DGentile 9 Posted June 9, 2006 Share Posted June 9, 2006 may be an odd question... i know tomorrow I will reveal the results .... your not-so-usual stone-chisle however... I wanted to ask if anyone here got a good idea about how hard (HRC) a stone-chisles "cutting-edge" should approx. be? thanks Daniel FERRUM - Daniel Gentile custom knives & forging classes http://www.ferrum-d.com Link to post Share on other sites
DFogg 13 Posted June 10, 2006 Share Posted June 10, 2006 Fikes use to sharpen bull points and temper them "pigeon egg blue" Don Fogg Link to post Share on other sites
ScottB 0 Posted June 10, 2006 Share Posted June 10, 2006 Daniel, don't know if it makes much difference what kind of stone you use, but one of my teachers was a marble carver and he suggested the end be something like purple to blue at the tip and a little less drawn further back.... Might be just how he did it, but there it is.... I keep meaning to make some of my own carving chisels but can't seem to get to into it considering I can't afford to by the marble to work.... lol Too bad, I am not a bad sculptor sometimes.... But, money is an object and obstacle if you don't have it.... heh, heh.... Link to post Share on other sites
DGentile 9 Posted June 10, 2006 Author Share Posted June 10, 2006 thanks. I used to repair and reforge a lot of construction-site tools..... mostly reforging deformed / dull tips and reheat-treating them. I after the reforging and a quick grind I heated them to non-magnetic and quenched only the tip in water (but quickly...) pulled it out ... used a rasp to remove the oxide and waited 'till the tip got blue and then into the oil... this was the procedure I was told to do with that sort of tools... but I had not much info about the steels... so not much idea what Hardness a 290°C temper will result in. anyways... with this piece (intended for "soft" stones, like marble, sandstone, limestone...) I'll go for a blue temper... resulting in approx. 58HRC I guess t hat should work fine. (it's 01 steel... I know... not the perfect choice for the the job, but goes well with the damascus rest ) thanks again. FERRUM - Daniel Gentile custom knives & forging classes http://www.ferrum-d.com Link to post Share on other sites
Giuseppe Maresca 0 Posted June 10, 2006 Share Posted June 10, 2006 On an old book i read that stone chisels were tempered to bronze color, so pretty hard. There was written that you have to harden not only the edge, but also the area that you hit with the hammer. Mourir pour des idées, c'est bien beau mais lesquelles? Link to post Share on other sites
B. Norris 13 Posted June 11, 2006 Share Posted June 11, 2006 (edited) The harder the chisels are the longer they will stay sharp. The best stonecarving chisels are made with carbide tips, brazed on, instead of hardened steel. Of course the harder they are the easier to shatter so usually just the teeth of the chisel are hardened, 3 to 4mm. Chisels for harder stones usually are drawn to a straw or bronze color and are ground with a larger angle on the tip (duller). Chisels for softer stones would be ground to a smaller angle (sharper) and tempered back to a purple or blue depending on the stone they are intended for. Hammers used by stonemasons to strike chisels are, often, made of unhardened steel. Hardening the end of the chisel that is struck makes it so that when struck by an unhardened hammer it "bites" and does not slip off the end of the chisel. Sometimes chisels would be cupped slightly on the striking end and hardened to provide even more "bite". Traditional steels for stonemasons chisels have 100 to 130 points of carbon and that's about it. There are a few businesses in Italy that still make stonecarving chisels the "old way", might be worth a roadtrip to check them out. Edited June 11, 2006 by B. Norris “All work is empty save when there is love, for work is love made visible.” Kahlil Gibran "It is easier to fight for one's principles than to live up to them." - Alfred Adler Link to post Share on other sites
B. Norris 13 Posted June 11, 2006 Share Posted June 11, 2006 Here is the link to the links page of a stoncarver from the US who trained in Italy: http://www.stonecarver.com/scullink.html He has links to businesses that sell stonecarving tools so you can look around and see what is available commercially. “All work is empty save when there is love, for work is love made visible.” Kahlil Gibran "It is easier to fight for one's principles than to live up to them." - Alfred Adler Link to post Share on other sites
RKNichols 0 Posted June 11, 2006 Share Posted June 11, 2006 (edited) Well, you need to know how hard it is BEFORE you temper it. If we quenched out a .95%C steel and a .15% C steel, and tempered them both at 300F, which one do you think would be the hardest? The tempering temperature would drop them both approximately the same number of Rockwell units (assuming we have no significant alloying differences) but I am betting the .95C would be a lot harder even if it were the same temper color as the .15C steel. I would guess stone working tools would be in the Rc 40-50 range. Edited June 11, 2006 by RKNichols Which is worse; ingnorance or apathy? Who knows? Who cares? Link to post Share on other sites
