Gert Burkhardt Posted July 9 Posted July 9 Making 2 small folder blades from AEB-L by heat treating inside a closed graphite crucible (with charcoal added), I noticed the blade came out with a pretty blue-black surface (oxide?) that was very even, almost shiny and not easy to grind off. For another one I am going to make, I am wondering to grind the blade to almost finish shape before heat treating and leave the black skin on. Then only grind and sharpen the small secondary edge bevel. Does that sound reasonable? Or is the black layer bound to be scratched and scuffed in use, just making it ugly? The other question: If I am going the grind the edge to e.g. 0.2 mm thickness, will that thin edge heat treat/quench properly (assuming I can take it from the crucible to the oil tank within about a second)?
Alan Longmire Posted July 9 Posted July 9 I don't know about the oxide layer, it sounds like old fashioned charcoal blueing, though. Should be reasonably durable if only used on soft materials. I leave my folder edges at about 0.2mm, sometimes thinner, and it works fine on AEB-L as long as I seal my foil correctly and avoid decarb. You shouldn't have decarb in the closed crucible with charcoal, I wouldn't think. If you try it and it won't hold an edge, you're getting decarb somehow.
Gert Burkhardt Posted July 10 Author Posted July 10 (edited) Ha! I did not even know what charcoal blueing is. But what I read about it, it seems to be usually done at much lower temperatures, like 800 F with multiple reheating and burnishing cycles without quenching. For my AEB-L blades I used a slow 1-hour heat-up to 1925 F inside the crucible, soak for 15 minutes and rapid transfer to Parks 50. Then ice box and 325F tempering. The black skin came out of the quench oil already Edited July 10 by Gert Burkhardt
Gert Burkhardt Posted July 12 Author Posted July 12 Well, that does not look too bad. I polished the blade to 2000 grit before the heat treat/blackening and it even retained some of the gloss. The black skin does not rub off easily but I am sure contact with hard material will scratch it. 3
Gert Burkhardt Posted July 13 Author Posted July 13 Apparently, a diamond drag bit can scratch the surface...and the hardened steel. 1
