Jeroen Zuiderwijk Posted September 1 Posted September 1 I'm looking into buying a thermocouple and reader for my charcoal bronze casting furnace, that I can use to monitor the temperature inside the charcoal in various places in my furnace. What do I need to look out for? Ideally, I'd like one that can survive up to about 1300C. Higher may be helpfull, just in case the temperature spikes, but I believe that will add to the price a lot. Some reading into it I found that type K thermocouples are the most commonly used? But also for those there are many variants, with very differing prices. And what reader do I need to use? Of course the cheaper (but still adequate) the better, as my funds are limited. I'm of course EU based, so ideally I want to get it here to keep it affordable. But even US examples could help me in what to look for. Jeroen Zuiderwijk Facebook page: https://www.facebook.com/barbarianmetalworking
Brian Dougherty Posted September 1 Posted September 1 (edited) I did not see this post before I answered in the "What did you do in your shop today" thread. You can use an inexpensive digital thermometer meter to read the thermocouple. I use a $25 (US) one from Amazon for my forge. I have melted a few of them by leaving them too close to the dragon's breath, so now I only buy cheap ones. This is just one example — the cheap meters all work the same way: Meter on Amazon For the thermocouple probe itself, I think you will want a long one that can be bent. This way, you can put the tip into the crucible without holding your hand (and the plastic connector) directly over the top. A thermocouple probe made to survive constant heat of 1300°C will cost more money. But a Type K thermocouple that is rated for lower temperatures will still give an accurate reading at higher temperatures. The problem is that it will not last as long. A Type K thermocouple always produces about 41 microvolts per degree Celsius, no matter what temperature the manufacturer says is the maximum. The temperature rating is really about how well the probe is built to survive the heat — not about how accurate it is. A Type K thermocouple should give correct readings right up until it physically breaks. (This is an oversimplification, but mostly true) This means you can buy an inexpensive Type K thermocouple and dip it into the bronze now and then to take a reading. It will not last forever, but I think you could get several casting sessions out of even a cheap probe. . Edited September 1 by Brian Dougherty -Brian
Dick Sexstone Posted September 1 Posted September 1 you might be better over the long run buying the reader and the meter separately .....I switched to buying these thermocouples because they came without a connector and were much less expensive than the replacement thermocouples that have a connector for my meter....as you can see I crudely wired the new thermocouple to an old thermocouple wire that had burned out.... I recalibrated the meter using ice water ..... it works slower than the original thermocouple cause it is shielded by a stainless tube.... it was 3 or 4 times less expensive than the original .... it's a K type ......
Jerrod Miller Posted September 1 Posted September 1 A couple things to keep in mind (simplified): The metals used in the thermocouple determine appropriate temperature range/accuracy Wire gauge generally translates to service life Stainless and ceramic sheaths extend life, but slow response time (often a very reasonable trade off) The thermocouple just produces a reliable voltage, so if you have an accurate enough voltmeter you can look up the formula or chart for a given thermocouple type and just use the voltage. Dedicated meters just do the math for you. Any changes in wire composition in the line can affect accuracy of readings. So don't plan on getting a short thermocouple and add copper wire extensions between it and the reader. If you buy a spool of wire you can twist the tip end together and that can work, but the wires can oxidize and your connection gets spotty. A welding torch or TIG melting the tips together is pretty easy (if you have the tools) and works quite well.
Brian Dougherty Posted September 1 Posted September 1 1 hour ago, Jerrod Miller said: If you buy a spool of wire you can twist the tip end together and that can work, but the wires can oxidize and your connection gets spotty. A welding torch or TIG melting the tips together is pretty easy (if you have the tools) and works quite well. I'm glad you chimed in here Jerrod. Is there any concern with the bare TC junction interacting with the molten bronze? For that matter, would the typical stainless jacket have any metallurgical issues? I know the molten metals sort of act like solvents to other metals and cause some wild alloying type events, but I don't know enough about that sort of thing to be anything other than paranoid. -Brian
Gert Burkhardt Posted September 1 Posted September 1 For my bronze and aluminum casting experiments I use 3.2mm K-type thermocouples with Inconel sleeve. They are specified up to 1100C and have survived a few dozen melting heats but as previously mentioned, in-and-out, not leaving for a long time. They were $58 at Amazon. Only thing I noticed the molten metal tends to stick in a thin layer and is difficult to get off, especially aluminum. That is why I use different ones for Al and bronze.
