kb0fhp Posted April 29, 2006 Share Posted April 29, 2006 (edited) I may have cross-posted this - if so I apoligize. I am a PhD metallurgist with years of experience in heat treating and failure analysis. My primary specialty is quenching (aluminum and steel) - water, oils, salt and polymers. I have been asked by Advanced Material and Progress Magazine to write and article on the history of quenching. I have many references prior to 200 AD or so, but little from about 200AD to 1850. Can any one provide me with a good set of references regarding the history of quenching? I suspect much of the dearth of information is because little was written down, or because of guild protection of intellectual property. I woud really appreciate it. If anyone has any questions regarding heat treating, quenching or other similar topic - feel free to ask me. I would be glad to help. Thanks Scott MacKenzie, PhD aka KB0FHP Edited April 29, 2006 by kb0fhp D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
Jeff Pringle Posted April 30, 2006 Share Posted April 30, 2006 Have you checked out the bibliography of "A History of Metallography" (Smith, MIT Press 1988)? There must be something you can use in there. "On Divers Arts" (Theophilus, 1120ish) has a couple recommendations, and other early ideas can be found in "The Pirotechnia" of Biringuccio (1500ish) - both of those are out in Dover paperbacks. Jomsvikingar Raða Ja! http://vikingswordsmith.com Link to comment Share on other sites More sharing options...
kb0fhp Posted April 30, 2006 Author Share Posted April 30, 2006 Have you checked out the bibliography of "A History of Metallography" (Smith, MIT Press 1988)? There must be something you can use in there. "On Divers Arts" (Theophilus, 1120ish) has a couple recommendations, and other early ideas can be found in "The Pirotechnia" of Biringuccio (1500ish) - both of those are out in Dover paperbacks. Thank you - I have Pirotechnica, but I do not have On Divers Arts.....Thank you! Scott D. Scott MacKenzie, PhD Heat Treating (Aluminum and Steel) Quenching (Water, Polymer, Oil, Salt and Mar-Tempering) Link to comment Share on other sites More sharing options...
daryl meier Posted April 30, 2006 Share Posted April 30, 2006 "Sources for the History of the Science of Steel 1532-1786" MIT press 1986, Cyril Stanley Smith , has some interesting formuli for quenchants. I particularly like the distilled cockchafer grubs one. Articles by Piaskowski, and by Antiens in JISI ( 1960's) show evidence of hard structures from an earlier time peroid , but do not speculate on method of quenching. Link to comment Share on other sites More sharing options...
