Posted
I use a vertical forge, which works well for my "everyday" forging.  It's a 10" (?, might be 12") bottom section from a 20 gallon propane tank.  I'm thinking that a ribbon burner cast into the bottom of the tank might be an improvement.  It's not that I have an issue with the forge, I just have a desire to tinker.  Has anyone seen anything like this?  I'm thinking of using my existing forced air burner setup like I describe in my pinned post with the burner coming straight up from the bottom.  I would need to figure out how to channel the air/gas flow so that the burn was balanced.
Any ideas?
I said that.
- - -G. K. Chesterton
Grant Sarver
Posted
Personally I'd put it coming in from the side at a tangent, but with a ribbon it probably doesn't make much difference. The only thing I'd worry about for a bottom entry burner is fallling scale, flux, and so on.  But hey, try it and see!  I don't see many vertical forges these days, and they were all the rage 25 years ago.  And for good reason, the heat is just so much more even.
Posted
I got the idea here from Don Fogg, probably 25 years ago!  It works fine as it is, it needs some patching right now but that's about it.  You know how the urge to tinker is, you don't really need a reason.
g
I said that.
Grant Sarver
Posted
I built a small ribbon burner for a small vertical forge for crucibles. It didn't work so well.
If I were to try this again, in a full-size vertical forge, I would put the burner lengthwise in the side of the forge, just below the door.
