Posted
I made a miniature pantograph as a tool to scribe the centerline of a blade (tapered, curved). Works quite well but I may re-do it with tighter tolerances. The joints are a little sloppy.
The pen is a long-nose permanent marker.
  • Like 5
So...here is V2.0
I found that my woodworking CNC machine is just not that great for such a job in brass. Also, this first prototype only can handle blades down to 20mm width.
I re-designed it based on that experience with components to be made on a 3d printer (plus some 3mm OD brass tubing). This is much more precise than the prototype and goes down to 9mm blade width. Maximum blade width is 95 mm (that would be an executioner's sword?). The hinge brass tubes are flared with a conical punch to stay in place.
Pretty neat and if somebody is interested I can post the 3d printer .stl file.
Edited by Gert Burkhardt
  • Like 4
Posted
Pretty slick! I like your design much more than the usual two prongs on a flat bar that you twist into place since yours can go to the very end of the material and seemingly accommodate thin stock more easily. I for one wouldn't mind printing one if the .stl is readily available.
John
-Nine Worlds Workshop-
Posted
Seconded
Posted
Cool Gert...... I'd rather use a scribe point marking a dykem surface to have a more precise line ....the fixture could easily do that too.....Thanks
Posted
I don't have or have access to a 3d printer, but I bet you could sell a few of those at the hammer-in.
Posted
I could bring one or two assembled as donation for the raffle? And maybe a few sets of the parts.
In the meantime I changed the design to V2.1 which is to make the parts solid. That helps rigidity of the assembly.
Here is the .stl file. I posted binary and ASCII format, just in case.
Panto.stl
Panto(ASCII).stl
  • Like 3
  • Thanks 2
A few tips...
- I used standard PLA filament, which is stiff enough. If you have fiber filled filament, that might be even better.
- The infill for my parts is 100%. I don't think there is a point making the parts hollow.
- The holes will come out a bit undersized from the printer. Ream out the bigger holes with a 3mm drill and the smaller holes with a 2.5mm drill. The brass tubes should move freely but without slop. The bit may snag the plastic and make the hole cockeyed. Better on a drill press.
- When flaring the tubes to help them stay in place be careful not to overdo it. Otherwise you may split the plastic or the hinge will bind.
- I used 3mm washers between the moving parts to reduce friction. That works but the washers are too big and protrude a little under the plastic part. That limits the minimal blade width a bit. Smaller diameter shim washers might be better but I don't have them.
- The pens I used have a 2.4 mm diameter and 20mm long  nozzle. Amazon has several of them for little money.
- They could of course be replaced with a carbide scribe tip. Might however need a different hole diameter.
- 3mm brass tubing is sometimes at ACE hardware or online
Posted
Gert, I like the way you think and all of the engineering ideas are just good stuff.
Gary LT
