Jason Taylor
9260 ?
any thoughts on 9260 steel? I really want 5160 in 1/4 x 1 but can only find 9260 in that size. The little 5160 I have worked with has been very impressive performance wise and i just wonder if 9260 will work as well.
I have never worked in 9260, unless the 5160 from Admiral has always been 9260, but I found this at
http://www.efunda.com/
AISI 9260
Category Steel
Class Alloy steel
Type Standard
Common Names Silicon-manganese steel
Designations France: AFNOR 60 S 7 , AFNOR 61 SC 7
Germany: DIN 1.0909
United Kingdom: B.S. 250 A 58
United States: ASTM A29 , ASTM A322 , ASTM A331 , ASTM A505 , ASTM A519 , ASTM A59 , SAE J1268 , SAE J404 , SAE J412 , SAE J770 , UNS G92600
Composition
Element Weight %
C 0.56-0.64
Mn 0.75-1.00
P 0.035 (max)
S 0.04 (max)
Si 1.80-2.20
Mechanical Properties
Properties Conditions
T (°C) Treatment
Density (×1000 kg/m3) 7.7-8.03 25
Poisson's Ratio 0.27-0.30 25
Elastic Modulus (GPa) 190-210 25
Tensile Strength (Mpa) 1758 25 oil quenched, fine grained, tempered at 425°C more
Yield Strength (Mpa) 1503
Elongation (%) 8
Reduction in Area (%) 24
Hardness (HB) 600 25 oil quenched, fine grained, tempered at 205°C more
AISI 5160
Category Steel
Class Alloy steel
Type Standard
Common Names Chromium steel
Designations United States: ASTM A322 , ASTM A331 , ASTM A505 , ASTM A519 , SAE J404 , SAE J412 , SAE J770 , UNS G51600
Composition
Element Weight %
C 0.56-0.64
Mn 0.75-1.00
P 0.035 (max)
S 0.04 (max)
Si 0.15-0.30
Cr 0.70-0.90
T (°C) Treatment
Tensile Strength (Mpa) 722.6 25 annealed at 815°C more
Yield Strength (Mpa) 275.8
Elongation (%) 17.2
Reduction in Area (%) 30.6
Hardness (HB) 197 25 annealed at 815°C more
Impact Strength (J)
(Izod) 10 25 annealed at 815°C more
Hope that is of some use,
Al Lawrence has some 9260. He is found at Riverside Machine Shop in Dequeen, Arkansas. I have it from a knowledgable maker that 9260 is Britain's version of 5160. Take that for what it's worth. I have forged it and it does indeed act like 5160 in my opinion. Lin
If you have ever unwound a GM coil spring, and used it, you have used 9260. They have been making hot wound coils springs from this at General Motors for a Loooong time. It will make fine blades.
I have forged alot of it and I to agree it is just like 5160. I never intended to get it but that is what admiral steel sent me. The Si is alot higher then 5160 but I have not noticed any increase in brittleness.
I used the same temps and times as for 5160.
