Gert Burkhardt Posted August 11 Posted August 11 (edited) Since I got my propane forge upgraded to a blower system, I have been playing with air flow and gas feed settings and got it to work quite well. What still eluded me is the optimal setting for reducing flame when forge welding. While I can see the famous dragon breath increasing when opening the needle valve, it is difficult to assess how much is best, especially in bright daylight. So, given my nerdy streak, I installed an automotive wideband lambda probe on the forge with a sampling tube reaching a few inches inside from the rear opening. I had that probe and monitor from an upgrade project to my old sports car that never happened. And...that works great! Actually, I was surprised how little change to the gas flow needle valve (or the blower speed controller) is needed to change the gas mix from e.g. 20% excess oxygen to 20% excess propane (see how little hand movement in the video). Or how easy it is to totally over-saturate the flame with propane which will surely create a ton of CO. The obvious next question is: What is the optimal lambda value for forge welding? I have never seen any specific info other than "reducing" and "soft billowing dragon breath". I will shoot for maybe 0.8 for my next project, i.e. 20% excess propane. Not sure yet, but maybe I will install this thing permanently. LambdaProbeResult.mp4 Edited August 11 by Gert Burkhardt 3
Carl Chandler Posted August 12 Posted August 12 I don't know a ton about these sensors, but spent some amount of time working at Bosch, around guys who knew a lot about lambda sensors. You might already know this, but I think Lambda sensors need pretty high heat for them to work correctly. Somewhere around 600-1000F, IIRC. Your sensor might have a heater built in to do just this, but it might be worth double checking, just so you know you're not getting bad readings. If you already know this, disregard :).
Gert Burkhardt Posted August 12 Author Posted August 12 (edited) You are right, these probes have a heater element and are not solely dependent on the exhaust temperature. That said, I am pretty sure that the cheap kit that I used does not come with a genuine Bosch probe. But I did an air calibration and for my purpose it is good enough. Edited August 12 by Gert Burkhardt
Alan Longmire Posted August 12 Posted August 12 I love it! Never would have thought of it, not being an engineer-type, but it makes perfect sense. Now you need to test just how reducing you need by seeing when steel stops scaling in the forge. It'll still scale the minute you expose it to open air, but finding the exact amount of CO that cancels out O would be good to know. It may be a simple 1%, it may be more like 10%. Now you can find out for the rest of us!
Gert Burkhardt Posted August 12 Author Posted August 12 That is an idea. So how would I do this? I guess taking a mild steel bar and grind it clean, then taking it to good orange heat starting at high propane excess, then slowly decreasing propane flow until scale start to show? How long would it normally take to develop forge scale?
Jerrod Miller Posted August 12 Posted August 12 A couple things to keep in mind, which some here will already know, but not everyone: The sensor is sampling the atmosphere in the tube, which may be affected by the tube, and you will definitely have differences in oxygen levels throughout the forge. This is easiest (in my mind) to visualize with the scenario of having too much propane injected causing a cool spot directly in line with the burner. The unburned gas is cool and there is no oxygen, but it does eventually burn further away, so there is definitely oxygen present. About a decade ago I was looking for oxygen sensors to put in our industrial ovens and couldn't find anything suitable for those temps and atmospheres (2000F, highly oxidizing) that weren't ridiculously expensive. Things are getting much better as the technology advances. Service life was a big factor. If you have a dedicated exhaust port, then you can use one in there, rather than in the furnace itself, but you really have to have good atmosphere mixing (or just assume you do) to have it be of especially good use for scaling/decarb purposes (as opposed to fuel efficiency purposes). 32 minutes ago, Gert Burkhardt said: How long would it normally take to develop forge scale? Depends on temperature, atmosphere composition, and alloy.
Gert Burkhardt Posted August 12 Author Posted August 12 The Bosch LSU 4.9 sensors are specified up to 1700 F (or 1860F for short time). I have seen such a sensor tip glowing cherry red when dyno tuning an engine. But 2000F is surely too much. That is why I did not install the sensor inside the forge but outside with that tube extension. Kind of like in a car exhaust. But I will also measure how hot it gets inside the tube (which is simple black iron pipe). As for the mixing, I hope the swirl induced by the burner will mix it up reasonably well so that the sampling tube position (3" inside and near the top) is representative of the gas mix that hits the work piece. But this is another good point and I could unbolt that assembly and move it around in the forge with a longer tip to see if there are big differences. Or, if the position of the front and rear doors has a serious influence. Anyway, fun experimenting!
