Thunder Posted March 17, 2018 Author Share Posted March 17, 2018 very clean build, love the foot operated air. KNIVES PLUS ® Retail cutlery and cutlery accessories since 1987. Link to comment Share on other sites More sharing options...
kenuto Posted March 17, 2018 Share Posted March 17, 2018 Just a random question: would these jacks work inverted? Link to comment Share on other sites More sharing options...
MacCrea Posted March 22, 2018 Share Posted March 22, 2018 Thanks all! Just followed what I've seen on this post. Squished 1" square steel down to 1/4" with drawing dies 5x in one heat. Pretty simple build. Found the foot pedal on Amazon for a little over $20. Link to comment Share on other sites More sharing options...
Jonathanbradshaw Posted May 7, 2018 Share Posted May 7, 2018 On 3/22/2018 at 4:59 PM, MacCrea said: Thanks all! Just followed what I've seen on this post. Squished 1" square steel down to 1/4" with drawing dies 5x in one heat. Pretty simple build. Found the foot pedal on Amazon for a little over $20. Can you link to the pedal you purchased? Link to comment Share on other sites More sharing options...
MacCrea Posted May 7, 2018 Share Posted May 7, 2018 https://www.amazon.com/gp/product/B007EBXCTY/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
AndrewB Posted July 31, 2018 Share Posted July 31, 2018 I think I'll have to come up with something similar over the winter time. Link to comment Share on other sites More sharing options...
Sam Young Posted November 12, 2018 Share Posted November 12, 2018 I’ve been following this topic for a couple weeks and I’m the final stages of mine. I need to get some Grade 8 bolts and make brackets to hold the dies in place and to be removable. Thanks to Thunder and everyone’s input and ideas!! Link to comment Share on other sites More sharing options...
Sam Young Posted December 21, 2018 Share Posted December 21, 2018 1 Link to comment Share on other sites More sharing options...
Thunder Posted December 21, 2018 Author Share Posted December 21, 2018 Look Great! KNIVES PLUS ® Retail cutlery and cutlery accessories since 1987. Link to comment Share on other sites More sharing options...
Jonathanbradshaw Posted December 21, 2018 Share Posted December 21, 2018 I finally got my press frame welded up. I have not made the attachment for the dies yet. How are people locking the die plates in for the slide in method like pictured above? Does this require a screw or will a drop in pin suffice? Link to comment Share on other sites More sharing options...
Sam Young Posted December 27, 2018 Share Posted December 27, 2018 On 12/21/2018 at 2:55 PM, Jonathanbradshaw said: I finally got my press frame welded up. I have not made the attachment for the dies yet. How are people locking the die plates in for the slide in method like pictured above? Does this require a screw or will a drop in pin suffice? Mine as of now just slides in, I feel a set screw of some kind would be best. If u did a pin, u have the potential that it may/can get bound some how and won’t be able to remove the pin. Link to comment Share on other sites More sharing options...
AndrewB Posted December 27, 2018 Share Posted December 27, 2018 What size square tubing are you guys using for these? Link to comment Share on other sites More sharing options...
Sam Young Posted December 28, 2018 Share Posted December 28, 2018 On 12/27/2018 at 11:23 AM, AndrewB said: What size square tubing are you guys using for these? I used 2” x 2” x 1/4” wall for mine Link to comment Share on other sites More sharing options...
AndrewB Posted December 28, 2018 Share Posted December 28, 2018 I'll have to find some because I'm strongly considering building one of these in the near future. Just to save myself the hammering of steel to forge weld. Link to comment Share on other sites More sharing options...
Conner Michaux Posted December 28, 2018 Share Posted December 28, 2018 How much does it cost to build a Press? It probably varies but can anyone give me a price range? Link to comment Share on other sites More sharing options...
Sam Young Posted December 28, 2018 Share Posted December 28, 2018 15 minutes ago, Conner Michaux said: How much does it cost to build a Press? It probably varies but can anyone give me a price range? The a actual jack is $90 with coupon from HF, tubing is going to vary. If you have a local scrap yard or a welding/sheet metal shop nearby you can check with them. Otherwise from a metal distributor it’s prob guna be $100 or so for a full length stick of it. Link to comment Share on other sites More sharing options...
