Posted
Hey Guys,
I'm new here, and got a question for you.
As i am sure is a problem with most beginers like me, i am having a very hard time getting the shoulders on the ricasso square, so as to get a good fit on the top of the guard.
There is a product made of hardened bar stock, called a filing fixture, or filing guide, that clamps on the ricasso area, so you can file the shoulders square and not eat into the hardened steel of the jig.
"question."   Where can i get this thing ??
I have looked every where,  and cannot find one.
I appreciate any and all help here.
Thanks!
CanyonMan
Posted
Or you can make one yourself. Clamp two pieces of thick ( .25 or maybe a little better ) hardenable steel together. Grind / file one set of the long edges flat and even with each other. While still clamped, drill guide holes.  [ Picture clamping two dominos together and drill where the center dot would be on each side or maybe a little closer to the edge ]  I used a 3/16 drill bit and 3/16 mild steel rod as my guide pins. Now harden and don't temper or temper very slighly ( 300 degrees or so ) depending on the steel.
I hope that made some sense.
Seth
Posted
I think that Koval sells one.  If not, Uncle Hal does.
Posted
Tip; instead of clamping, stick the two pieces together with a few spots of epoxy. No clamps to get in the way when drilling and grinding.  A quick blast with a torch or in the forge will break down the epoxy.
Posted
ScottB ,
Man this is "exactly" what i am looking for!
I tried to call this fellow, Don, but could not find him as yet.
i will let you guys know one way or the other. Thanks.
Joss,
I tried kovals, and they 'do,' carry them, but are 'all out', and it is very small, looks nice, but i would like one somewhat larger. Joss i tried to find this "Uncle Hal," i cannot locate the site..  Can ya help me here?
Guys, please keep those 'suggestions coming', i am desperate here! I really need this thing asap.
Thanks to all of you thus far.
CanyonMan
Posted
Uncle Al at Riverside Machine- www.riversidemachine.net
A true and square filing jig is dificult to make. Buy one and make two knives in the time you would have spent on it. then again I guy should always make what he wants. mike
Posted
Hi Seth:  Would you try to harden the two pieces while they are "pinned" together?  Same for grinding.  Finally, any advantage to the set-screws apparently used to pull the two together I've seen on some illustrations?
Thanks for the help.  Malik
