B Finnigan Posted January 1, 2008 Posted January 1, 2008 (edited) I am working on a dagger that will have a fuller groove and needed a groove cutting tool. So I built one out of 1/2" square mild steel. The bit is 1095 and interchangable. I turned the square bar to 3/8" round and peened a scotch broom wood handle between two steel caps. The guide bar is adjustable from 1/8" out to 1 3/4". It also takes 1/4" and 3/8" lath chisels. Edited February 3, 2008 by B Finnigan Everything I need to know I learned from the people trapped in my basement. I'm out of my mind but feel free to leave a message.
DFogg Posted January 1, 2008 Posted January 1, 2008 Nice looking tool. Would love to see it in action. Don Fogg
Alan Longmire Posted January 1, 2008 Posted January 1, 2008 Nice job! How does it track? Oh, and I looked up the active substance in Scotch Broom tops: scopalamine. Don't eat any!
B Finnigan Posted January 1, 2008 Author Posted January 1, 2008 (edited) Thanks Don and Alan! I may be able to talk my daughter into shooting some video it. It cuts like butta' and every 3-4 passes I have to clear the cutings out. Even using one hand with no pressure on the tension knob it cuts aggresively. This was my first test cut on some mild steel. Alan, I didn't know it had scopalamine in it. I use the patches when I go deep sea fishing for motion sickness. Maybe I will save a few bucks and bring some tops and a pipe. Edited January 13, 2008 by B Finnigan Everything I need to know I learned from the people trapped in my basement. I'm out of my mind but feel free to leave a message.
JJH Posted January 1, 2008 Posted January 1, 2008 Would be inverested in some vids/photos of it in action so i could be 100% sure how its used
J. Helmes Posted January 1, 2008 Posted January 1, 2008 for starters i'd like to say that that is a beautiful tool that you have made there. out of curiosity though, how would some one put a fuller into a large sword that tapers along its length? http://www.jeffhelmes.com
polarbearforge Posted January 1, 2008 Posted January 1, 2008 Nice looking tool. I like the adjustability of it. Does it chatter at all while cutting? Do you use it dry or with cutting lube? On a longer blade that tapers, you can still get a straight line by putting the blade on top of another piece that is straight and using it to guide the tool. Jamie Jamie Boley Polar Bear Forge
B Finnigan Posted January 2, 2008 Author Posted January 2, 2008 (edited) It only chatters if you get the rake angle wrong. I have not tried any lube yet since it seems to work fine dry. Once you get a slot going the guide is not needed. If I was to build another one I would add a few degrees more curve to it for some extra cleareance. Edited January 4, 2008 by B Finnigan Everything I need to know I learned from the people trapped in my basement. I'm out of my mind but feel free to leave a message.
J. Helmes Posted January 2, 2008 Posted January 2, 2008 On a longer blade that tapers, you can still get a straight line by putting the blade on top of another piece that is straight and using it to guide the tool. Jamie brilliant. thanks http://www.jeffhelmes.com
B Finnigan Posted January 27, 2008 Author Posted January 27, 2008 (edited) My sanding/draw filing fixture also was used as a straight edge for the guide. (No comments about my clutered bench, I know where everything is at. ) Edited January 27, 2008 by B Finnigan Everything I need to know I learned from the people trapped in my basement. I'm out of my mind but feel free to leave a message.
ETX Chartaine Posted February 28, 2008 Posted February 28, 2008 Been reading about all these tools like this and wondering to my inexperienced self ... do you use this tool on cold steel or semi warm steel or what?
dan pfanenstiel Posted March 1, 2008 Posted March 1, 2008 Just finished my take on the thing. Gotta thank Brent for the idea and examples. This is one area (of many) that I havn't been able to do to my blades satisfactorily. I changed up the shaft so that it stayed in line, but provided something of a finger clearance. Seems promising in initial tests. And no, I don't make tools purty for myself Dan Dan Pfanenstiel
B Finnigan Posted March 2, 2008 Author Posted March 2, 2008 Cool beans!! There is an improvement that another member from Primal Fires came up with for the guide that I have not posted yet. With multiple brains making and using the same tool a type of "gadget evolution" will happen. I grew up watching both my dad and grandfather design and create in thier shops. Both of them were hardcore function-over-form people and that philosophy stuck with me. Last night I spent a couple hours grinding some lathe bits and not once did I stop, step back and look at my $1400 grinder and say to myself "Dang, what a beautiful, symetrical, flowing piece of machinery". I got it to do a job and it does it well so I am satisfied. What it looks like is not going to help me one bit. Both sides of my family have a long lineage of talented craftsmen but not a single artist. Everything I need to know I learned from the people trapped in my basement. I'm out of my mind but feel free to leave a message.
