Svet
10¢ forge, made of Ytong
Your original design will work. No need to get fancy and reinvent the wheel.
Your issue is not enough volume inside your forge.
All you need is 1500 degrees.
I once made a heat treat forge out of "I" beams stacked on a steel table (my burner was a weed killer torch) to treat a short sword and it worked fine.
I bet if you just made a square retangular box forge using that material and the I.D. is the size of one of those blocks, it would work fine.
You will have a hot spot and you just have to work the blade back and forth.
Anyhow think volume, flame development, etc.
So, I just need a larger diameter tunnel?
What if I just use a smaller flame with this diameter?
Svet, i think it's a great idea using those blocks as parts for a forge! Even thought they're not supposed to, they do a great job of keeping the heat in.
I made something roughly similar to HT a knife once. I barely got the edge up to critical, but managed to melt the concrete where the hot gases were coming out of the forge. I've still got 2 little vitrified blobs of glass from it. I don't know how hot i got that tunnel, but i needed my welding hood to look inside the main body of it.
