not melt the bronze.
That may take some experimentation if possible at all. Given the unequal coefficient of expansion, I suspect the cast bronze may fall off or crack.
Also while casting, on the long run along the steel spine for the "brass strip", the steel will cool down the molten bronze so it may or may not reach the end.
What would be life without challenge. I probably would not try this if I made knives for a living.
I got the idea because I some point I owned a fascine knife (Faschinenmesser) with a solid aluminum handle. I am not sure when that was made but such weapons fell out of use before WW1. It was very unusual because most of these knives had a solid cast brass handle but in aluminum it looked very good.
It may not be the most practical knife, freezing your fingers off when ice cold or burning your fingers when left in the sun. But I am not planning to take it to battle, anyway.
I can not cast the aluminum in place like the bronze since it would melt below quench temperature. So that would be 2 separately cast scales, riveted on. I thought about a single cast grip but the long slim core for the tang would be difficult.
Edited by Gert Burkhardt
Posted
I watched a video several years ago about a family of knifemakers that showed them casting aluminum handles on knife blades.  It's on youtube somewhere, but I bet it was 10 years ago that I saw it.  The nearly complete blade was just insert molded into the aluminum.  I forget what the mold haves were made from...
Gert, I think if I were to try bronze with a ceramic mold, I would fire and pre-heat the mold, but design in a way to insert the blade tang after pre-heating and just prior to pouring.  I would also heatsink the blade with wet leather or wool felt or something like that.  My alternative approach would be to wait to quench the blade afterwards, but only get the edge/tip up past the transition temp.  Neither approach is ideal, but may work.
-Brian
Posted
This is what I am talking about. The casting mold is two pieces. It is formed around a model of the handle with a spot to insert the blade tang. The model is removed, the tang inserted, and the handle poured using the mold.
Posted
I believe you are thinking about Ruana Knife Works, Inc.  They made (and maybe still make) knives with cast AL furniture.
If you made your blade out of one of the high temp stainless steels (I'm not a stainless guy, but someone here will know) you could cast the handle and not worry about affecting the heat treatment.  Some of those temper around 1800 F.
I said that.
- - -G. K. Chesterton
Grant Sarver
Posted
First Things First. Maybe I should forge that blade before further speculation about the guard and handle methods. After all, I never made a Bowie knife...
If the imagined in-place casting methods  won't work, I think I can still knock/grind off the failed casting and just assemble the knife in a conventional way.
But just in case it might work, I printed the investment patterns for the guard with attached spine strip.
Now back to the counterblow power hammer😉
Posted
Yes- there is at least one you tube video from their shop showing pretty.much the complete process.
Posted
Thanks for the YouTube tip. I found a video showing the aluminum cast in place over the blade. They used steel molds which makes sense for a shop doing series production. The heat capacity of the mold will probably keep the blade cool enough to not affect the heat treat.
Got to think about that. While a metal mold is surely not doable (or sensible) for me, at least it looks like the cast aluminum handle is not a bad idea as such.
Posted
Look into sand casting. It's fairly inexpensive and you can make the mold frame out of scrap wood.
I never cast something in sand molds. Well, got to learn another new thing. For this knife's purpose it just looks easier and less risky than investment casting.
I did start forging the blade and ran into another amateur problem. While I am getting the overall blade shape closer to the design and nearing the target 6mm thickness, it becomes obvious that I am running out of steel, i.e. I guess my W2 billet was too small to start with (maybe 20% over blade target weight). So I need to think if I:
- Start over with a bigger piece of steel
- Make the design smaller (the original dimensions of that Musso blade at almost 18" incl. tang are anyway a bit massive)
- Keep forging and end up with maybe 4mm blade thickness. But that would be a bit flimsy for such a long blade.
I am getting there with the blade. Just don't laugh at me...it is still quite crude. The blade still needs to be wider, especially right in front of the ricasso and the tang longer.
But I am struggling to forge the bevel. While there is some thinning on the edge side, I suspect most will have to be done on the grinder. And I had to turn down the speed (and impact energy) of my power hammer to avoid smashing big dents into the blade when accidentally misaligned. Maybe I should make a flat die for such work?
Interesting observation is that the W2 steel barely sheds forge scale like earlier tests with e.g. 1084 or mild steel. There is just a pinch of black dust on the floor.
Posted
FWIW, I rarely do much work on the power hammer for the bevel anymore.
When I did do bevels on the PH, I used my drawing dies and held the tang in one set of tongs and the spine in another set. I held the blade lengthwise across the dies.
Posted
... I held the blade lengthwise across the dies...
That is what I tried and it worked to a degree. It surely saved a bit of grinding, but the risk of a misplaced hammer blow just went up.
I kept forging a little more with a hand hammer and did some rough grinding. So far I am quite satisfied for my first Bowie attempt, in spite of a few small forging dimples (too deep to grind out) and marks of my unsteady hands when grinding. I tried a hollow grind for the bevel using a curved jig.
Due to the billet that was too small, the blade ended up two inches shorter and maybe 1/16 thinner than intended. But it is still a pretty massive blade at 16" length (incl. 4" tang) and 12.5 oz weight. The billet was a 1.25" round rod, about 3" long.
The step in the spine in this picture is to accommodate the bronze ridge. That will be the next challenge...
Posted
Oh well. I am giving up on the idea of the guard and handle cast directly over the blade. 🙄   I tried casting the guard with attached bronze strip but I failed to do it in a sand mold (cold shut on the narrow long strip) and could not do it in a investment gypsum mold (the mold fell apart in shards, probably due to uneven expansion of the blade and the gypsum at burn-out temperature). I am sure it can be done but losing the patience for another dozen experiments. At least the blade should be well annealed now...
So, I will go the traditional route. Cast a bronze guard separately and assemble it with the heat treated blade, then add the handle parts: maybe separately cast aluminum scales or maybe wood.
Posted
The original Musso bowie's back strip is piece of hobby brass U-channel soldered on with lead solder (it was made around 1951).  The few 16th century Scottish dirks with brass spines were done by making U-channel from flat poured brass, the same way they made the backs of brasses for furniture.
I understand there is a bit of controversy about the origins of the Musso knife, not to mention the questionable utility of the brass strip. But I was not going for an exact replica. Just wanted to forge a big blade to test my new power hammer and liked the design and I cannot help myself to try new things.
Anyway, I have ground the top 1/4" of the blade spine thinner and gave it a serration and a small undercut channel. I am planning to crimp/hammer the spine strip U-channel into the serration and the undercut (save the soldering) then grind it flush with the blade.
Posted
Better casting aspersions than failing to cast a bronze guard onto a blade   🤣
Anyway, any constructive criticism is appreciated!
I cleaned the blade from the gypsum remnants and gave it a final grind before I take it to heat treating. That removed some of the earlier flaws and it looks like it might end up a nice knife (if it does not crack).
I got the blade heat treated (1470F for quench in lukewarm Parks50 and twice 2 hour 460F for tempering). No cracking.
For the quench I applied a pattern coat onto the spine. Improvised a bit, not having clay at hand I used a thick slurry of fine sand and hide glue, let dry, then coated the entire blade thinly with ATP641. The glue slurry carbonized and baked into a hard crust while heating to quenching temperature so it might have done the job.
Anyway, the resulting Hamon pattern is a bit unexpected (not exactly what I had drawn)  and maybe I need to work on the etching/polishing process but so far, so good.
Posted
Gert  ......there is nothing shameful about using a hand hammer to clean up a forging ....
this is looking good ....I kind of like it the way it looks now before the brass is added....I look forward to seeing what the brass adds to it.....