Brenno Posted March 3, 2008 Posted March 3, 2008 Cool beans!! There is an improvement that another member from Primal Fires came up with for the guide that I have not posted yet. With multiple brains making and using the same tool a type of "gadget evolution" will happen. I'd buy one. Even an ugly one. Who here wouldn't. Great ideas guys. Re. the tapered sword question: For us stock removers it wouldn't be a problem, just do it on the flatbar before grinding commences. Otherwise yes, clamp the tapered sword to a flat bar. You could even have a depth setter wheel that rolls along the flatbed so that the fullerer (lol) stays the same height above and would thus fade out nicely as the distal taper increases. First you must learn to use, this... It'll teach you to use, this... (Uncle Argyle, Braveheart.) Fable Blades.com
loneronin Posted March 3, 2008 Posted March 3, 2008 beatiful tools! I'll do it! B Finnigan, Dan Pfanenstiel, what is the size of the square bare you used? 5/8" ? dont' tell me what I can't do
B Finnigan Posted March 3, 2008 Author Posted March 3, 2008 I used 1/2" but it doesn't matter as long as it can hold the bit, guide and some type of handle. The hole for the bit does not have to square either. It just allows for larger bits w/o having to use a bigger chunk of square bar. I will be making a smaller version for cutting borders on bracelets, pendants, etc. Right now I am using my leather groover which is not what it was made for. Everything I need to know I learned from the people trapped in my basement. I'm out of my mind but feel free to leave a message.
dan pfanenstiel Posted March 3, 2008 Posted March 3, 2008 (edited) Mine was just 1/2" square mild steel. Bit slot takes a 3/8" lathe bit, or custom ground. I did change the guide up from the pics. Instead of bending the 1/4" round rod, like in the picture, I went back and silver brazed two peices together to get a cleaner 90 degree angle. Also inlet the hole in the main bar somewhat to get the guide closer to the bit. On japanese style, I want to get pretty close to the mune, within an eighth inch or so. Dan Edited March 3, 2008 by dan pfanenstiel Dan Pfanenstiel
B Finnigan Posted March 4, 2008 Author Posted March 4, 2008 I cut a 1/4" slice of 1/4" x 2" angle for the guide to get closer. Should have done it that way first but that is how tool prototyping goes sometimes. Measure once and cut twice (or more ). Everything I need to know I learned from the people trapped in my basement. I'm out of my mind but feel free to leave a message.
loneronin Posted March 4, 2008 Posted March 4, 2008 please guys, post the pics of the last version of your tools... I can't wait to make one and all your experience is very very welcome!! dont' tell me what I can't do
dan pfanenstiel Posted March 5, 2008 Posted March 5, 2008 Here's mine, turned up to show. The notch is what I was talking about to allow the guide to get a little closer to bit center. At this point, the closest it'll get, it's at about 3/16" from guide edge to center bit. New bit there is just a piece of 01 hand ground to a half round shape and hardened. Dan Dan Pfanenstiel
B Finnigan Posted March 5, 2008 Author Posted March 5, 2008 The notch is a great idea! It will be cool to watch this tool evolve as more brains go to work on it for slightly different applications. This is what the forums are all about, pooling our collective ignorance and seeing what comes of it. 1 Everything I need to know I learned from the people trapped in my basement. I'm out of my mind but feel free to leave a message.
loneronin Posted March 5, 2008 Posted March 5, 2008 (edited) great pic and great evolution Dan! I presume the depth setter wheel could be the extra-mile but it is probably too sofisticated for me. I'll try to find a square bare to start my tool. You drilled the lathe-tool hole and then file it square correct? Edited March 5, 2008 by loneronin dont' tell me what I can't do
B Finnigan Posted March 5, 2008 Author Posted March 5, 2008 That is how I did it since I looked all over for a square drill bit to no avail. Everything I need to know I learned from the people trapped in my basement. I'm out of my mind but feel free to leave a message.
B. Norris Posted March 5, 2008 Posted March 5, 2008 Just wanted to say that this is a really great tool and a wonderful contribution to the forum. That being said.. Gotta get my two cents worth in! You could also weld or solder on a piece like in the cheesy paint shop touch up of your picture below. It would not decrease the strength of the bar this way. I have been watching this thread and thinking about this tool. I am envisioning something with handles on it like a hand plane. In a few months when I get some time I'll have to give it a go! ~Bruce~ 1 “All work is empty save when there is love, for work is love made visible.” Kahlil Gibran "It is easier to fight for one's principles than to live up to them." - Alfred Adler