Jerrod Miller Posted September 1 Posted September 1 1 hour ago, Brian Dougherty said: I'm glad you chimed in here Jerrod. Is there any concern with the bare TC junction interacting with the molten bronze? For that matter, would the typical stainless jacket have any metallurgical issues? I know the molten metals sort of act like solvents to other metals and cause some wild alloying type events, but I don't know enough about that sort of thing to be anything other than paranoid. If you are going to be dipping thermocouples into liquid metal, I would add in that you should absolutely have the wires welded and shielded. In industrial melting, we often use disposable tips that have extremely small wires in a quartz (or similar) tube as a shield. Some are single use, some get several dips. You can download the Heraeus brochure here. Page 2 has good images of the different products. I have the most experience with the "Multi-Stik" and "Positherm" options. We buy them in bulk and pay a few bucks each (~$3 IIRC). For hobby level like this, I would definitely go with a product more like what Gert is using. If you are dipping an Inconel shield into liquid copper based alloy, my main concern would just be coating the Inconel (essentially brazing it). For the even cheaper option, go unshielded and just touch it to your crucible. If you want to be really fancy, you can even attach it to the outside of your crucible with furnace cement. If it were me (i.e. what I actually have in my shop at home), I like to use a welded tip of fairly heavy gauge wires and just use it in the heat (poking solid things as needed) for a little bit of time (single digits in minutes, but this really depends on environment and actual wire gauge). I also snagged some ceramic shields that my wire fits in. Just a tube with 2 holes, so wire can go down each channel and poke out the tip where it then gets welded. I haven't used my thermocouple at home for quite a while, though. 1
Jeroen Zuiderwijk Posted September 2 Author Posted September 2 Thanks for the responses so far. I would not use the sensor in the metal, but to measure the temperature in the charcoal around the crucible, preferably at the bottom and top of the crucible (which I can alternate with the same sensor), and preferably continuously so I can adjust the bellowing accordingly and get the optimal temperature during the melt. Right now I don't know if I'm partially cooling the crucible by blowing cold air against it, and if the temperature is sufficient all the way to the top. Jeroen Zuiderwijk Facebook page: https://www.facebook.com/barbarianmetalworking
Jono Pukallus Posted September 2 Posted September 2 17 hours ago, Jerrod Miller said: If you buy a spool of wire you can twist the tip end together and that can work, but the wires can oxidize and your connection gets spotty. A welding torch or TIG melting the tips together is pretty easy (if you have the tools) and works quite well. Sorry to hijack the thread a little, but I need to clarify: Are you saying you can just TIG weld the tips of two wires of the correct metals for the type of thermocouple and plug the other ends into whatever sensor you have and that is your thermocouple?! Are the spools of wire easy enough to come by? and (I presume) cheaper per length? This sounds too good to be true. Am I missing or over-simplifying something?
Brian Dougherty Posted September 2 Posted September 2 (edited) 45 minutes ago, Jono Pukallus said: Are you saying you can just TIG weld the tips of two wires of the correct metals for the type of thermocouple and plug the other ends into whatever sensor you have and that is your thermocouple?! Are the spools of wire easy enough to come by? and (I presume) cheaper per length? Yes, this is correct. A thermocouple is simply a junction made up of two dissimilar metals. Each metal combinations will produce a small potential difference that is proportional to temperature because of the Peltier effect. There are several catches. The primary one being that the voltage is tiny. The calibration factor is usually measured in microvolts per degree. If I flap my arms under some fluorescent lights, the magnetic field will generate microvolts at my finger-tips, so the temperature value can be very difficult to pull out of the electrical noise around you. the other big issue is the effect happens every time you change metals. So, when you connect your TC wire to a test lead, or a terminal block, you are creating an accidental thermocouple. If you are careful/clever, you can do this so that all the accidental thermocouples you create in a system cancel each other out, but you have to pay attention to what you are doing. TC wire is more expensive than lead wire, but much cheaper than buying finished probes. Edited September 2 by Brian Dougherty -Brian
Dick Sexstone Posted September 2 Posted September 2 Thanks Jerrod. I think I'm a good example of a little bit of knowledge is dangerous..... Great info !!! would I be better soldering the wire connections instead of wire nuts? and will a different probe which the meter has been recalibrated using ice water to read correctly at 32 degrees read correctly at 1500 degrees...... The set up I have now seems to be correct temps compared to the PID readings of my salt bath but it takes longer to reach a stable readout.... I did not know about making up your own using tig to join the sensing end .... COOL!!!!!
Gert Burkhardt Posted September 2 Posted September 2 If your task is to measure 1500 deg F I would not bother calibrating the Thermocouple with ice. Just watch if it shows your room temperature reasonably well. The potential error of a few degrees is likely small compared to the linearity error and drift of a K type at that temperature. I would not trust it to show better than 10-15 degrees accuracy. FWIW, I bought a 5-pack of finished thermocouples with 3 meter leads and connectors for $14. Very thin wire, glass fiber insulated and specified for 750 F. But I use them to measure the temperature during my investment mold burnout at 1350 F just fine. It is just the glass braid will deteriorate a bit.