AJ Chalifoux Posted August 13 Posted August 13 1. Really, really neat idea! 2. Stating the obvious here, but if you move the tip around and see big swings, then the non-uniformity of the atmosphere may lend itself better to a two or three sensor system not unlike the thermocouples on multi-zone heat treat furnaces. Facebook
Gert Burkhardt Posted August 13 Author Posted August 13 Some results from my experiments: 1. The temperature at the sensor tip is good. I dropped a thin thermocouple into the tube exit and measured 1000-1300 deg F temperature in the gas stream. While the lower black iron nipples and the elbow turned blue, the sensor t-fitting barely changed color. 2. I probed the oxygen level at various points in the forge with a nozzle extension. The result depended highly on the front and rear opening: - When both forge doors are wide open, the oxygen fluctuated wildly and depended even if the nozzle was stuck in from the front or back. I guess, due to the tilt of my burner tube there is some "draft" going through the forge, adding a variable amount of oxygen. - If the rear door is almost closed and the forge exhaust is mostly through the front door, no outside air is mixed in. The measured oxygen level is quite even, usually within 0.05 lambda. That means, for stable reducing environment, I need to close the rear opening almost shut. 3. I did some experiments for scale development, using a mild steel bar with mill skin ground off at lambda 0.75 (rich, reducing), 0.9 (slightly rich), 1.0 (stoichometric, neutral) and 1.1 (lean, oxidizing). The test was not very scientific, since I did not time the duration at temperature exactly (about 5-6 minutes per heat) and I removed scale from previous experiments only roughly. Looking at the following pictures, the color of the steel is misleading. At 0.9, 1.0 and 1.1 lambda the steel was much hotter and bright yellow. At 0.75 lambda the steel was bright orange but my iPhone camera made it all look the same. A) Lambda 0.75. Steel stayed mostly clean but some scale blisters are developing. Lambda=0.9 More scale and significantly hotter flame Lambda=1.1 Heavy scale development My Conclusion: Lambda down to 0.75 keeps scale at minimum but not avoid entirely. Maybe there is still too much water vapor and CO2 in the combustion output, oxidizing the steel directly (even without free oxygen). But the flame is rather cool and going even richer with more propane makes it unstable. Looks like a compromise is needed and for my next forge welding project I will try to keep it at 0.8. Given the sensitivity of the needle valve setting, I think the sensor is helpful to set up the forge repeatably without guessing. 2
Alan Longmire Posted August 13 Posted August 13 Real results! And yes, one of the many benefits of blown burners is that you can close the doors much more than you can with venturi burners. They still need exhaust ports, but they can run fine with a lot of back pressure. Very similar to comparing a supercharged engine to a simple carbureted engine of the same displacement. And yes, by now I've gotten familiar with how your mind works, and I fully expect to see you develop a turbocharged blown burner with auxiliary acetylene injection... 6000 degree F flame front, here we come! Note to others: Don't try that, it'd be incredibly dangerous. Note to Gert: I really think you are capable of that. It'd still be incredibly dangerous, though. And only practical if you intend to forge tungsten or platinum group metals. 1
Gert Burkhardt Posted August 13 Author Posted August 13 2 hours ago, Alan Longmire said: ....expect to see you develop a turbocharged blown burner with auxiliary acetylene injection... Oh no! I have fun with these experiments because they help me understand the processes and hopefully improve how I work. But obviously it distracts me from the goal of making blades. That means I will stop here with the forge trials and just use it. But I know you were joking and believe such a turbo acetylene burner would melt down any refractory in no time... Actually, starting to use the upgraded forge I noticed another advantage of the lambda sensor: When the reading started creeping up to really lean without changing the needle valve setting, I knew I have to go and refill the propane tank. 😏 1
Brian Dougherty Posted August 14 Posted August 14 (edited) Wow, I would not have guessed that you have to be that far off stoichiometric to stop the scale formation. I really need to get a CO monitor for the shed where I run the forge! Thanks for running this experiment and sharing the results. Edited August 14 by Brian Dougherty -Brian
Jerrod Miller Posted August 14 Posted August 14 I have posted the Ellingham-Richardson diagram before (multiple times), but it is especially relevant here. I highly recommend those interested in checking out the explanation to it all at this website. Especially of note is the section where they specifically speak to the carbon oxidations and how it relates to iron/steel. 1
