Posted
I'm calling it a pocket razor.  It was mostly an experiment in hollow grinding.  Single sided, 1080, very hard, just a boiling water temper with a mosaic pin decoration.  The scabbard is a plastic slip on blade cover, covered in a bit of ray skin.  It will be on the table at SLT BladeWest next week.
g
  • Like 5
"The worst day smithing is better than the best day working for someone else."
I said that.
If a thing is worth doing, it is worth doing badly.
- - -G. K. Chesterton
So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy.
Grant Sarver