Joshua States Posted September 2 Posted September 2 (edited) Looking at your furnace design (scroll up a few posts) in the other thread, it is very similar in size and shape to my crucible furnace. I wonder if you could just use a similar setup to mine where the TC comes in through the furnace wall on the side opposite from the blast. I use propane for my furnace, so that might make all the difference. I have a type S TC that is ceramic-clad and is long enough that when fully inserted, it comes to about 1cm from the crucible wall, if not actually touching the crucible. They are a lot more expensive than the type K or N and the correct wires for the type S are more expensive as well. Buy once, cry once. I use type N for my regular forge. These are very similar to the type K as both have a top temperature range around 1300C. I never really get my welding forge above 1150C, so the lower range works for me. They are very thin and flexible, but they also burn out after a while. I consider them to be "consumables". So, I bought a bunch of them. I probably replace them annually. You really do not need a fancy meter either. They make a small DRO for reading the TC. They come with directions for adjusting the DRO to match the TC type you are using and whether it reads in F or C. Just make sure you use the correct wire type for the TC you are using. You may be able to find the TC and DRO at an EU ceramics supply store online. Any business that sells ceramic supplies and especially kilns, usually sells the individual components to do repair or replacement of the internal parts. Edited September 2 by Joshua States 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Jerrod Miller Posted September 2 Posted September 2 Others have chimed in with great info. I just want to reiterate a couple points. Welded joints (oxyacetylene, TIG, or capacitive discharge) are very good, easy to do, and highly recommended Really watch out for all your connections and introducing unintentional metal combinations. Check a few known temperatures every time you build a new TC setup. Boiling water is great for this. A generic voltage reader works, but I HIGHLY recommend getting a dedicated device to read the output voltage and automatically convert to temperature. Looking at charts or entering formulas while dealing with things at temp isn't fun; it just adds to the stress of the moment. One like Josh linked is great. I use an old controller that had the controller aspect fried, but the readout still worked. It was being thrown away, so free was great. 1
Jono Pukallus Posted September 2 Posted September 2 So, if I were to compare the meter from Amazon, linked above, to making my own probe and, say, an Arduino-based reader (apart from the Amazon reader being stupid easy in comparison) I would have to take into account the dissimilar metals where the probe meets the reader and calibrate accordingly? And, do I have to account for two dissimilar metal junctions: one for where the positive side meets the board and one for where the negative side meets the board? Don't get me wrong, I'll probably just buy the meter, but I also run on curiosity and I teach early high school Engineering/STEM so this could be useful project content. I'm also thinking, if I buy the meter and recognise the thermocouple is a consumable, then at least I could easily and cheaply make more as needed.
Brian Dougherty Posted September 2 Posted September 2 What you are asking about is generally refered to cold junction compensation. It's been too many years since I have done that from scratch for me to explain, but must chips that you would use today to condition a tc signal to get it ready to go into an a/d on a micro will have some method of this designed in to deal with the incidental junction caused by landing the tc wire to the board. 1 -Brian
Jono Pukallus Posted September 3 Posted September 3 (edited) Got it, thanks! Does wire gauge or length affect the voltage? If it is that sensitive, I would presume there could be voltage drop if you make the TC wires too long? Edit: Disregard, I did some research instead of leaning on everyone here. For future readers: at a hobby level, the difference in readings due to wire length or gauge are negligible because the readings are generally in microVolts so a fractional variation will be tiny (industrial thermocouple circuits can be 100 feet plus!). Also, there is almost no current in the circuit so there is less loss to resistance. Hobby readers also have very high impedance which also helps negate issues with wire resistance. (All of this is a very quick summary of the google info I found, so take it with a grain of salt!) Edited September 3 by Jono Pukallus
Gert Burkhardt Posted September 3 Posted September 3 5 minutes ago, Jono Pukallus said: ...Does wire gauge or length affect the voltage?... Not really. Since the measurement input has pretty high impedance and the resulting current is negligible, wire gage and length has no effect. That is, unless the long cable introduces electrical noise from the environment.
Jerrod Miller Posted September 3 Posted September 3 11 minutes ago, Jono Pukallus said: Got it, thanks! Does wire gauge or length affect the voltage? If it is that sensitive, I would presume there could be voltage drop if you make the TC wires too long? Not at the scale you are looking at. I have to run TC wire from our heat treat ovens to the recorders and such, and there are certainly issues with running the 100+ feet, but you shouldn't be having too much length near a forge.
Jono Pukallus Posted September 3 Posted September 3 Hehe, you both responded in the time it took me to type an edit! I'll have to pick up my game! 🤣 1
Brian Dougherty Posted September 3 Posted September 3 The challenge with long leads is the electrical noise that can get coupled into the wires. Fortunately, most of it is common mode which is easier to reject, but with tc amplifiers, every millivolt matters so they are very noise sensitive. Industrial quality instrumentation amplifiers for TCs are pretty amazing bits of engineering. -Brian
Joshua States Posted September 8 Posted September 8 All this talk about making a TC from scratch reminds me of an old blacksmith saying: "Why buy something for $50 when you can make it yourself for $75?" 2 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Jono Pukallus Posted September 8 Posted September 8 Yep, that's usually me! Although in this case, at least for consumable replacements, I can get 10m of fibre insulated k type thermocouple wire (for making extensions without error, I presume) for about $7 Australian, and most of the k type TCs I can find online would cost me that, and I should get 5 to 10 of them out of one length, depending on how long I need them.
