Christopher Price Posted July 31 Posted July 31 So the ashtray project is moving forward. The plan is to make a line and sell to the cigar company I work for. I'd like one of the high-end to be a damascus billet forged into the high-end example. What would contrast well with regular mild, and isn't expensive knife steel or in need of hardening to produce good contrast? The Tidewater Forge Christopher Price, Bladesmith
Alan Longmire Posted July 31 Posted July 31 Pure nickel sheet/A36, coffee etch. Hot blue would be better, but more expensive, thus negating the savings. Pure nickel sheet is also known as nickel 400. 1
billyO Posted July 31 Posted July 31 I don't have a huge amount of experience, but about 8 years ago I started down this path when I was making chess sets out of damascus. I didn't experiment much with mild steel because I found it to etch to a dull grey that was kind of in between what I use which is 1084 and 15N20. I decided to just go with what I knew which is knife steels and I assume you know the effects of Carbon, Nickle, Manganese, etc on etch color. 1 One should keep in mind, we are all both the blacksmith and iron in the fire... as always peace and love billyO
Spencer Phillipson Posted July 31 Posted July 31 Noob here, but have you considered old industrial bandsaw blades? From what I’ve heard they have a nickel content. I’m not speaking from experience here, so take that with a grain of salt 😀 I’m not sure where you would procure them, but maybe that’s an option. 1
Brian Dougherty Posted July 31 Posted July 31 I hesitate to even say this, but your application might be a legitimate use for some Pakistani crapmascus. You might be able to import some billets pretty inexpensively. Then again, cigar guys spend money. I'd probably just make them something with the good stuff and charge a fair rate. 2 -Brian
Christopher Price Posted July 31 Author Posted July 31 Appreciate the input. Still noodling on how to put it together too. The Tidewater Forge Christopher Price, Bladesmith
shane45 Posted August 1 Posted August 1 I had a similar question but I wasn't concerned about the cost as much because my application was small. I was looking at nickel and straight iron. It seemed to me that would make a serious contrast. But that is pure speculation from a complete newbie!
Alan Longmire Posted August 1 Posted August 1 11 hours ago, shane45 said: I was looking at nickel and straight iron. As Billy said above, unless there's sufficient manganese the "iron" will etch gray. That's why I suggested a coffee etch or bluing, for better contrast.
Jerrod Miller Posted August 3 Posted August 3 On 8/1/2026 at 6:38 AM, Alan Longmire said: unless there's sufficient manganese the "iron" will etch gray. If your local steel merchant carries 15XX series steel, this may be a cheap alternative to get >1% Mn in an otherwise mild steel. 2
Dick Sexstone Posted September 1 Posted September 1 I liked 203E & iron for non hardening scales for folders I used to do ... I could etch it to the point the iron would take a texture and the 203E would remain pretty clean and come up to bright without touching the textured iron....