Cdecker Posted February 15, 2020 Share Posted February 15, 2020 (edited) First off, I just wanted to thank everyone who posted on this thread! This was a really fun build, and the advice/knowledge on here defiantly made the whole process a lot smoother. I did add a pneumatic cylinder for the manual release valve. It was kind of a pain to set up and get right but well worth it. The return spring inside this particular cylinder was not strong enough to lock the valve into the closed position, so I had to add additional springs.Had to add yet another additional spring to help close the valve. Also added some aluminum slag shields. Mission success!! Tested it out on a Damascus billet. Squared it all up and drew it out! Thanks again!! Edited March 28, 2020 by Cdecker Link to comment Share on other sites More sharing options...
Jonathanbradshaw Posted February 16, 2020 Share Posted February 16, 2020 Extra springs!!!! I ran into the same problem with the return spring on the pneumatic cylinder not being strong enough to close the valve. I had been trying to determine if there is a way to adjust the spring tension. Link to comment Share on other sites More sharing options...
Wallace Foster Posted October 16, 2020 Share Posted October 16, 2020 This is great I already have the jack so building the rest of this SHOULD be fairly straight forward I have a cheap 115 volt MIG welder that I hope will work I do have a 220V Lincoln stick but my shop is not wired for it yet. Now I just need to start scrounging for steel, or just bite the bullet and buy it. Link to comment Share on other sites More sharing options...
Thunder Posted October 16, 2020 Author Share Posted October 16, 2020 Great looking machines! I am impressed with all the improvements. KNIVES PLUS ® Retail cutlery and cutlery accessories since 1987. Link to comment Share on other sites More sharing options...
Wallace Foster Posted October 31, 2020 Share Posted October 31, 2020 (edited) I started mine and I realized my jack is a 30 tonne and has a little bigger bottom on it but I can still make it work I think I have 8 ft of 1"x2" I can add to the side of my base to give me the extra area. Great inspiration in here keep it up I have a pic but I can't seem to post it.....Got it LOL Edited November 1, 2020 by Wallace Foster Link to comment Share on other sites More sharing options...
Wallace Foster Posted October 9, 2021 Share Posted October 9, 2021 Thing move slow in my world, I got a different plan set up and some bigger tubing. I got a new welding helmet and I can now see what I am doing and I also picked up a stick/DC TIG welder and I have been using the stick for everything now and love using it. Here is the progress on my press I just need to weld the anvil base on top and bottom and tidy up the rest of the welds and hook up a something to release the air. Then build some dies but steel is getting hard to get here :( Link to comment Share on other sites More sharing options...
Gary LT Posted March 27, 2022 Share Posted March 27, 2022 This is a great thread with lots of input to help all, obviously it has. I finally got “the” HF jack on sale and will build the press for myself. I want to add the foot press and I want to feather the pedal, so I can press and move fairly rapidly. Want type of foot pedal / valve is best. “Poor Man’s Hydraulic Press” input was very helpful especially on the Bimba cylinder but I still want to be exact before I purchase (and yes schematics explanation help!) because I know absolutely “jack-sheet” about this stuff Kind thanks to all! Gary LT "I Never Met A Knife I Didn't Like", (Will Rogers) Link to comment Share on other sites More sharing options...
Gilbert McCann Posted March 27, 2022 Share Posted March 27, 2022 (edited) @Gary LThere's a shot of mine. It was very useful. I'm not sure about moving rapidly with the foot pedal but probably 2 or 3 squeezes per heat. I used 1 1/2×3/16 square tube,top cross bar was 1/2×2 flat bar.I tried to leave the top removable but kept breaking bolts. After welding the top cross bar on I had no more problems. Here are some of my dies and you can see what I connected to the pressure release. I like to think I weld better now Edited March 27, 2022 by Gilbert McCann Link to comment Share on other sites More sharing options...
Gary LT Posted March 28, 2022 Share Posted March 28, 2022 (edited) Hey there @Gilbert McCann! Thanks and the photos are clear, especially the dies as they are designed which I like. My problem is I want to use the foot pedal to control all the action up and down on the press. Which means I need a Bimba cylinder with clovis coupling to turn the exhaust valve quickie to release cylinder pressure and down action occurs all with the foot pedal. Then using same foot pedal, go back up. My ignorance is 1) What foot pedal will work best as a “3 way pedal described pressing down to turn the Bimba and release the cylinder pressure (goes down). Then I assume you stop pressing the pedal and the jack (goes up.) HERE IS THE LINK FROM AN EARLIER POST IN THIS TOPIC https://www.spacmo.org/Press.htm I see the set up however I am total clueless how to hook one up…………is a 4 way pedal better suited? Or something else?? That’s where I am lost! Gary LT Edited March 28, 2022 by Gary LT 1 "I Never Met A Knife I Didn't Like", (Will Rogers) Link to comment Share on other sites More sharing options...
