Posted
Hi guys I still haven’t gotten around to making my forge but I have some ideas that I want to try. My old one was a 20lb propane tank line with 2” inswool and coated with satanite with a mizzou floor. The problem was that the satanite would chip and fall off relatively frequently and it got old fast. My question is has anyone used a 3/8” layer of Kastolite 30 to cast around the walls of the wool? That way you have a much more robust coating yet you still have the insulating abilities of the wool. My other question is when you are inserting the burner into the forge how far in should the nozzle be and should the liner near the nozzle be flared and coated as well?
Posted
I use Mizzou in my welding forge floor and it's pretty tough stuff.  I just made a slurry and soaked an extra piece of wool and smushed it into place.  The burner tips should not extend into the forge.  I hand formed a rough cone of Mizzou and wool in the inlet opening.  I have seen people do this with a small dixie cup to form the opening.  It makes for a clean build, but I'm not sure that it makes all that much difference.
g
I said that.
- - -G. K. Chesterton
Grant Sarver
Posted
g
Thank you! Are you using the mizzou on the walls too or just the forge and the inlet?
Posted
I know a guy who did the 1" cast-o-lite over wool thing and it works fine.  He uses a kind of ribbon burner, though.
Posted
On that forge (my welding forge) I used an inch of untreated wool and then a layer of treated wool inside of that.  It's been pretty durable, but after a couple of years ( or longer, unless I keep notes everything is a "a while ago") it's in need of a rebuild.
G
I said that.
Grant Sarver
